[PATCH 2/2] bsps/riscv: add riscv/kendrytek210 BSP variant
Mon Mar 13 15:04:12 UTC 2023
On Thu, Mar 9, 2023 at 8:48 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> This patch set adds support for the Kendryte K210 RISC-V BSP variant.
> The SoC uses existing PLIC, Timer, and console UART. It only needs
> SoC specific initalization and an embedded device tree binary similar
> to the polarfire SoC BSP.
> Updates #4876
>  bsps/riscv/riscv/config/kendrytek210.cfg      |   9 +
>  bsps/riscv/riscv/console/console-config.c     |  10 +-
>  bsps/riscv/riscv/console/fe310-uart.c         |   2 +-
>  bsps/riscv/riscv/dts/kendryte-k210.dts        | 216 ++++++++++++
>  bsps/riscv/riscv/include/bsp.h                |   4 +
>  bsps/riscv/riscv/include/bsp/k210.h           |  91 +++++
>  .../riscv/include/bsp/kendryte-k210-dtb.h     | 315 ++++++++++++++++++
>  bsps/riscv/riscv/include/bsp/riscv.h          |   4 +
>  bsps/riscv/riscv/start/bspstart.c             |  42 +++
>  9 files changed, 687 insertions(+), 6 deletions(-)
>  create mode 100644 bsps/riscv/riscv/config/kendrytek210.cfg
>  create mode 100644 bsps/riscv/riscv/dts/kendryte-k210.dts
>  create mode 100644 bsps/riscv/riscv/include/bsp/k210.h
>  create mode 100644 bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
> diff --git a/bsps/riscv/riscv/config/kendrytek210.cfg b/bsps/riscv/riscv/config/kendrytek210.cfg
> new file mode 100644
> index 0000000000..b04e78b0e9
> --- /dev/null
> +++ b/bsps/riscv/riscv/config/kendrytek210.cfg
> @@ -0,0 +1,9 @@
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU = riscv
> +CPU_CFLAGS = -march=rv64imafdc -mabi=lp64d -mcmodel=medany
> +LDFLAGS = -Wl,--gc-sections
> +CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
> diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> index 4916191e0b..72743fe9d5 100644
> --- a/bsps/riscv/riscv/console/console-config.c
> +++ b/bsps/riscv/riscv/console/console-config.c
> @@ -55,7 +55,7 @@
>  #include <libfdt.h>
>  #include <string.h>
> -#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
> +#if RISCV_ENABLE_SIFIVE_UART_SUPPORT != 0
>  #include <bsp/fe310-uart.h>
>  static fe310_uart_context fe310_uart_instance;
>  #endif
> @@ -239,7 +239,7 @@ static void riscv_console_probe(void)
>  #endif
>      if (fdt_stringlist_contains(compat, compat_len, "sifive,uart0")) {
>        fe310_uart_context *ctx;
> @@ -255,7 +255,7 @@ static void riscv_console_probe(void)
>          riscv_console.getchar = fe310_uart_read;
> -      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
> +      rtems_termios_device_context_initialize(&ctx->base, "SIFIVEUART");
>  #endif
> @@ -290,7 +290,7 @@ rtems_status_code console_initialize(
>    size_t i;
>  #endif
>    char fe310_path[] = "/dev/ttyS0";
>  #endif
> @@ -326,7 +326,7 @@ rtems_status_code console_initialize(
>  #endif
>    ctx = &fe310_uart_instance;
>    rtems_termios_device_install(
>      fe310_path,
> diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
> index 506521add0..ddabcff4c8 100644
> --- a/bsps/riscv/riscv/console/fe310-uart.c
> +++ b/bsps/riscv/riscv/console/fe310-uart.c
> @@ -53,7 +53,7 @@ static void fe310_uart_write (
>    fe310_uart_context * ctx = (fe310_uart_context*) base;
>    size_t i;
> -  ctx->regs->div = riscv_get_core_frequency() / 115200 - 1;
> +  ctx->regs->div = (riscv_get_core_frequency() / 115200 - 1) & 0xFFFF;
>    ctx->regs->txctrl |= 1;
>    ctx->regs->rxctrl |= 1;
> diff --git a/bsps/riscv/riscv/dts/kendryte-k210.dts b/bsps/riscv/riscv/dts/kendryte-k210.dts
> index 0000000000..379aaf01a3
> --- /dev/null
> +++ b/bsps/riscv/riscv/dts/kendryte-k210.dts
> @@ -0,0 +1,216 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * Copyright (C) Alan Cudmore
> + * Copyright (C) Padmarao Begari
> + * Copyright (C) 2022 Microchip Technology Inc.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *     notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *     notice, this list of conditions and the following disclaimer in the
> + *     documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + /* This is a device tree for the Kendryte K210 SoC. It is a simplified tree
> +  * to support the current RTEMS BSP, but it is not sufficient enough for
> +  * full linux or u-boot support.
