[PATCH v2 1/3] bsps/riscv: add device tree source and device tree blob header for k210 bsp variant
Alan Cudmore alan.cudmore at gmail.com
Thu Mar 16 02:04:10 UTC 2023
This patch adds the k210 device tree source and the corresponding
device tree blob encoded in the header which is used for the
embedded device tree blob for the Kendryte K210 BSP variant.
Updates #4876
 bsps/riscv/riscv/dts/kendryte-k210.dts        | 216 ++++++++++++
 .../riscv/include/bsp/kendryte-k210-dtb.h     | 315 ++++++++++++++++++
 2 files changed, 531 insertions(+)
 create mode 100644 bsps/riscv/riscv/dts/kendryte-k210.dts
 create mode 100644 bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
diff --git a/bsps/riscv/riscv/dts/kendryte-k210.dts b/bsps/riscv/riscv/dts/kendryte-k210.dts
new file mode 100644
index 0000000000..cad413dc81
--- /dev/null
+++ b/bsps/riscv/riscv/dts/kendryte-k210.dts
@@ -0,0 +1,216 @@
+ * Copyright (C) Alan Cudmore
+ * Copyright (C) Padmarao Begari
+ * Copyright (C) 2022 Microchip Technology Inc.
+ * are met:
+ *	notice, this list of conditions and the following disclaimer.
+ *	notice, this list of conditions and the following disclaimer in the
+ *	documentation and/or other materials provided with the distribution.
+ /* This is a device tree for the Kendryte K210 SoC. It is a simplified tree
+  * to support the current RTEMS BSP, but it is not sufficient enough for
+  * full linux or u-boot support.
+  * The file structure is based on the device tree source for the
+  * Polarfire SoC created by Padmaro Begari. The K210 device trees from
+  * u-boot were originally used to bring up the RTEMS BSP and were
+  * referenced to develop this file.
+/dts-v1/;
+        /* 32 bit address bus - upper 32 bits are ignored */
+	#address-cells = <1>;
+	#size-cells = <1>;
+	model = "Kendtryte K210 generic";
+	compatible = "canaan,kendryte-k210";
+	aliases {
+		serial0 = &uarths0;
+		serial1 = &uart1;
+		/* serial2 = &uart2; */
+		/* serial3 = &uart3; */
+	chosen {
+		stdout-path = "serial0";
+	cpus {
+		#size-cells = <0>;
+		timebase-frequency = <7800000>;
+		cpu0: cpu at 0 {
+			compatible = "canaan,k210", "riscv";
+			device_type = "cpu";
+			reg = <0>;
+			riscv,isa = "rv64imafdc";
+			i-cache-block-size = <64>;
+			i-cache-size = <0x8000>;
+			d-cache-block-size = <64>;
+			d-cache-size = <0x8000>;
+			cpu0_intc: interrupt-controller {
+				#interrupt-cells = <1>;
+				compatible = "riscv,cpu-intc";
+				interrupt-controller;
+		cpu1: cpu at 1 {
+			reg = <1>;
+			cpu1_intc: interrupt-controller {
+	clocks {
+                in0: oscillator {
+			compatible = "fixed-clock";
+			#clock-cells = <0>;
+			clock-frequency = <26000000>;
+	sram: memory at 80000000 {
+		device_type = "memory";
+                compatible = "canaan,k210-sram";
+		reg = <0x80000000 0x400000>,
+		      <0x80400000 0x200000>,
+		      <0x80600000 0x200000>;
+                reg-names = "sram0",
+                            "sram1",
+                            "aisram";
+	soc: soc {
+		compatible = "simple-bus";
+		ranges;
+                interrupt-parent = <&plic0>;
+                rom0: nvmem at 1000 {
+                         reg = <0x1000 0x1000>;
+                         read-only;
+		clint0: timer at 2000000 {
+			compatible = "riscv,clint0","sifive,clint0";
+			reg = <0x2000000 0xC000>;
+			interrupts-extended = <&cpu0_intc 3>,<&cpu0_intc 7>,
+					      <&cpu1_intc 3>,<&cpu1_intc 7>;
+		plic0: interrupt-controller at c000000 {
+			#address-cells = <0>;
+			compatible = "riscv,plic0","sifive,plic-1.0.0";
+			reg = <0xC000000 0x4000000>;
+			riscv,ndev = <65>;
+				<&cpu0_intc 11>, <&cpu0_intc 9>,
+				<&cpu1_intc 11>, <&cpu1_intc 9>;
+		uarths0: serial at 38000000 {
+			compatible = "canaan,k210-uarths","sifive,uart0";
+			reg = <0x38000000 0x1000>;
+			interrupts = <33>;
+			clocks = <&sysclk 0>;
+                /* apb0 has gpio1 and additional uarts */
+		apb0: bus at 50200000 {
+			compatible = "simple-pm-bus";
+			ranges;
+			clocks = <&sysclk 8>;
+			uart1: serial at 50210000 {
+				compatible = "snps,dw-apb-uart";
+				reg = <0x50210000 0x100>;
+				interrupts = <11>;
+				clocks = <&sysclk 30>,
+					 <&sysclk 8>;
+				clock-namees = "baudclk", "abp_pclk";
+				resets = <&sysrst 16>;
+				reg-io-width = <4>;
+				reg-shift = <2>;
+				dcd-override;
+				dsr-override;
+				cts-override;
+				ri-override;
+                apb1: bus at 50400000 {
+			ranges;
+			clocks = <&sysclk 9>;
