Fwd: New Defects reported by Coverity Scan for RTEMS
Joel Sherrill
joel at rtems.org
Mon Mar 20 12:56:16 UTC 2023
New issue from Coveriry.
I vaguely recall that JFFS2 uses dynamic checks for things that static
would work and Coveriry spots the dead code
---------- Forwarded message ---------
Date: Sun, Mar 19, 2023, 10:59 PM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <build at rtems.org>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
4 new defect(s) introduced to RTEMS found with Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 4 of 4 defect(s)
** CID 1523448: Control flow issues (DEADCODE)
/cpukit/libfs/src/jffs2/src/gc.c: 137 in jffs2_garbage_collect_pass()
________________________________________________________________________________________________________
*** CID 1523448: Control flow issues (DEADCODE)
131 struct jffs2_raw_node_ref *raw;
132 uint32_t gcblock_dirty;
133 int ret = 0, inum, nlink;
134 int xattr = 0;
135
136 if (mutex_lock_interruptible(&c->alloc_sem))
>>> Execution cannot reach this statement: "return -4;".
137 return -EINTR;
138
139
140 for (;;) {
141 /* We can't start doing GC until we've finished
checking
142 the node CRCs etc. */
** CID 1523447: Null pointer dereferences (FORWARD_NULL)
/cpukit/libfs/src/jffs2/src/fs-rtems.c: 1370 in rtems_jffs2_initialize()
*** CID 1523447: Null pointer dereferences (FORWARD_NULL)
1364 } else {
1365 err = -ENOMEM;
1366 }
1367
1368 sb = &fs_info->sb;
1369 c = JFFS2_SB_INFO(sb);
>>> Dereferencing null pointer "c".
1370 c->mtd = NULL;
1371
1372 if (err == 0) {
1373 rtems_recursive_mutex_init(&sb->s_mutex,
RTEMS_FILESYSTEM_TYPE_JFFS2);
1374 }
1375
** CID 1330065: Incorrect expression (PW.ASSIGN_WHERE_COMPARE_MEANT)
/cpukit/libfs/src/jffs2/src/wbuf.c: 651 in ()
*** CID 1330065: Incorrect expression (PW.ASSIGN_WHERE_COMPARE_MEANT)
645 goto wfail;
646 } else if (retlen != c->wbuf_pagesize) {
647 pr_warn("jffs2_flush_wbuf(): Write was short: %zd
instead of %d\n",
648 retlen, c->wbuf_pagesize);
649 ret = -EIO;
650 goto wfail;
>>> use of "=" where "==" may have been intended
651 } else if ((ret = jffs2_verify_write(c, c->wbuf,
c->wbuf_ofs))) {
652 wfail:
653 jffs2_wbuf_recover(c);
654
655 return ret;
656 }
** CID 100676: Resource leaks (RESOURCE_LEAK)
/cpukit/libfs/src/jffs2/src/scan.c: 290 in jffs2_scan_medium()
*** CID 100676: Resource leaks (RESOURCE_LEAK)
284 if (buf_size)
285 kfree(flashbuf);
286 #ifndef __ECOS
287 else
288 mtd_unpoint(c->mtd, 0, c->mtd->size);
289 #endif
>>> Variable "flashbuf" going out of scope leaks the storage it points
to.
290 return ret;
291 }
292
293 static int jffs2_fill_scan_buf(struct jffs2_sb_info *c, void *buf,
294 uint32_t ofs, uint32_t len)
295 {
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3D4ud5_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMpnugfe7VtmjlezAUiUAqURm-2BYADlhnMIumDCuBe7mGT9aB8TE9cxvKFYrBHVJ7mgUGDbfjluxq0RzsXGFS9SkOWyeEfvDu1fFzYW3HwPYe1Rb-2FBCAMDNLGqgmVE-2Bb4qg5R5mDe6-2FFbWF4SiJvT-2FGVjdNh1OVArH-2Ff8IlRB6Y43MQ-3D-3D
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230320/eb2f785f/attachment.htm>
