[PATCH v2 2/3] bsps/riscv: add riscv/kendrytek210 BSP variant source changes
Thu Mar 16 05:00:39 UTC 2023
This looks ok, There's a minor problem that this patch might break
existing BSPs due to the change in the option name
(RISCV_ENABLE_FRDME310ARTY_SUPPORT  to
RISCV_ENABLE_SIFIVE_UART_SUPPORT) until the spec patch is applied, so
it would be better then to combine the patches together, so that it
commits and builds/works cleanly, but this is a pretty minor issue. I
think these patches can be applied.
On Wed, Mar 15, 2023 at 8:04 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> This patch adds support for the Kendryte K210 RISC-V BSP variant.
> The SoC uses the existing Interrupt Controller, Timer, and console UART.
> It only needs SoC specific initialization and an embedded device tree binary
> similar to the polarfire SoC BSP.
> Updates #4876
>  bsps/riscv/riscv/config/kendrytek210.cfg  |   9 ++
>  bsps/riscv/riscv/console/console-config.c |  10 +--
>  bsps/riscv/riscv/console/fe310-uart.c     |   2 +-
>  bsps/riscv/riscv/include/bsp.h            |   4 +
>  bsps/riscv/riscv/include/bsp/k210.h       | 105 ++++++++++++++++++++++
>  bsps/riscv/riscv/include/bsp/riscv.h      |   4 +
>  bsps/riscv/riscv/start/bspstart.c         |  43 +++++++++
>  7 files changed, 171 insertions(+), 6 deletions(-)
>  create mode 100644 bsps/riscv/riscv/config/kendrytek210.cfg
>  create mode 100644 bsps/riscv/riscv/include/bsp/k210.h
> diff --git a/bsps/riscv/riscv/config/kendrytek210.cfg b/bsps/riscv/riscv/config/kendrytek210.cfg
> new file mode 100644
> index 0000000000..b04e78b0e9
> --- /dev/null
> +++ b/bsps/riscv/riscv/config/kendrytek210.cfg
> @@ -0,0 +1,9 @@
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU = riscv
> +CPU_CFLAGS = -march=rv64imafdc -mabi=lp64d -mcmodel=medany
> +LDFLAGS = -Wl,--gc-sections
> +CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
> diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> index 4916191e0b..72743fe9d5 100644
> --- a/bsps/riscv/riscv/console/console-config.c
> +++ b/bsps/riscv/riscv/console/console-config.c
> @@ -55,7 +55,7 @@
>  #include <libfdt.h>
>  #include <string.h>
> -#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
> +#if RISCV_ENABLE_SIFIVE_UART_SUPPORT != 0
>  #include <bsp/fe310-uart.h>
>  static fe310_uart_context fe310_uart_instance;
>  #endif
> @@ -239,7 +239,7 @@ static void riscv_console_probe(void)
>  #endif
>      if (fdt_stringlist_contains(compat, compat_len, "sifive,uart0")) {
>        fe310_uart_context *ctx;
> @@ -255,7 +255,7 @@ static void riscv_console_probe(void)
>          riscv_console.getchar = fe310_uart_read;
> -      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
> +      rtems_termios_device_context_initialize(&ctx->base, "SIFIVEUART");
>  #endif
> @@ -290,7 +290,7 @@ rtems_status_code console_initialize(
>    size_t i;
>  #endif
>    char fe310_path[] = "/dev/ttyS0";
>  #endif
> @@ -326,7 +326,7 @@ rtems_status_code console_initialize(
>  #endif
>    ctx = &fe310_uart_instance;
>    rtems_termios_device_install(
>      fe310_path,
> diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
> index 506521add0..ddabcff4c8 100644
> --- a/bsps/riscv/riscv/console/fe310-uart.c
> +++ b/bsps/riscv/riscv/console/fe310-uart.c
> @@ -53,7 +53,7 @@ static void fe310_uart_write (
>    fe310_uart_context * ctx = (fe310_uart_context*) base;
>    size_t i;
> -  ctx->regs->div = riscv_get_core_frequency() / 115200 - 1;
> +  ctx->regs->div = (riscv_get_core_frequency() / 115200 - 1) & 0xFFFF;
>    ctx->regs->txctrl |= 1;
>    ctx->regs->rxctrl |= 1;
> diff --git a/bsps/riscv/riscv/include/bsp.h b/bsps/riscv/riscv/include/bsp.h
> index 911b85f4a3..c33de42aa7 100644
> --- a/bsps/riscv/riscv/include/bsp.h
> +++ b/bsps/riscv/riscv/include/bsp.h
> @@ -60,6 +60,10 @@
>  #include <rtems/devnull.h>
> +#if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0
> +   #include <bsp/k210.h>
> +#endif
>  #ifdef __cplusplus
>  extern "C" {
>  #endif
> diff --git a/bsps/riscv/riscv/include/bsp/k210.h b/bsps/riscv/riscv/include/bsp/k210.h
> index 0000000000..d5ae062863
> --- /dev/null
> +++ b/bsps/riscv/riscv/include/bsp/k210.h
> @@ -0,0 +1,105 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup k210_regs
> + * @brief k210 RISC-V CPU defines.