+			sysctl: syscon at 50440000 {
+				compatible = "canaan,k210-sysctl","syscon",
+				             "simple-mfd";
+				reg = <0x50440000 0x100>;
+				clock-names = "pclk";
+				sysclk: clock-controller {
+					#clock-cells = <1>;
+					compatible = "canaan,k210-rst";
+					clock = <&in0>;
+				sysrst: reset-coontroller {
+					#reset-cells = <1>;
+				reboot: syscon-reboot {
+					compatible = "syscon-reboot";
+					regmap = <&sysctl>;
+					offset = <48>;
+					mask = <1>;
+					value = <1>;
diff --git a/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
index 0000000000..f1693f891b
--- /dev/null
+++ b/bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
@@ -0,0 +1,315 @@
+ *  Declarations for C structure representing binary file system.dtb
+ *  WARNING: Automatically generated -- do not edit!
+ * are met:
+#ifndef __kendryte_k210_dtb_h
+#define __kendryte_k210_dtb_h
+#include <rtems/score/basedefs.h>
+#include <sys/types.h>
+const unsigned char system_dtb[] RTEMS_ALIGNED(8) = {
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x0c, 0xa7, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x0a, 0xb4, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf3,
+  0x00, 0x00, 0x0a, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x1b,
+  0x4b, 0x65, 0x6e, 0x64, 0x74, 0x72, 0x79, 0x74, 0x65, 0x20, 0x4b, 0x32,
+  0x31, 0x30, 0x20, 0x67, 0x65, 0x6e, 0x65, 0x72, 0x69, 0x63, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x21,
+  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x65, 0x6e, 0x64, 0x72,
+  0x79, 0x74, 0x65, 0x2d, 0x6b, 0x32, 0x31, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x2c,
+  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40,
+  0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x34,
+  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32,
+  0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c,
+  0x40, 0x35, 0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x6f, 0x73,
+  0x65, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x3c, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x73,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x48,
+  0x00, 0x77, 0x04, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12,
+  0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b,
+  0x32, 0x31, 0x30, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b,
+  0x63, 0x70, 0x75, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34,
+  0x69, 0x6d, 0x61, 0x66, 0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88,
+  0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x95, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00,
+  0x00, 0x00, 0x00, 0x01, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
+  0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72,
+  0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
+  0x76, 0x2c, 0x63, 0x70, 0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40, 0x31, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x21,
+  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x00,
+  0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5b, 0x63, 0x70, 0x75, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x67,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
+  0x00, 0x00, 0x00, 0x6b, 0x72, 0x76, 0x36, 0x34, 0x69, 0x6d, 0x61, 0x66,
+  0x64, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x75, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x80, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x95,
+  0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xa8, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
+  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0f,
+  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x63, 0x70,
+  0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x73, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x01, 0x6f, 0x73, 0x63, 0x69, 0x6c, 0x6c, 0x61, 0x74,
+  0x6f, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c,
+  0x00, 0x00, 0x00, 0x21, 0x66, 0x69, 0x78, 0x65, 0x64, 0x2d, 0x63, 0x6c,
+  0x6f, 0x63, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xe3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x8c, 0xba, 0x80,
+  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x6d, 0x65, 0x6d, 0x6f, 0x72, 0x79, 0x40, 0x38,
+  0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x5b, 0x6d, 0x65, 0x6d, 0x6f,
+  0x72, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x11,
