[PATCH v2] doxygen: Add groups for related test suites
Chris Johns
chrisj at rtems.org
Mon Mar 13 21:57:28 UTC 2023
OK
Does this catch all RTEMSTestSuites cases?
On 14/3/2023 10:16 pm, Sebastian Huber wrote:
> v2: Adjust group membership of related test suites.
> cpukit/doxygen/top-level-groups.h | 24 +++++++++++++++++++
> testsuites/unit/ts-unit-no-clock-0.c | 2 +-
> ...boot-processor-not-assigned-to-scheduler.c | 2 +-
> .../ts-fatal-idle-thread-create-failed.c | 2 +-
> .../ts-fatal-idle-thread-stack-too-small.c | 2 +-
> .../ts-fatal-init-task-construct-failed.c | 2 +-
> ...ts-fatal-mandatory-processor-not-present.c | 2 +-
> ...scheduler-requires-exactly-one-processor.c | 2 +-
> testsuites/validation/ts-fatal-smp.c | 2 +-
> ...atal-start-of-mandatory-processor-failed.c | 2 +-
> .../ts-fatal-start-on-not-online-processor.c | 2 +-
> .../validation/ts-fatal-too-large-tls-size.c | 2 +-
> .../validation/ts-performance-no-clock-0.c | 2 +-
> testsuites/validation/ts-terminate.c | 2 +-
> testsuites/validation/ts-userext.c | 2 +-
> testsuites/validation/ts-validation-0.c | 2 +-
> testsuites/validation/ts-validation-1.c | 2 +-
> testsuites/validation/ts-validation-acfg-0.c | 2 +-
> testsuites/validation/ts-validation-acfg-1.c | 2 +-
> testsuites/validation/ts-validation-cache.c | 2 +-
> testsuites/validation/ts-validation-intr.c | 2 +-
> .../validation/ts-validation-io-kernel.c | 2 +-
> .../validation/ts-validation-no-clock-0.c | 2 +-
> testsuites/validation/ts-validation-non-smp.c | 2 +-
> .../validation/ts-validation-one-cpu-0.c | 2 +-
> .../validation/ts-validation-one-cpu-1.c | 2 +-
> .../validation/ts-validation-smp-one-cpu-0.c | 2 +-
> .../validation/ts-validation-smp-only-0.c | 2 +-
> .../validation/ts-validation-smp-only-2.c | 2 +-
> .../validation/ts-validation-timecounter-0.c | 2 +-
> .../validation/ts-validation-timecounter-1.c | 2 +-
> .../ts-validation-timecounter-smp-0.c | 2 +-
> testsuites/validation/ts-validation-tls-0.c | 2 +-
> testsuites/validation/ts-validation-tls-1.c | 2 +-
> 34 files changed, 57 insertions(+), 33 deletions(-)
> diff --git a/cpukit/doxygen/top-level-groups.h b/cpukit/doxygen/top-level-groups.h
> index 8a439feee1..25bf8faae2 100644
> --- a/cpukit/doxygen/top-level-groups.h
> +++ b/cpukit/doxygen/top-level-groups.h
> @@ -63,3 +63,27 @@
> * @brief This group contains the test suites.
> + * @defgroup RTEMSTestSuitesPerformance Performance Test Suites
> + * @ingroup RTEMSTestSuites
> + * @brief This group contains the test suites related to performance tests.
> + * @defgroup RTEMSTestSuitesUnit Unit Test Suites
> + * @brief This group contains the test suites related to unit tests.
> + * @defgroup RTEMSTestSuitesValidation Validation Test Suites
> + * @brief This group contains the test suites related to validation tests.
> diff --git a/testsuites/unit/ts-unit-no-clock-0.c b/testsuites/unit/ts-unit-no-clock-0.c
> index 4bbb0b8000..a494eea074 100644
> --- a/testsuites/unit/ts-unit-no-clock-0.c
> +++ b/testsuites/unit/ts-unit-no-clock-0.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesUnitNoClock0 spec:/testsuites/unit-no-clock-0
> - * @ingroup RTEMSTestSuites
> + * @ingroup RTEMSTestSuitesUnit
> * @brief This general purpose unit test suite provides enough resources to run
> * basic tests without a Clock Driver for all specified managers and
> diff --git a/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c b/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
> index dd1bae545c..51dd22fc1d 100644
> --- a/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
> +++ b/testsuites/validation/ts-fatal-boot-processor-not-assigned-to-scheduler.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesFatalBootProcessorNotAssignedToScheduler \
> * spec:/testsuites/fatal-boot-processor-not-assigned-to-scheduler
> + * @ingroup RTEMSTestSuitesValidation
> * @brief This validation test suite uses an application configuration which
> * triggers a fatal error during system initialization.
