[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Tue Mar 14 13:37:55 UTC 2023
> On Tue, 2023-03-14 at 13:37 +0100, Sebastian Huber wrote:
> On 14.03.23 13:31, Padmarao.Begari at microchip.com wrote:
> > Hi Sebastian,
> > > On Mon, 2023-03-06 at 14:11 +0100, Sebastian Huber wrote:
> > > On 06.03.23 13:00,Padmarao.Begari at microchip.com  wrote:
> > > > > On Mon, 2023-03-06 at 11:19 +0100, Sebastian Huber wrote:
> > > > > On 06.03.23 10:24,Padmarao.Begari at microchip.com   wrote:
> > > > > > Hi Sebastian,
> > > > > > > On Mon, 2023-03-06 at 09:41 +0100, Sebastian Huber wrote:
> > > > > > > On 06.03.23 09:37,Padmarao.Begari at microchip.com   wrote:
> > > > > > > > > Is
> > > > > > > > > the claim complete message ignored if the interrupt
> > > > > > > > > is
> > > > > > > > > disabled?
> > > > > > > > Yes.
> > > > > > > Is this an intended and documented behaviour of the PLIC?
> > > > > > Not documented
> > > > > Is this a common PLIC behaviour or just the case for the
> > > > > MicroChip
> > > > > implementation?
> > > > It's a common PLIC behaviour.
> > > It is not implemented in the Qemu PLIC emulation:
> > > https://github.com/qemu/qemu/blob/master/hw/intc/sifive_plic.c#L242
> > > Where do I see this behaviour in a PLIC implementation, for
> > > example:
> > > https://github.com/lowRISC/opentitan/tree/master/hw/ip_templates/rv_plic
> > > That the interrupt completion depends on the interrupt
> > > enable/disable
> > > status is quite unusual.
> > https://github.com/riscv/riscv-plic-spec/blob/master/riscv-plic.adoc#8-interrupt-completion
> > The interrupt is completed only when the interrupt is enabled but
> > not
> > when disabled.
> > Can we clear the interrupt before calling the interrupt handler?
> > like
> > below
> > https://github.com/RTEMS/rtems/blob/master/bsps/riscv/riscv/irq/irq.c#L90
> >      while ((interrupt_index = plic_hart_regs->claim_complete) !=
> > 0) {
> > +     plic_hart_regs->claim_complete = interrupt_index;
> >        bsp_interrupt_handler_dispatch(
> >          RISCV_INTERRUPT_VECTOR_EXTERNAL(interrupt_index)
> > -      plic_hart_regs->claim_complete = interrupt_index;
> > Also refer
> > https://github.com/psherman42/Demonstrating-MTVEC/blob/main/start.s#L307
> At some point I would like to enable support for nested interrupts. I
> guess in this case it is important that you complete the interrupt
> after
> processing.
The Exception(trap) handler is called when an interrupt occurs and the
global interrupt(mie) is disabled automatically at the top-most
level–the MIE bit in mstatus and re-enabled after return from machine
interrupt instruction "mret".
I think, we will not get any other interrupt while servicing the
interrupt handler, we can use the interrupt complete before processing.
Regards
Padmarao
> Ideally, we would return a status in the interrupt handlers to
> support
> things like the PLIC, however, this would be an API change affecting
> all
> existing interrupt handlers. This is not an option from my side.
> I would add new BSP interrupt controller methods specifically for the
> interrupt server. By default, they do nothing. For the PLIC they do
> the
> enable and complete once the server task did process the interrupt.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
