[PATCH] grub2.cfg: fix GRUB compilation with GCC 12.
Chris Johns
chrisj at rtems.org
Sun Mar 19 22:22:36 UTC 2023
Ok to push
Thanks
On 20/3/2023 9:13 am, Karel Gardas wrote:
> source-builder/config/grub2.cfg | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/source-builder/config/grub2.cfg b/source-builder/config/grub2.cfg
> index 2333d6a..174b846 100644
> --- a/source-builder/config/grub2.cfg
> +++ b/source-builder/config/grub2.cfg
> @@ -56,7 +56,8 @@ URL: https://www.gnu.org/software/grub/index.html
> --mandir=%{_mandir} --infodir=%{_infodir} \
> --with-platform=%{grub2_platform} \
> --target=%{grub2_target} \
> - --disable-libzfs # broken on FreeBSD and not needed at all
> + --disable-libzfs \ # broken on FreeBSD and not needed at all
> + --disable-werror # fixes compilation by GCC 12
> %{__make} %{?_smp_mflags} all