> diff --git a/testsuites/validation/ts-fatal-idle-thread-create-failed.c b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
> index d09a8aeaf9..1bbf06df00 100644
> --- a/testsuites/validation/ts-fatal-idle-thread-create-failed.c
> +++ b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesFatalIdleThreadCreateFailed \
> * spec:/testsuites/fatal-idle-thread-create-failed
> * @brief This validation test suite contains a test case which is triggered by
> * a fatal error during system initialization.
> diff --git a/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c b/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
> index f0689b286e..b5dd10c960 100644
> --- a/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
> +++ b/testsuites/validation/ts-fatal-idle-thread-stack-too-small.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesFatalIdleThreadStackTooSmall \
> * spec:/testsuites/fatal-idle-thread-stack-too-small
> * @brief This validation test suite contains a test case which triggers a
> * fatal error during system initialization.
> diff --git a/testsuites/validation/ts-fatal-init-task-construct-failed.c b/testsuites/validation/ts-fatal-init-task-construct-failed.c
> index c7ac50adc6..a2a1c8668e 100644
> --- a/testsuites/validation/ts-fatal-init-task-construct-failed.c
> +++ b/testsuites/validation/ts-fatal-init-task-construct-failed.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesFatalInitTaskConstructFailed \
> * spec:/testsuites/fatal-init-task-construct-failed
> diff --git a/testsuites/validation/ts-fatal-mandatory-processor-not-present.c b/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
> index c4a4f84b40..855b67a7d6 100644
> --- a/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
> +++ b/testsuites/validation/ts-fatal-mandatory-processor-not-present.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesFatalMandatoryProcessorNotPresent \
> * spec:/testsuites/fatal-mandatory-processor-not-present
> diff --git a/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c b/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
> index 590af0249f..fe86e34bd0 100644
> --- a/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
> +++ b/testsuites/validation/ts-fatal-scheduler-requires-exactly-one-processor.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesFatalSchedulerRequiresExactlyOneProcessor \
> * spec:/testsuites/fatal-scheduler-requires-exactly-one-processor
> diff --git a/testsuites/validation/ts-fatal-smp.c b/testsuites/validation/ts-fatal-smp.c
> index 8f4c20b0d8..d1455a5148 100644
> --- a/testsuites/validation/ts-fatal-smp.c
> +++ b/testsuites/validation/ts-fatal-smp.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesFatalSmp spec:/testsuites/fatal-smp
> * SMP-specific fatal errors.
> diff --git a/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c b/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
> index b65afae5c2..38ee0f180d 100644
> --- a/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
> +++ b/testsuites/validation/ts-fatal-start-of-mandatory-processor-failed.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesFatalStartOfMandatoryProcessorFailed \
> * spec:/testsuites/fatal-start-of-mandatory-processor-failed
> diff --git a/testsuites/validation/ts-fatal-start-on-not-online-processor.c b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
> index 1630952234..765ae2d8d8 100644
> --- a/testsuites/validation/ts-fatal-start-on-not-online-processor.c
> +++ b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesFatalStartOnNotOnlineProcessor \
> * spec:/testsuites/fatal-start-on-not-online-processor
> diff --git a/testsuites/validation/ts-fatal-too-large-tls-size.c b/testsuites/validation/ts-fatal-too-large-tls-size.c
> index 7b3e06f92a..3687f9a234 100644
> --- a/testsuites/validation/ts-fatal-too-large-tls-size.c
> +++ b/testsuites/validation/ts-fatal-too-large-tls-size.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesFatalTooLargeTlsSize \
> * spec:/testsuites/fatal-too-large-tls-size
> diff --git a/testsuites/validation/ts-performance-no-clock-0.c b/testsuites/validation/ts-performance-no-clock-0.c
> index ecff6395ab..1cbb258413 100644
> --- a/testsuites/validation/ts-performance-no-clock-0.c
> +++ b/testsuites/validation/ts-performance-no-clock-0.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesPerformanceNoClock0 \
> * spec:/testsuites/performance-no-clock-0
> + * @ingroup RTEMSTestSuitesPerformance
> * @brief This general purpose performance test suite provides enough resources
> * to run basic performance tests for all specified managers and functions.
> diff --git a/testsuites/validation/ts-terminate.c b/testsuites/validation/ts-terminate.c
> index 95a6fed64c..dc9c953472 100644
> --- a/testsuites/validation/ts-terminate.c
> +++ b/testsuites/validation/ts-terminate.c
> @@ -59,7 +59,7 @@
> * @defgroup TestsuitesTerminate spec:/testsuites/terminate
> * @brief This validation test suite contains a test case for the system
> * termination procedure.
