[PATCH 1/2] spec: add riscv Kendryte K210 variant options
Gedare Bloom
gedare at rtems.org
Mon Mar 13 16:14:31 UTC 2023
On Mon, Mar 13, 2023 at 9:31 AM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Good idea. With the number of changes, do you think one commit for the spec/build options and one for the code is sufficient?
I'm fine with 2 commits, but you might also consider separating the
addition of the generated file (dtb) on its own as a separate step
from source code you wrote/imported.
> On Mon, Mar 13, 2023 at 10:55 AM Gedare Bloom <gedare at rtems.org> wrote:
>> I'm not 100% sure it matters, but I think the spec/build commit should
>> come after the source is added. This is a generally good approach
>> when integrating code vs build changes, so that you don't try to build
>> something that doesn't exist.
>> On Thu, Mar 9, 2023 at 8:48 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> > This patch includes the spec/build options for the riscv kendrytek210
>> > BSP variant. It includes options to allow the frdme310arty console
>> > UART to be used on multiple BSPS, device tree options, memory
>> > options, and other required options for the variant.
>> > spec/build/bsps/optdtb.yml | 4 +++-
>> > spec/build/bsps/optdtbheaderpath.yml | 2 ++
>> > spec/build/bsps/optfdtuboot.yml | 3 +++
>> > spec/build/bsps/riscv/optramsize.yml | 2 ++
>> > spec/build/bsps/riscv/riscv/abi.yml | 1 +
>> > .../bsps/riscv/riscv/bspkendrtyek210.yml | 19 ++++++++++++++++++
>> > spec/build/bsps/riscv/riscv/grp.yml | 4 ++++
>> > spec/build/bsps/riscv/riscv/obj.yml | 1 +
>> > .../bsps/riscv/riscv/optkendrytek210.yml | 18 +++++++++++++++++
>> > spec/build/bsps/riscv/riscv/optns16550max.yml | 4 +++-
>> > spec/build/bsps/riscv/riscv/optsifiveuart.yml | 20 +++++++++++++++++++
>> > spec/build/cpukit/optsmp.yml | 1 +
>> > 12 files changed, 77 insertions(+), 2 deletions(-)
>> > create mode 100644 spec/build/bsps/riscv/riscv/bspkendrtyek210.yml
>> > create mode 100644 spec/build/bsps/riscv/riscv/optkendrytek210.yml
>> > create mode 100644 spec/build/bsps/riscv/riscv/optsifiveuart.yml
>> > diff --git a/spec/build/bsps/optdtb.yml b/spec/build/bsps/optdtb.yml
>> > index 78fed67866..f775dc7750 100644
>> > --- a/spec/build/bsps/optdtb.yml
>> > +++ b/spec/build/bsps/optdtb.yml
>> > @@ -6,7 +6,9 @@ build-type: option
>> > copyrights:
>> > - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> > default:
>> > -- enabled-by: riscv/mpfs64imafdc
>> > +- enabled-by:
>> > + - riscv/mpfs64imafdc
>> > + - riscv/kendrytek210
>> > value: true
>> > - enabled-by: true
>> > value: false
>> > diff --git a/spec/build/bsps/optdtbheaderpath.yml b/spec/build/bsps/optdtbheaderpath.yml
>> > index 65573c4cb8..944c8e830e 100644
>> > --- a/spec/build/bsps/optdtbheaderpath.yml
>> > +++ b/spec/build/bsps/optdtbheaderpath.yml
>> > @@ -8,6 +8,8 @@ copyrights:
>> > default:
>> > value: bsp/mpfs-dtb.h
>> > +- enabled-by: riscv/kendrytek210
>> > + value: bsp/kendryte-k210-dtb.h
>> > - enabled-by: true
>> > value: false
>> > description: |
>> > diff --git a/spec/build/bsps/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
>> > index 8c53b8b799..9d91639dc6 100644
>> > --- a/spec/build/bsps/optfdtuboot.yml
>> > +++ b/spec/build/bsps/optfdtuboot.yml
>> > @@ -6,6 +6,9 @@ build-type: option
>> > copyrights:
>> > default:
>> > +- enabled-by:
>> > + value: false
>> > - enabled-by: true
>> > value: true
>> > description: |
>> > diff --git a/spec/build/bsps/riscv/optramsize.yml b/spec/build/bsps/riscv/optramsize.yml
>> > index be80c0f462..1fc407d1ea 100644
>> > --- a/spec/build/bsps/riscv/optramsize.yml
>> > +++ b/spec/build/bsps/riscv/optramsize.yml
>> > @@ -15,6 +15,8 @@ default:
>> > value: 0x10000000
>> > - enabled-by: riscv/griscv
>> > value: 0x01000000
>> > + value: 0x00600000
>> > - enabled-by: true
>> > value: 0x04000000
>> > description: ''
>> > diff --git a/spec/build/bsps/riscv/riscv/abi.yml b/spec/build/bsps/riscv/riscv/abi.yml
>> > index ab3046ee24..de23bdd795 100644
>> > --- a/spec/build/bsps/riscv/riscv/abi.yml