> +  * The file structure is based on the device tree source for the
> +  * Polarfire SoC created by Padmaro Begari. The K210 device trees from
> +  * u-boot were originally used to bring up the RTEMS BSP and were
> +  * referenced to develop this file.
> +/dts-v1/;
> +        /* 32 bit address bus - upper 32 bits are ignored */
> +       #address-cells = <1>;
> +       #size-cells = <1>;
> +       model = "Kendtryte K210 generic";
> +       compatible = "canaan,kendryte-k210";
> +       aliases {
> +               serial0 = &uarths0;
> +               serial1 = &uart1;
> +               /* serial2 = &uart2; */
> +               /* serial3 = &uart3; */
> +       chosen {
> +               stdout-path = "serial0";
> +       cpus {
> +               #size-cells = <0>;
> +               timebase-frequency = <7800000>;
> +               cpu0: cpu at 0 {
> +                       compatible = "canaan,k210", "riscv";
> +                       device_type = "cpu";
> +                       reg = <0>;
> +                       riscv,isa = "rv64imafdc";
> +                       i-cache-block-size = <64>;
> +                       i-cache-size = <0x8000>;
> +                       d-cache-block-size = <64>;
> +                       d-cache-size = <0x8000>;
> +                       cpu0_intc: interrupt-controller {
> +                               #interrupt-cells = <1>;
> +                               compatible = "riscv,cpu-intc";
> +                               interrupt-controller;
> +               cpu1: cpu at 1 {
> +                       reg = <1>;
> +                       cpu1_intc: interrupt-controller {
> +       clocks {
> +                in0: oscillator {
> +                       compatible = "fixed-clock";
> +                       #clock-cells = <0>;
> +                       clock-frequency = <26000000>;
> +       sram: memory at 80000000 {
> +               device_type = "memory";
> +                compatible = "canaan,k210-sram";
> +               reg = <0x80000000 0x400000>,
> +                     <0x80400000 0x200000>,
> +                     <0x80600000 0x200000>;
> +                reg-names = "sram0",
> +                            "sram1",
> +                            "aisram";
> +       soc: soc {
> +               compatible = "simple-bus";
> +               ranges;
> +                interrupt-parent = <&plic0>;
> +                rom0: nvmem at 1000 {
> +                         reg = <0x1000 0x1000>;
> +                         read-only;
> +               clint0: timer at 2000000 {
> +                       compatible = "riscv,clint0","sifive,clint0";
> +                       reg = <0x2000000 0xC000>;
> +                       interrupts-extended = <&cpu0_intc 3>,<&cpu0_intc 7>,
> +                                             <&cpu1_intc 3>,<&cpu1_intc 7>;
> +               plic0: interrupt-controller at c000000 {
> +                       #address-cells = <0>;
> +                       compatible = "riscv,plic0","sifive,plic-1.0.0";
> +                       reg = <0xC000000 0x4000000>;
> +                       riscv,ndev = <65>;
> +                               <&cpu0_intc 11>, <&cpu0_intc 9>,
> +                               <&cpu1_intc 11>, <&cpu1_intc 9>;
> +               uarths0: serial at 38000000 {
> +                       compatible = "canaan,k210-uarths","sifive,uart0";
> +                       reg = <0x38000000 0x1000>;
> +                       interrupts = <33>;
> +                       clocks = <&sysclk 0>;
> +                /* apb0 has gpio1 and additional uarts */
> +               apb0: bus at 50200000 {
> +                       compatible = "simple-pm-bus";
> +                       ranges;
> +                       clocks = <&sysclk 8>;
> +                       uart1: serial at 50210000 {
> +                               compatible = "snps,dw-apb-uart";
> +                               reg = <0x50210000 0x100>;
> +                               interrupts = <11>;
> +                               clocks = <&sysclk 30>,
> +                                        <&sysclk 8>;
> +                               clock-namees = "baudclk", "abp_pclk";