> diff --git a/testsuites/validation/ts-userext.c b/testsuites/validation/ts-userext.c
> index 7d2c190cb1..595f37a2a6 100644
> --- a/testsuites/validation/ts-userext.c
> +++ b/testsuites/validation/ts-userext.c
> @@ -59,7 +59,7 @@
> * @defgroup TestsuitesUserext spec:/testsuites/userext
> * @brief This validation test suite contains a test cases related to the
> * invocation of user extensions.
> diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
> index dda79c4427..cca15c7c6d 100644
> --- a/testsuites/validation/ts-validation-0.c
> +++ b/testsuites/validation/ts-validation-0.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidation0 spec:/testsuites/validation-0
> * @brief This general purpose validation test suite provides enough resources
> * to run basic tests for all specified managers and functions.
> diff --git a/testsuites/validation/ts-validation-1.c b/testsuites/validation/ts-validation-1.c
> index f1a67e16a3..0ded0a18be 100644
> --- a/testsuites/validation/ts-validation-1.c
> +++ b/testsuites/validation/ts-validation-1.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidation1 spec:/testsuites/validation-1
> diff --git a/testsuites/validation/ts-validation-acfg-0.c b/testsuites/validation/ts-validation-acfg-0.c
> index 9fe6793231..3c033bbecb 100644
> --- a/testsuites/validation/ts-validation-acfg-0.c
> +++ b/testsuites/validation/ts-validation-acfg-0.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesValidationAcfg0 spec:/testsuites/validation-acfg-0
> * @brief This validation test suite is used to validate the default value of
> * application configuration options taking the optional BSP provided
> diff --git a/testsuites/validation/ts-validation-acfg-1.c b/testsuites/validation/ts-validation-acfg-1.c
> index 2696d789be..92c2e90f83 100644
> --- a/testsuites/validation/ts-validation-acfg-1.c
> +++ b/testsuites/validation/ts-validation-acfg-1.c
> @@ -61,7 +61,7 @@
> * @defgroup TestsuitesValidationAcfg1 spec:/testsuites/validation-acfg-1
> * application configuration options where all optional BSP provided settings
> diff --git a/testsuites/validation/ts-validation-cache.c b/testsuites/validation/ts-validation-cache.c
> index 352341ed80..1ea4130597 100644
> --- a/testsuites/validation/ts-validation-cache.c
> +++ b/testsuites/validation/ts-validation-cache.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationCache spec:/testsuites/validation-cache
> * @brief This validation test suite provides enough resources to run tests for
> * the directives of the @ref RTEMSAPIClassicCache.
> diff --git a/testsuites/validation/ts-validation-intr.c b/testsuites/validation/ts-validation-intr.c
> index 10bb19a840..4b1074fc4a 100644
> --- a/testsuites/validation/ts-validation-intr.c
> +++ b/testsuites/validation/ts-validation-intr.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationIntr spec:/testsuites/validation-intr
> * the interrupt controller related directives of the @ref
> diff --git a/testsuites/validation/ts-validation-io-kernel.c b/testsuites/validation/ts-validation-io-kernel.c
> index 84ba9ef441..6153e8ab18 100644
> --- a/testsuites/validation/ts-validation-io-kernel.c
> +++ b/testsuites/validation/ts-validation-io-kernel.c
> @@ -64,7 +64,7 @@
> * @defgroup TestsuitesValidationIoKernel spec:/testsuites/validation-io-kernel
> * @brief This validation test suite contains test cases which test the kernel
> * character input/output device provided by the BSP before the system
> diff --git a/testsuites/validation/ts-validation-no-clock-0.c b/testsuites/validation/ts-validation-no-clock-0.c
> index 820dadcd25..b6e5989727 100644
> --- a/testsuites/validation/ts-validation-no-clock-0.c
> +++ b/testsuites/validation/ts-validation-no-clock-0.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationNoClock0 \
> * spec:/testsuites/validation-no-clock-0
> * to run basic tests without a Clock Driver for all specified managers and
> diff --git a/testsuites/validation/ts-validation-non-smp.c b/testsuites/validation/ts-validation-non-smp.c
> index 9a4a9061ae..9c26d9b286 100644
> --- a/testsuites/validation/ts-validation-non-smp.c
> +++ b/testsuites/validation/ts-validation-non-smp.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationNonSmp spec:/testsuites/validation-non-smp
> * @brief This test suite for non-SMP test cases provides enough resources to
> * run basic tests for all specified managers and functions.
> diff --git a/testsuites/validation/ts-validation-one-cpu-0.c b/testsuites/validation/ts-validation-one-cpu-0.c
> index f45e8a4905..8956b66732 100644
> --- a/testsuites/validation/ts-validation-one-cpu-0.c
> +++ b/testsuites/validation/ts-validation-one-cpu-0.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationOneCpu0 spec:/testsuites/validation-one-cpu-0
> * to run basic tests with exactly one processor and without a Clock Driver.