+  0x32, 0x31, 0x30, 0x2d, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x67,
+  0x80, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x80, 0x40, 0x00, 0x00,
+  0x00, 0x20, 0x00, 0x00, 0x80, 0x60, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x01, 0x00,
+  0x73, 0x72, 0x61, 0x6d, 0x30, 0x00, 0x73, 0x72, 0x61, 0x6d, 0x31, 0x00,
+  0x61, 0x69, 0x73, 0x72, 0x61, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x73, 0x6f, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f,
+  0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62,
+  0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x01, 0x11, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
+  0x6e, 0x76, 0x6d, 0x65, 0x6d, 0x40, 0x31, 0x30, 0x30, 0x30, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67,
+  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x22, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x74, 0x69, 0x6d, 0x65, 0x72, 0x40, 0x32, 0x30,
+  0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63,
+  0x76, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x73, 0x69, 0x66,
+  0x69, 0x76, 0x65, 0x2c, 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x30, 0x00, 0x00,
+  0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x07,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x63, 0x30, 0x30,
+  0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xb5, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1e,
+  0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x70, 0x6c,
+  0x69, 0x63, 0x30, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x70,
+  0x6c, 0x69, 0x63, 0x2d, 0x31, 0x2e, 0x30, 0x2e, 0x30, 0x00, 0x00, 0x00,
+  0x0c, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x41,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x01, 0x2c,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69,
+  0x61, 0x6c, 0x40, 0x33, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21,
+  0x63, 0x61, 0x6e, 0x61, 0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d,
+  0x75, 0x61, 0x72, 0x74, 0x68, 0x73, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76,
+  0x65, 0x2c, 0x75, 0x61, 0x72, 0x74, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x38, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x01, 0x4b, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x62, 0x75, 0x73, 0x40, 0x35, 0x30, 0x32, 0x30, 0x30, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21,
+  0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75,
+  0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x01, 0x0a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x35,
+  0x30, 0x32, 0x31, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x21, 0x73, 0x6e, 0x70, 0x73,
+  0x2c, 0x64, 0x77, 0x2d, 0x61, 0x70, 0x62, 0x2d, 0x75, 0x61, 0x72, 0x74,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x67, 0x50, 0x21, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x4b,
+  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1e,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x01, 0x5d, 0x62, 0x61, 0x75, 0x64,
+  0x63, 0x6c, 0x6b, 0x00, 0x61, 0x62, 0x70, 0x5f, 0x70, 0x63, 0x6c, 0x6b,
+  0x00, 0x00, 0x01, 0x6a, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x71,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x01, 0x7e, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x88, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x95, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xa2, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xaf, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x62, 0x75, 0x73, 0x40,
+  0x35, 0x30, 0x34, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x6d, 0x70,
+  0x6c, 0x65, 0x2d, 0x70, 0x6d, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x0a,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x56,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01,
+  0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x40, 0x35, 0x30, 0x34, 0x34, 0x30,
+  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25,
+  0x32, 0x31, 0x30, 0x2d, 0x73, 0x79, 0x73, 0x63, 0x74, 0x6c, 0x00, 0x73,
+  0x79, 0x73, 0x63, 0x6f, 0x6e, 0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65,
+  0x2d, 0x6d, 0x66, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x67, 0x50, 0x44, 0x00, 0x00,
+  0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x01, 0x56, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x01, 0xbb,
