[PATCH] bsps/riscv: Clear interrupt complete before disable
Tue Mar 14 12:37:22 UTC 2023
On 14.03.23 13:31, Padmarao.Begari at microchip.com wrote:
> Hi Sebastian,
>> On Mon, 2023-03-06 at 14:11 +0100, Sebastian Huber wrote:
>> On 06.03.23 13:00,Padmarao.Begari at microchip.com  wrote:
>>>> On Mon, 2023-03-06 at 11:19 +0100, Sebastian Huber wrote:
>>>> On 06.03.23 10:24,Padmarao.Begari at microchip.com   wrote:
>>>>> Hi Sebastian,
>>>>>> On Mon, 2023-03-06 at 09:41 +0100, Sebastian Huber wrote:
>>>>>> On 06.03.23 09:37,Padmarao.Begari at microchip.com   wrote:
>>>>>>>> Is
>>>>>>>> the claim complete message ignored if the interrupt is
>>>>>>>> disabled?
>>>>>>> Yes.
>>>>>> Is this an intended and documented behaviour of the PLIC?
>>>>> Not documented
>>>> Is this a common PLIC behaviour or just the case for the
>>>> MicroChip
>>>> implementation?
>>> It's a common PLIC behaviour.
>> It is not implemented in the Qemu PLIC emulation:
>> https://github.com/qemu/qemu/blob/master/hw/intc/sifive_plic.c#L242
>> Where do I see this behaviour in a PLIC implementation, for example:
>> https://github.com/lowRISC/opentitan/tree/master/hw/ip_templates/rv_plic
>> That the interrupt completion depends on the interrupt enable/disable
>> status is quite unusual.
> https://github.com/riscv/riscv-plic-spec/blob/master/riscv-plic.adoc#8-interrupt-completion
> The interrupt is completed only when the interrupt is enabled but not
> when disabled.
> Can we clear the interrupt before calling the interrupt handler? like
> below
> https://github.com/RTEMS/rtems/blob/master/bsps/riscv/riscv/irq/irq.c#L90
>      while ((interrupt_index = plic_hart_regs->claim_complete) != 0) {
> +     plic_hart_regs->claim_complete = interrupt_index;
>        bsp_interrupt_handler_dispatch(
>          RISCV_INTERRUPT_VECTOR_EXTERNAL(interrupt_index)
> -      plic_hart_regs->claim_complete = interrupt_index;
> Also refer
> https://github.com/psherman42/Demonstrating-MTVEC/blob/main/start.s#L307
At some point I would like to enable support for nested interrupts. I
guess in this case it is important that you complete the interrupt after
processing.
Ideally, we would return a status in the interrupt handlers to support
things like the PLIC, however, this would be an API change affecting all
existing interrupt handlers. This is not an option from my side.
I would add new BSP interrupt controller methods specifically for the
interrupt server. By default, they do nothing. For the PLIC they do the
enable and complete once the server task did process the interrupt.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
