[PATCH v2 2/3] bsps/riscv: add riscv/kendrytek210 BSP variant source changes
Alan Cudmore alan.cudmore at gmail.com
Thu Mar 16 02:04:11 UTC 2023
This patch adds support for the Kendryte K210 RISC-V BSP variant.
The SoC uses the existing Interrupt Controller, Timer, and console UART.
It only needs SoC specific initialization and an embedded device tree binary
similar to the polarfire SoC BSP.
Updates #4876
 bsps/riscv/riscv/config/kendrytek210.cfg  |   9 ++
 bsps/riscv/riscv/console/console-config.c |  10 +--
 bsps/riscv/riscv/console/fe310-uart.c     |   2 +-
 bsps/riscv/riscv/include/bsp.h            |   4 +
 bsps/riscv/riscv/include/bsp/k210.h       | 105 ++++++++++++++++++++++
 bsps/riscv/riscv/include/bsp/riscv.h      |   4 +
 bsps/riscv/riscv/start/bspstart.c         |  43 +++++++++
 7 files changed, 171 insertions(+), 6 deletions(-)
 create mode 100644 bsps/riscv/riscv/config/kendrytek210.cfg
 create mode 100644 bsps/riscv/riscv/include/bsp/k210.h
diff --git a/bsps/riscv/riscv/config/kendrytek210.cfg b/bsps/riscv/riscv/config/kendrytek210.cfg
new file mode 100644
index 0000000000..b04e78b0e9
--- /dev/null
+++ b/bsps/riscv/riscv/config/kendrytek210.cfg
@@ -0,0 +1,9 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv64imafdc -mabi=lp64d -mcmodel=medany
+LDFLAGS = -Wl,--gc-sections
+CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index 4916191e0b..72743fe9d5 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -55,7 +55,7 @@
 #include <libfdt.h>
-#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
+#if RISCV_ENABLE_SIFIVE_UART_SUPPORT != 0
 #include <bsp/fe310-uart.h>
 static fe310_uart_context fe310_uart_instance;
 #endif
@@ -239,7 +239,7 @@ static void riscv_console_probe(void)
 #endif
     if (fdt_stringlist_contains(compat, compat_len, "sifive,uart0")) {
       fe310_uart_context *ctx;
@@ -255,7 +255,7 @@ static void riscv_console_probe(void)
         riscv_console.getchar = fe310_uart_read;
-      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
+      rtems_termios_device_context_initialize(&ctx->base, "SIFIVEUART");
 #endif
@@ -290,7 +290,7 @@ rtems_status_code console_initialize(
   size_t i;
 #endif
   char fe310_path[] = "/dev/ttyS0";
 #endif
@@ -326,7 +326,7 @@ rtems_status_code console_initialize(
 #endif
   ctx = &fe310_uart_instance;
   rtems_termios_device_install(
     fe310_path,
diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
index 506521add0..ddabcff4c8 100644
--- a/bsps/riscv/riscv/console/fe310-uart.c
+++ b/bsps/riscv/riscv/console/fe310-uart.c
@@ -53,7 +53,7 @@ static void fe310_uart_write (
   fe310_uart_context * ctx = (fe310_uart_context*) base;
   size_t i;
-  ctx->regs->div = riscv_get_core_frequency() / 115200 - 1;
+  ctx->regs->div = (riscv_get_core_frequency() / 115200 - 1) & 0xFFFF;
   ctx->regs->txctrl |= 1;
   ctx->regs->rxctrl |= 1;
diff --git a/bsps/riscv/riscv/include/bsp.h b/bsps/riscv/riscv/include/bsp.h
index 911b85f4a3..c33de42aa7 100644
--- a/bsps/riscv/riscv/include/bsp.h
+++ b/bsps/riscv/riscv/include/bsp.h
@@ -60,6 +60,10 @@
 #include <rtems/devnull.h>
+#if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0
+   #include <bsp/k210.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif
diff --git a/bsps/riscv/riscv/include/bsp/k210.h b/bsps/riscv/riscv/include/bsp/k210.h
index 0000000000..d5ae062863
--- /dev/null
+++ b/bsps/riscv/riscv/include/bsp/k210.h
@@ -0,0 +1,105 @@
+ * @file
+ * @ingroup k210_regs
+ * @brief k210 RISC-V CPU defines.