>> > +++ b/spec/build/bsps/riscv/riscv/abi.yml
>> > @@ -10,6 +10,7 @@ default:
>> > - enabled-by:
>> > - riscv/rv64imafdc
>> > value:
>> > - -march=rv64imafdc
>> > - -mabi=lp64d
>> > diff --git a/spec/build/bsps/riscv/riscv/bspkendrtyek210.yml b/spec/build/bsps/riscv/riscv/bspkendrtyek210.yml
>> > new file mode 100644
>> > index 0000000000..91c601979e
>> > --- /dev/null
>> > +++ b/spec/build/bsps/riscv/riscv/bspkendrtyek210.yml
>> > @@ -0,0 +1,19 @@
>> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> > +arch: riscv
>> > +bsp: kendrytek210
>> > +build-type: bsp
>> > +cflags: []
>> > +copyrights:
>> > +- Copyright (C) 2022 Alan Cudmore
>> > +cppflags: []
>> > +enabled-by: true
>> > +family: riscv
>> > +includes: []
>> > +install: []
>> > +links:
>> > +- role: build-dependency
>> > + uid: ../../opto2
>> > + uid: grp
>> > +source: []
>> > +type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
>> > index 713c15509a..a2ed4a1052 100644
>> > --- a/spec/build/bsps/riscv/riscv/grp.yml
>> > +++ b/spec/build/bsps/riscv/riscv/grp.yml
>> > @@ -50,10 +50,14 @@ links:
>> > uid: ../../optdtbheaderpath
>> > uid: optfrdme310arty
>> > + uid: optkendrytek210
>> > uid: opthtif
>> > uid: optmpfs
>> > + uid: optsifiveuart
>> > uid: optns16550max
>> > diff --git a/spec/build/bsps/riscv/riscv/obj.yml b/spec/build/bsps/riscv/riscv/obj.yml
>> > index 0ddeef828b..d28945fae4 100644
>> > --- a/spec/build/bsps/riscv/riscv/obj.yml
>> > +++ b/spec/build/bsps/riscv/riscv/obj.yml
>> > @@ -16,6 +16,7 @@ install:
>> > - bsps/riscv/riscv/include/bsp/fe310-uart.h
>> > - bsps/riscv/riscv/include/bsp/irq.h
>> > - bsps/riscv/riscv/include/bsp/riscv.h
>> > + - bsps/riscv/riscv/include/bsp/k210.h
>> > - destination: ${BSP_INCLUDEDIR}/dev/serial
>> > source:
>> > - bsps/riscv/riscv/include/dev/serial/htif.h
>> > diff --git a/spec/build/bsps/riscv/riscv/optkendrytek210.yml b/spec/build/bsps/riscv/riscv/optkendrytek210.yml
>> > index 0000000000..09848cf6e7
>> > --- /dev/null
>> > +++ b/spec/build/bsps/riscv/riscv/optkendrytek210.yml
>> > @@ -0,0 +1,18 @@
>> > +actions:
>> > +- get-boolean: null
>> > +- define-condition: null
>> > +build-type: option
>> > +copyrights:
>> > +default:
>> > + value: true
>> > +- enabled-by: true
>> > + value: false
>> > +description: |
>> > + enables support for the Kendryte K210 System on Chip if defined to a non-zero value, otherwise it is disabled (disabled by default)
>> > +enabled-by: true
>> > +links: []
>> > +name: RISCV_ENABLE_KENDRYTE_K210_SUPPORT
>> > +type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/optns16550max.yml b/spec/build/bsps/riscv/riscv/optns16550max.yml
>> > index 423bb5f74f..094a35f81e 100644
>> > --- a/spec/build/bsps/riscv/riscv/optns16550max.yml
>> > +++ b/spec/build/bsps/riscv/riscv/optns16550max.yml
>> > copyrights:
>> > default:
>> > -- enabled-by: riscv/frdme310arty
>> > +- enabled-by:
>> > + - riscv/frdme310arty
>> > value: null
>> > value: 1
>> > diff --git a/spec/build/bsps/riscv/riscv/optsifiveuart.yml b/spec/build/bsps/riscv/riscv/optsifiveuart.yml
>> > index 0000000000..6ad70755d5
>> > --- /dev/null
>> > +++ b/spec/build/bsps/riscv/riscv/optsifiveuart.yml
>> > @@ -0,0 +1,20 @@
>> > +actions:
>> > +build-type: option
>> > +copyrights:
>> > +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> > +default:
>> > +- enabled-by:
>> > + value: true
>> > +- enabled-by: true
>> > + value: false
>> > +description: |
>> > + enables support Sifive UART if defined to a non-zero value, otherwise it is disabled (disabled by default)
>> > +enabled-by: true
>> > +links: []
>> > +name: RISCV_ENABLE_SIFIVE_UART_SUPPORT
>> > +type: build
>> > diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
>> > index bbe93443ad..78f73e8c1b 100644
>> > --- a/spec/build/cpukit/optsmp.yml
>> > +++ b/spec/build/cpukit/optsmp.yml
>> > @@ -49,6 +49,7 @@ enabled-by:
>> > - riscv/rv64imafdc
>> > - riscv/rv64imafdc_medany
>> > - riscv/rv64imafd_medany
>> > +- riscv/kendrytek210
>> > - sparc/erc32
>> > - sparc/gr712rc
>> > - sparc/gr740
>> > 2.25.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