> +                               resets = <&sysrst 16>;
> +                               reg-io-width = <4>;
> +                               reg-shift = <2>;
> +                               dcd-override;
> +                               dsr-override;
> +                               cts-override;
> +                               ri-override;
> +                apb1: bus at 50400000 {
> +                       ranges;
> +                       clocks = <&sysclk 9>;
> +                       sysctl: syscon at 50440000 {
> +                               compatible = "canaan,k210-sysctl","syscon",
> +                                            "simple-mfd";
> +                               reg = <0x50440000 0x100>;
> +                               clock-names = "pclk";
> +                               sysclk: clock-controller {
> +                                       #clock-cells = <1>;
> +                                       compatible = "canaan,k210-rst";
> +                                       clock = <&in0>;
> +                               sysrst: reset-coontroller {
> +                                       #reset-cells = <1>;
> +                               reboot: syscon-reboot {
> +                                       compatible = "syscon-reboot";
> +                                       regmap = <&sysctl>;
> +                                       offset = <48>;
> +                                       mask = <1>;
> +                                       value = <1>;
> diff --git a/bsps/riscv/riscv/include/bsp.h b/bsps/riscv/riscv/include/bsp.h
> index 911b85f4a3..c33de42aa7 100644
> --- a/bsps/riscv/riscv/include/bsp.h
> +++ b/bsps/riscv/riscv/include/bsp.h
> @@ -60,6 +60,10 @@
>  #include <rtems/devnull.h>
> +#if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0
> +   #include <bsp/k210.h>
> +#endif
>  #ifdef __cplusplus
>  extern "C" {
>  #endif
> diff --git a/bsps/riscv/riscv/include/bsp/k210.h b/bsps/riscv/riscv/include/bsp/k210.h
> index 0000000000..558502cd11
> --- /dev/null
> +++ b/bsps/riscv/riscv/include/bsp/k210.h
> @@ -0,0 +1,91 @@
> + * @file
> + * @ingroup k210_regs
> + * @brief k210 RISC-V CPU defines.
> + *  Copyright (c) 2022 Alan Cudmore
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE
Please use the 2-BSD boilerplate consistent with the SPDX above.
> +#ifndef LIBBSP_RISCV_RISCV_K210_H
> +#define LIBBSP_RISCV_RISCV_K210_H
> +#include <bspopts.h>
> +#include <stdint.h>
> +#include <bsp/utility.h>
> + * @defgroup K210 RISC V Register Definitions
> + * @ingroup RTEMSBSPsriscv
> + * @brief Register Definitions
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* For PLL / Clocks */
> +#define K210_SYSCTL_BASE     0x50440000
> +#define PLL_CLK_R(n)         (n & 0x00000F)
Usually good practice to put parens around CPP macro arguments, e.g.,
((n) & 0x00000F)
> +#define PLL_CLK_F(n)         ((n & 0x0003F0) >> 4)
> +#define PLL_CLK_OD(n)        ((n & 0x003C00) >> 10)
> +#define CLKSEL0_ACLK_SEL(n)  (n & 0x00000001)
> +typedef struct {
> +  uint32_t git_id;
> +  uint32_t clk_freq;
> +  uint32_t pll0;
> +  uint32_t pll1;
> +  uint32_t pll2;
> +  uint32_t resv5;
> +  uint32_t pll_lock;
> +  uint32_t rom_error;
> +  uint32_t clk_sel0;
> +  uint32_t clk_sel1;
> +  uint32_t clk_en_cent;
> +  uint32_t clk_en_peri;
> +  uint32_t soft_reset;
> +  uint32_t peri_reset;
> +  uint32_t clk_th0;
> +  uint32_t clk_th1;
> +  uint32_t clk_th2;
> +  uint32_t clk_th3;
> +  uint32_t clk_th4;
> +  uint32_t clk_th5;
> +  uint32_t clk_th6;
> +  uint32_t misc;
> +  uint32_t peri;
> +  uint32_t spi_sleep;
> +  uint32_t reset_status;
> +  uint32_t dma_sel0;
> +  uint32_t dma_sel1;
> +  uint32_t power_sel;
> +  uint32_t resv28;
> +  uint32_t resv29;
> +  uint32_t resv30;
> +  uint32_t resv31;
> +} k210_sysctl_t;
> +#ifdef __cplusplus
> +#endif
> +#endif /* LIBBSP_RISCV_RISCV_K210_H */
> diff --git a/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
> index 0000000000..ad13aefdbf
> --- /dev/null
> +++ b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
> @@ -0,0 +1,315 @@
> + *  Declarations for C structure representing binary file system.dtb
> + *  WARNING: Automatically generated -- do not edit!