> diff --git a/testsuites/validation/ts-validation-one-cpu-1.c b/testsuites/validation/ts-validation-one-cpu-1.c
> index 39852cc510..953f067037 100644
> --- a/testsuites/validation/ts-validation-one-cpu-1.c
> +++ b/testsuites/validation/ts-validation-one-cpu-1.c
> @@ -59,7 +59,7 @@
> * @defgroup TestsuitesValidationOneCpu1 spec:/testsuites/validation-one-cpu-1
> diff --git a/testsuites/validation/ts-validation-smp-one-cpu-0.c b/testsuites/validation/ts-validation-smp-one-cpu-0.c
> index a52477b507..ddd47bfee2 100644
> --- a/testsuites/validation/ts-validation-smp-one-cpu-0.c
> +++ b/testsuites/validation/ts-validation-smp-one-cpu-0.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationSmpOneCpu0 \
> * spec:/testsuites/validation-smp-one-cpu-0
> * to run basic tests for all specified managers and functions in a
> diff --git a/testsuites/validation/ts-validation-smp-only-0.c b/testsuites/validation/ts-validation-smp-only-0.c
> index 5f65ac7af1..e4eaa3cf0c 100644
> --- a/testsuites/validation/ts-validation-smp-only-0.c
> +++ b/testsuites/validation/ts-validation-smp-only-0.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationSmpOnly0 \
> * spec:/testsuites/validation-smp-only-0
> * @brief This test suite for SMP-only test cases provides enough resources to
> diff --git a/testsuites/validation/ts-validation-smp-only-2.c b/testsuites/validation/ts-validation-smp-only-2.c
> index e8897adfaf..0e1b0c1310 100644
> --- a/testsuites/validation/ts-validation-smp-only-2.c
> +++ b/testsuites/validation/ts-validation-smp-only-2.c
> @@ -60,7 +60,7 @@
> * @defgroup TestsuitesValidationSmpOnly2 \
> * spec:/testsuites/validation-smp-only-2
> * @brief This SMP-only test suite validates the clustered scheduler
> * configuration through an application configuration with a processor
> diff --git a/testsuites/validation/ts-validation-timecounter-0.c b/testsuites/validation/ts-validation-timecounter-0.c
> index 3ce34342fb..07e638160a 100644
> --- a/testsuites/validation/ts-validation-timecounter-0.c
> +++ b/testsuites/validation/ts-validation-timecounter-0.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationTimecounter0 \
> * spec:/testsuites/validation-timecounter-0
> * @brief This validation test suite is intended test cases related to the
> * installation of timecouters. The Clock Driver is disabled.
> diff --git a/testsuites/validation/ts-validation-timecounter-1.c b/testsuites/validation/ts-validation-timecounter-1.c
> index 80440d2e07..aa5873bdb8 100644
> --- a/testsuites/validation/ts-validation-timecounter-1.c
> +++ b/testsuites/validation/ts-validation-timecounter-1.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationTimecounter1 \
> * spec:/testsuites/validation-timecounter-1
> * @brief This validation test suite is intended test cases related to the use
> * of timecouters. The Clock Driver is enabled.
> diff --git a/testsuites/validation/ts-validation-timecounter-smp-0.c b/testsuites/validation/ts-validation-timecounter-smp-0.c
> index 3c2b3c218c..aef567ab6a 100644
> --- a/testsuites/validation/ts-validation-timecounter-smp-0.c
> +++ b/testsuites/validation/ts-validation-timecounter-smp-0.c
> @@ -58,7 +58,7 @@
> * @defgroup TestsuitesValidationTimecounterSmp0 \
> * spec:/testsuites/validation-timecounter-smp-0
> * of timecouters. The Clock Driver is disabled.
> diff --git a/testsuites/validation/ts-validation-tls-0.c b/testsuites/validation/ts-validation-tls-0.c
> index 463a460f2e..1016bfccb4 100644
> --- a/testsuites/validation/ts-validation-tls-0.c
> +++ b/testsuites/validation/ts-validation-tls-0.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationTls0 spec:/testsuites/validation-tls-0
> * @brief This validation test suite contains test cases related to the
> * thread-local storage support.
> diff --git a/testsuites/validation/ts-validation-tls-1.c b/testsuites/validation/ts-validation-tls-1.c
> index 6a4dbf587b..ea46c4f20e 100644
> --- a/testsuites/validation/ts-validation-tls-1.c
> +++ b/testsuites/validation/ts-validation-tls-1.c
> @@ -57,7 +57,7 @@
> * @defgroup TestsuitesValidationTls1 spec:/testsuites/validation-tls-1
