[PATCH rtems-docs 1/2] user/zynqmp: Fix SDHCI wording
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Mar 21 20:00:58 UTC 2023
user/bsps/aarch64/xilinx-zynqmp.rst | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 1fef7a4..4de0115 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -253,7 +253,7 @@ as well as the physical ARM PL011 PrimeCell UART in the ZynqMP hardware.
SDHCI Driver
-The ZynqMP bsp has an SDHCI driver which allows reading to and writing from SD
+The ZynqMP bsp has an SDHCI driver which allows writing to and reading from SD
cards. These can be tested in qemu using the "-sd" option. For example:
.. code-block:: shell
2.30.2