> + * are met:
> +#ifndef __kendryte_k210_dtb_h
> +#define __kendryte_k210_dtb_h
> +#include <rtems/score/basedefs.h>
> +#include <sys/types.h>
> +const unsigned char system_dtb[] RTEMS_ALIGNED(8) = {
> +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x0c, 0xa7, 0x00, 0x00, 0x00, 0x38,
> +  0x00, 0x00, 0x0a, 0xb4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf3,
> +  0x00, 0x00, 0x0a, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x1b,
> +  0x4b, 0x65, 0x6e, 0x64, 0x74, 0x72, 0x79, 0x74, 0x65, 0x20, 0x4b, 0x32,
> +  0x31, 0x30, 0x20, 0x67, 0x65, 0x6e, 0x65, 0x72, 0x69, 0x63, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x21,
> +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x65, 0x6e, 0x64, 0x72,
> +  0x79, 0x74, 0x65, 0x2d, 0x6b, 0x32, 0x31, 0x30, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x2c,
> +  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40,
> +  0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x34,
> +  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32,
> +  0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c,
> +  0x40, 0x35, 0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x6f, 0x73,
> +  0x65, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x00, 0x3c, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x73,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x48,
> +  0x00, 0x77, 0x04, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40,
> +  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12,
> +  0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b,
> +  0x32, 0x31, 0x30, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b,
> +  0x63, 0x70, 0x75, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34,
> +  0x69, 0x6d, 0x61, 0x66, 0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88,
> +  0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x95, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00,
> +  0x00, 0x00, 0x00, 0x01, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
> +  0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72,
> +  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
> +  0x76, 0x2c, 0x63, 0x70, 0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40, 0x31, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x21,
> +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x00,
> +  0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b, 0x63, 0x70, 0x75, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x67,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
> +  0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34, 0x69, 0x6d, 0x61, 0x66,
> +  0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x80, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x95,
> +  0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
> +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0f,
> +  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x63, 0x70,
> +  0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x73, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x01, 0x6f, 0x73, 0x63, 0x69, 0x6c, 0x6c, 0x61, 0x74,
> +  0x6f, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
> +  0x00, 0x00, 0x00, 0x21, 0x66, 0x69, 0x78, 0x65, 0x64, 0x2d, 0x63, 0x6c,
> +  0x6f, 0x63, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0xe3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x8c, 0xba, 0x80,
> +  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x6d, 0x65, 0x6d, 0x6f, 0x72, 0x79, 0x40, 0x38,
> +  0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x5b, 0x6d, 0x65, 0x6d, 0x6f,
> +  0x72, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x11,
> +  0x32, 0x31, 0x30, 0x2d, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x67,
> +  0x80, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x80, 0x40, 0x00, 0x00,
> +  0x00, 0x20, 0x00, 0x00, 0x80, 0x60, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x01, 0x00,
> +  0x73, 0x72, 0x61, 0x6d, 0x30, 0x00, 0x73, 0x72, 0x61, 0x6d, 0x31, 0x00,
> +  0x61, 0x69, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x73, 0x6f, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f,
> +  0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62,
> +  0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x01, 0x11, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
> +  0x6e, 0x76, 0x6d, 0x65, 0x6d, 0x40, 0x31, 0x30, 0x30, 0x30, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67,
> +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x22, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x74, 0x69, 0x6d, 0x65, 0x72, 0x40, 0x32, 0x30,
> +  0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
