[PATCH v2 0/3] bsps/riscv: Add kendrytek210 riscv BSP variant
Padmarao.Begari at microchip.com
Fri Mar 17 11:41:43 UTC 2023
I have tested it on the renode.io simulator and working fine.
Regards
Padmarao
> On Wed, 2023-03-15 at 22:04 -0400, Alan Cudmore wrote:
> Version 2 patch updates: Separated the device tree source and encoded
> device tree blob into a separate patch, added the license text to
> k210.h, eliminated whitespace warnings, and eliminated dead code in
> the conditional compilation structure for the core_get_frequency
> function in start/bspstart.c.
> This patch set adds the riscv/kendrytek210 BSP variant to support the
> Kendryte K210 Dual Core RISC-V SoC. The BSP runs on the renode.io
> simulator, the Sipeed MAiX BiT and MAiXDuino boards, and would likely
> run on other boards. RTEMS binaries can be flashed to the boards
> using
> the kflash python utility available through the pip command.
> Currently
> the BSP supports the console UART which is shared with the
> frdme310arty,
> an interrupt controller, and timer. The included device tree source
> just covers a minimal set of peripherals. The device tree can be
> expanded as additional device support is addded.
> Manufacturer, board links, and other information can be found in
> ticket #4876.
> Documentation that describes how to build and run the BSP on the
> boards and simulator has been prepared and will be submitted after
> the bsp
> is merged.
> The full testsuite has not been run on this BSP, but I run a
> subset of the of testsuite on the renode.io robot test framework.
> Alan Cudmore (3):
> bsps/riscv: add device tree source and device tree blob header for
> k210 bsp variant
> bsps/riscv: add riscv/kendrytek210 BSP variant source changes
> spec: add riscv kendrytek210 variant build options
> bsps/riscv/riscv/config/kendrytek210.cfg | 9 +
> bsps/riscv/riscv/console/console-config.c | 10 +-
> bsps/riscv/riscv/console/fe310-uart.c | 2 +-
> bsps/riscv/riscv/dts/kendryte-k210.dts | 216 ++++++++++++
> bsps/riscv/riscv/include/bsp.h | 4 +
> bsps/riscv/riscv/include/bsp/k210.h | 105 ++++++
> .../riscv/include/bsp/kendryte-k210-dtb.h | 315
> bsps/riscv/riscv/include/bsp/riscv.h | 4 +
> bsps/riscv/riscv/start/bspstart.c | 43 +++
> spec/build/bsps/optdtb.yml | 4 +-
> spec/build/bsps/optdtbheaderpath.yml | 2 +
> spec/build/bsps/optfdtuboot.yml | 3 +
> spec/build/bsps/riscv/optramsize.yml | 2 +
> spec/build/bsps/riscv/riscv/abi.yml | 1 +
> .../bsps/riscv/riscv/bspkendrtyek210.yml | 19 ++
> spec/build/bsps/riscv/riscv/grp.yml | 4 +
> spec/build/bsps/riscv/riscv/obj.yml | 1 +
> .../bsps/riscv/riscv/optkendrytek210.yml | 18 +
> spec/build/bsps/riscv/riscv/optns16550max.yml | 4 +-
> spec/build/bsps/riscv/riscv/optsifiveuart.yml | 20 ++
> spec/build/cpukit/optsmp.yml | 1 +
> 21 files changed, 779 insertions(+), 8 deletions(-)
> create mode 100644 bsps/riscv/riscv/config/kendrytek210.cfg
> create mode 100644 bsps/riscv/riscv/dts/kendryte-k210.dts
> create mode 100644 bsps/riscv/riscv/include/bsp/k210.h
> create mode 100644 bsps/riscv/riscv/include/bsp/kendryte-k210-dtb.h
> create mode 100644 spec/build/bsps/riscv/riscv/bspkendrtyek210.yml
> create mode 100644 spec/build/bsps/riscv/riscv/optkendrytek210.yml
> create mode 100644 spec/build/bsps/riscv/riscv/optsifiveuart.yml
> 2.25.1
> devel mailing list
> devel at rtems.org