> + * Copyright (c) 2022 Alan Cudmore
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *      notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *      notice, this list of conditions and the following disclaimer in the
> + *      documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef LIBBSP_RISCV_RISCV_K210_H
> +#define LIBBSP_RISCV_RISCV_K210_H
> +#include <bspopts.h>
> +#include <stdint.h>
> +#include <bsp/utility.h>
> + * @defgroup K210 RISC V Register Definitions
> + * @ingroup RTEMSBSPsriscv
> + * @brief Register Definitions
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* For PLL / Clocks */
> +#define K210_SYSCTL_BASE     0x50440000
> +#define PLL_CLK_R(n)         (n & 0x00000F)
> +#define PLL_CLK_F(n)         ((n & 0x0003F0) >> 4)
> +#define PLL_CLK_OD(n)        ((n & 0x003C00) >> 10)
> +#define CLKSEL0_ACLK_SEL(n)  (n & 0x00000001)
> +typedef struct {
> +  uint32_t git_id;
> +  uint32_t clk_freq;
> +  uint32_t pll0;
> +  uint32_t pll1;
> +  uint32_t pll2;
> +  uint32_t resv5;
> +  uint32_t pll_lock;
> +  uint32_t rom_error;
> +  uint32_t clk_sel0;
> +  uint32_t clk_sel1;
> +  uint32_t clk_en_cent;
> +  uint32_t clk_en_peri;
> +  uint32_t soft_reset;
> +  uint32_t peri_reset;
> +  uint32_t clk_th0;
> +  uint32_t clk_th1;
> +  uint32_t clk_th2;
> +  uint32_t clk_th3;
> +  uint32_t clk_th4;
> +  uint32_t clk_th5;
> +  uint32_t clk_th6;
> +  uint32_t misc;
> +  uint32_t peri;
> +  uint32_t spi_sleep;
> +  uint32_t reset_status;
> +  uint32_t dma_sel0;
> +  uint32_t dma_sel1;
> +  uint32_t power_sel;
> +  uint32_t resv28;
> +  uint32_t resv29;
> +  uint32_t resv30;
> +  uint32_t resv31;
> +} k210_sysctl_t;
> +#ifdef __cplusplus
> +#endif
> +#endif /* LIBBSP_RISCV_RISCV_K210_H */
> diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
> index bbaaa246c1..d294f1ae58 100644
> --- a/bsps/riscv/riscv/include/bsp/riscv.h
> +++ b/bsps/riscv/riscv/include/bsp/riscv.h
> @@ -56,6 +56,10 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
>  void htif_poweroff(void);
>  #endif
> +uint32_t k210_get_frequency(void);
> +#endif
>  #ifdef __cplusplus
>  #endif
> diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
> index 30d479ce88..0e4f483263 100644
> --- a/bsps/riscv/riscv/start/bspstart.c
> +++ b/bsps/riscv/riscv/start/bspstart.c
> @@ -201,7 +201,16 @@ static uint32_t get_core_frequency(void)
>      return fdt32_to_cpu(*val);
>  #endif
> +  uint32_t cpu_clock;
> +  cpu_clock = k210_get_frequency();
> +  return cpu_clock;
> +#else
>    return 0;
> +#endif
>  uint32_t riscv_get_core_frequency(void)
> @@ -215,6 +224,40 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
>    return RISCV_INTERRUPT_VECTOR_EXTERNAL(intr[0]);
> +  k210_sysctl_t *sysctl = (k210_sysctl_t *)K210_SYSCTL_BASE;
> +  uint32_t cpu_clock = 0;
> +  uint32_t pll0, nr, nf, od;
> +  uint32_t node;
> +  const char *fdt;
> +  const fdt32_t *val;
> +  int len;
> +  fdt = bsp_fdt_get();
> +  node = fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
> +  val = fdt_getprop(fdt, node, "clock-frequency", &len);
> +  if (val != NULL && len == 4) {
> +    clk_freq = fdt32_to_cpu(*val);
> +    if (CLKSEL0_ACLK_SEL(sysctl->clk_sel0) == 1) {
> +       /* PLL0 selected */
> +       pll0 = sysctl->pll0;
> +       nr = PLL_CLK_R(pll0) + 1;
> +       nf = PLL_CLK_F(pll0) + 1;
> +       od = PLL_CLK_OD(pll0) + 1;
> +       cpu_clock = (clk_freq / nr * nf / od)/2;
> +    } else {
> +       /* OSC selected */
> +       cpu_clock = clk_freq;
> +  return cpu_clock;
> +#endif
>  void bsp_start(void)
>    riscv_find_harts();
> 2.25.1
> devel mailing list
> devel at rtems.org