> +  0x76, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x73, 0x69, 0x66,
> +  0x69, 0x76, 0x65, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x00,
> +  0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x07,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x63, 0x30, 0x30,
> +  0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1e,
> +  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x70, 0x6c,
> +  0x69, 0x63, 0x30, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x70,
> +  0x6c, 0x69, 0x63, 0x2d, 0x31, 0x2e, 0x30, 0x2e, 0x30, 0x00, 0x00, 0x00,
> +  0x0c, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x41,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69,
> +  0x61, 0x6c, 0x40, 0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21,
> +  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d,
> +  0x75, 0x61, 0x72, 0x74, 0x68, 0x73, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76,
> +  0x65, 0x2c, 0x75, 0x61, 0x72, 0x74, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x38, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x01, 0x4b, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32, 0x30, 0x30, 0x30, 0x30, 0x30,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21,
> +  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75,
> +  0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x35,
> +  0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x21, 0x73, 0x6e, 0x70, 0x73,
> +  0x2c, 0x64, 0x77, 0x2d, 0x61, 0x70, 0x62, 0x2d, 0x75, 0x61, 0x72, 0x74,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x00, 0x67, 0x50, 0x21, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x4b,
> +  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
> +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1e,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x01, 0x5d, 0x62, 0x61, 0x75, 0x64,
> +  0x63, 0x6c, 0x6b, 0x00, 0x61, 0x62, 0x70, 0x5f, 0x70, 0x63, 0x6c, 0x6b,
> +  0x00, 0x00, 0x01, 0x6a, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x10,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x71,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x01, 0x7e, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x88, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x95, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xa2, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xaf, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x62, 0x75, 0x73, 0x40,
> +  0x35, 0x30, 0x34, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70,
> +  0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x0a,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01,
> +  0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x40, 0x35, 0x30, 0x34, 0x34, 0x30,
> +  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25,
> +  0x32, 0x31, 0x30, 0x2d, 0x73, 0x79, 0x73, 0x63, 0x74, 0x6c, 0x00, 0x73,
> +  0x79, 0x73, 0x63, 0x6f, 0x6e, 0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65,
> +  0x2d, 0x6d, 0x66, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x50, 0x44, 0x00, 0x00,
> +  0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x01, 0xbb,
> +  0x70, 0x63, 0x6c, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x07,
> +  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x6f,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe3,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
> +  0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xc7, 0x00, 0x00, 0x00, 0x06,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x72, 0x65, 0x73, 0x65, 0x74, 0x2d, 0x63, 0x6f, 0x6f, 0x6e, 0x74, 0x72,
> +  0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61,
> +  0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xcd,
> +  0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x01, 0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x2d, 0x72,
> +  0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x79, 0x73, 0x63,
> +  0x6f, 0x6e, 0x2d, 0x72, 0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xda,
> +  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x01, 0xe1, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xe8, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xed,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
> +  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65,
> +  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c,
> +  0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00,
> +  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00, 0x73, 0x65, 0x72, 0x69,
> +  0x61, 0x6c, 0x31, 0x00, 0x73, 0x74, 0x64, 0x6f, 0x75, 0x74, 0x2d, 0x70,
> +  0x61, 0x74, 0x68, 0x00, 0x74, 0x69, 0x6d, 0x65, 0x62, 0x61, 0x73, 0x65,