+ * Copyright (c) 2022 Alan Cudmore
+ * are met:
+ *      notice, this list of conditions and the following disclaimer.
+ *      notice, this list of conditions and the following disclaimer in the
+ *      documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_RISCV_RISCV_K210_H
+#define LIBBSP_RISCV_RISCV_K210_H
+#include <bspopts.h>
+#include <stdint.h>
+#include <bsp/utility.h>
+ * @defgroup K210 RISC V Register Definitions
+ * @ingroup RTEMSBSPsriscv
+ * @brief Register Definitions
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* For PLL / Clocks */
+#define K210_SYSCTL_BASE     0x50440000
+#define PLL_CLK_R(n)         (n & 0x00000F)
+#define PLL_CLK_F(n)         ((n & 0x0003F0) >> 4)
+#define PLL_CLK_OD(n)        ((n & 0x003C00) >> 10)
+#define CLKSEL0_ACLK_SEL(n)  (n & 0x00000001)
+typedef struct {
+  uint32_t git_id;
+  uint32_t clk_freq;
+  uint32_t pll0;
+  uint32_t pll1;
+  uint32_t pll2;
+  uint32_t resv5;
+  uint32_t pll_lock;
+  uint32_t rom_error;
+  uint32_t clk_sel0;
+  uint32_t clk_sel1;
+  uint32_t clk_en_cent;
+  uint32_t clk_en_peri;
+  uint32_t soft_reset;
+  uint32_t peri_reset;
+  uint32_t clk_th0;
+  uint32_t clk_th1;
+  uint32_t clk_th2;
+  uint32_t clk_th3;
+  uint32_t clk_th4;
+  uint32_t clk_th5;
+  uint32_t clk_th6;
+  uint32_t misc;
+  uint32_t peri;
+  uint32_t spi_sleep;
+  uint32_t reset_status;
+  uint32_t dma_sel0;
+  uint32_t dma_sel1;
+  uint32_t power_sel;
+  uint32_t resv28;
+  uint32_t resv29;
+  uint32_t resv30;
+  uint32_t resv31;
+} k210_sysctl_t;
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_RISCV_RISCV_K210_H */
diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
index bbaaa246c1..d294f1ae58 100644
--- a/bsps/riscv/riscv/include/bsp/riscv.h
+++ b/bsps/riscv/riscv/include/bsp/riscv.h
@@ -56,6 +56,10 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
 void htif_poweroff(void);
 #endif
+uint32_t k210_get_frequency(void);
+#endif
 #ifdef __cplusplus
 #endif
diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
index 30d479ce88..0e4f483263 100644
--- a/bsps/riscv/riscv/start/bspstart.c
+++ b/bsps/riscv/riscv/start/bspstart.c
@@ -201,7 +201,16 @@ static uint32_t get_core_frequency(void)
     return fdt32_to_cpu(*val);
 #endif
+  uint32_t cpu_clock;
+  cpu_clock = k210_get_frequency();
+  return cpu_clock;
+#else
   return 0;
+#endif
 uint32_t riscv_get_core_frequency(void)
@@ -215,6 +224,40 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
   return RISCV_INTERRUPT_VECTOR_EXTERNAL(intr[0]);
+  k210_sysctl_t *sysctl = (k210_sysctl_t *)K210_SYSCTL_BASE;
+  uint32_t cpu_clock = 0;
+  uint32_t pll0, nr, nf, od;
+  uint32_t node;
+  const char *fdt;
+  const fdt32_t *val;
+  int len;
+  fdt = bsp_fdt_get();
+  node = fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
+  val = fdt_getprop(fdt, node, "clock-frequency", &len);
+  if (val != NULL && len == 4) {
+    clk_freq = fdt32_to_cpu(*val);
+    if (CLKSEL0_ACLK_SEL(sysctl->clk_sel0) == 1) {
+       /* PLL0 selected */
+       pll0 = sysctl->pll0;
+       nr = PLL_CLK_R(pll0) + 1;
+       nf = PLL_CLK_F(pll0) + 1;
+       od = PLL_CLK_OD(pll0) + 1;
+       cpu_clock = (clk_freq / nr * nf / od)/2;
+    } else {
+       /* OSC selected */
+       cpu_clock = clk_freq;
+  return cpu_clock;
+#endif
 void bsp_start(void)
   riscv_find_harts();
2.25.1