+  0x70, 0x63, 0x6c, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x07,
+  0x00, 0x00, 0x00, 0x01, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x6f,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe3,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+  0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xc7, 0x00, 0x00, 0x00, 0x06,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x72, 0x65, 0x73, 0x65, 0x74, 0x2d, 0x63, 0x6f, 0x6f, 0x6e, 0x74, 0x72,
+  0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x21, 0x63, 0x61, 0x6e, 0x61,
+  0x61, 0x6e, 0x2c, 0x6b, 0x32, 0x31, 0x30, 0x2d, 0x72, 0x73, 0x74, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xcd,
+  0x00, 0x00, 0x00, 0xdb, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x73, 0x79, 0x73, 0x63, 0x6f, 0x6e, 0x2d, 0x72,
+  0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x21, 0x73, 0x79, 0x73, 0x63,
+  0x6f, 0x6e, 0x2d, 0x72, 0x65, 0x62, 0x6f, 0x6f, 0x74, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xda,
+  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x01, 0xe1, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xe8, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xed,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
+  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65,
+  0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c,
+  0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00,
+  0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x30, 0x00, 0x73, 0x65, 0x72, 0x69,
+  0x61, 0x6c, 0x31, 0x00, 0x73, 0x74, 0x64, 0x6f, 0x75, 0x74, 0x2d, 0x70,
+  0x61, 0x74, 0x68, 0x00, 0x74, 0x69, 0x6d, 0x65, 0x62, 0x61, 0x73, 0x65,
+  0x2d, 0x66, 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x64,
+  0x65, 0x76, 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x72,
+  0x65, 0x67, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x69, 0x73, 0x61,
+  0x00, 0x69, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f,
+  0x63, 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x69, 0x2d, 0x63, 0x61,
+  0x63, 0x68, 0x65, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63,
+  0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x73,
+  0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d,
+  0x73, 0x69, 0x7a, 0x65, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72,
+  0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x69, 0x6e,
+  0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74,
+  0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64,
+  0x6c, 0x65, 0x00, 0x23, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x65,
+  0x6c, 0x6c, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66, 0x72,
+  0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x72, 0x65, 0x67, 0x2d,
+  0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
+  0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70,
+  0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x72, 0x65, 0x61, 0x64, 0x2d, 0x6f,
+  0x6e, 0x6c, 0x79, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
+  0x74, 0x73, 0x2d, 0x65, 0x78, 0x74, 0x65, 0x6e, 0x64, 0x65, 0x64, 0x00,
+  0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x6e, 0x64, 0x65, 0x76, 0x00, 0x69,
+  0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00, 0x63, 0x6c,
+  0x6f, 0x63, 0x6b, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e,
+  0x61, 0x6d, 0x65, 0x65, 0x73, 0x00, 0x72, 0x65, 0x73, 0x65, 0x74, 0x73,
+  0x00, 0x72, 0x65, 0x67, 0x2d, 0x69, 0x6f, 0x2d, 0x77, 0x69, 0x64, 0x74,
+  0x68, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73, 0x68, 0x69, 0x66, 0x74, 0x00,
+  0x64, 0x63, 0x64, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64, 0x65,
+  0x00, 0x64, 0x73, 0x72, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69, 0x64,
+  0x65, 0x00, 0x63, 0x74, 0x73, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
+  0x64, 0x65, 0x00, 0x72, 0x69, 0x2d, 0x6f, 0x76, 0x65, 0x72, 0x72, 0x69,
+  0x64, 0x65, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x61, 0x6d,
+  0x65, 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x00, 0x23, 0x72, 0x65,
+  0x73, 0x65, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x72, 0x65,
+  0x67, 0x6d, 0x61, 0x70, 0x00, 0x6f, 0x66, 0x66, 0x73, 0x65, 0x74, 0x00,
+  0x6d, 0x61, 0x73, 0x6b, 0x00, 0x76, 0x61, 0x6c, 0x75, 0x65, 0x00,
+const size_t system_dtb_size = sizeof(system_dtb);
+#endif /* __kendryte_k210_dtb_h */
2.25.1