> +  0x2d, 0x66, 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x64,
> +  0x65, 0x76, 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72,
> +  0x65, 0x67, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x69, 0x73, 0x61,
> +  0x00, 0x69, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f,
> +  0x63, 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x69, 0x2d, 0x63, 0x61,
> +  0x63, 0x68, 0x65, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63,
> +  0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x73,
> +  0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d,
> +  0x73, 0x69, 0x7a, 0x65, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
> +  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x69, 0x6e,
> +  0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74,
> +  0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64,
> +  0x6c, 0x65, 0x00, 0x23, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x65,
> +  0x6c, 0x6c, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72,
> +  0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x72, 0x65, 0x67, 0x2d,
> +  0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
> +  0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70,
> +  0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x72, 0x65, 0x61, 0x64, 0x2d, 0x6f,
> +  0x6e, 0x6c, 0x79, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
> +  0x74, 0x73, 0x2d, 0x65, 0x78, 0x74, 0x65, 0x6e, 0x64, 0x65, 0x64, 0x00,
> +  0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x6e, 0x64, 0x65, 0x76, 0x00, 0x69,
> +  0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x63, 0x6c,
> +  0x6f, 0x63, 0x6b, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e,
> +  0x61, 0x6d, 0x65, 0x65, 0x73, 0x00, 0x72, 0x65, 0x73, 0x65, 0x74, 0x73,
> +  0x00, 0x72, 0x65, 0x67, 0x2d, 0x69, 0x6f, 0x2d, 0x77, 0x69, 0x64, 0x74,
> +  0x68, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73, 0x68, 0x69, 0x66, 0x74, 0x00,
> +  0x64, 0x63, 0x64, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64, 0x65,
> +  0x00, 0x64, 0x73, 0x72, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64,
> +  0x65, 0x00, 0x63, 0x74, 0x73, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
> +  0x64, 0x65, 0x00, 0x72, 0x69, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
> +  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x61, 0x6d,
> +  0x65, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x00, 0x23, 0x72, 0x65,
> +  0x73, 0x65, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
> +  0x67, 0x6d, 0x61, 0x70, 0x00, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00,
> +  0x6d, 0x61, 0x73, 0x6b, 0x00, 0x76, 0x61, 0x6c, 0x75, 0x65, 0x00,
> +const size_t system_dtb_size = sizeof(system_dtb);
> +#endif /* __kendryte_k210_dtb_h */
> diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
> index bbaaa246c1..d294f1ae58 100644
> --- a/bsps/riscv/riscv/include/bsp/riscv.h
> +++ b/bsps/riscv/riscv/include/bsp/riscv.h
> @@ -56,6 +56,10 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
>  void htif_poweroff(void);
>  #endif
> +uint32_t k210_get_frequency(void);
> +#endif
>  #ifdef __cplusplus
>  #endif
> diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
> index 30d479ce88..a0b6e683f6 100644
> --- a/bsps/riscv/riscv/start/bspstart.c
> +++ b/bsps/riscv/riscv/start/bspstart.c
> @@ -201,6 +201,14 @@ static uint32_t get_core_frequency(void)
>      return fdt32_to_cpu(*val);
>  #endif
> +  uint32_t cpu_clock;
> +  cpu_clock = k210_get_frequency();
> +  return cpu_clock;
> +#endif
>    return 0;
This code is unreachable if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0.
> @@ -215,6 +223,40 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
>    return RISCV_INTERRUPT_VECTOR_EXTERNAL(intr[0]);
> +  k210_sysctl_t *sysctl = (k210_sysctl_t *)K210_SYSCTL_BASE;
> +  uint32_t cpu_clock = 0;
> +  uint32_t pll0, nr, nf, od;
> +  uint32_t node;
> +  const char *fdt;
> +  const fdt32_t *val;
> +  int len;
> +  fdt = bsp_fdt_get();
> +  node = fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
> +  val = fdt_getprop(fdt, node, "clock-frequency", &len);
> +  if (val != NULL && len == 4) {
> +    clk_freq = fdt32_to_cpu(*val);
> +    if (CLKSEL0_ACLK_SEL(sysctl->clk_sel0) == 1) {
> +       /* PLL0 selected */
> +       pll0 = sysctl->pll0;
> +       nr = PLL_CLK_R(pll0) + 1;
> +       nf = PLL_CLK_F(pll0) + 1;
> +       od = PLL_CLK_OD(pll0) + 1;
> +       cpu_clock = (clk_freq / nr * nf / od)/2;
> +    } else {
> +       /* OSC selected */
> +       cpu_clock = clk_freq;
> +  return cpu_clock;
> +#endif
>  void bsp_start(void)
>    riscv_find_harts();
> 2.25.1
> devel mailing list
> devel at rtems.org
