[PATCH rtems-docs 2/2] user/zynqmp: Add NAND driver information
Kinsey Moore kinsey.moore at oarcorp.com
Tue Mar 21 20:00:59 UTC 2023
 user/bsps/aarch64/xilinx-zynqmp.rst | 9 +++++++++
 1 file changed, 9 insertions(+)
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 4de0115..e30c3f6 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -250,6 +250,15 @@ Console Driver
 The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART
 as well as the physical ARM PL011 PrimeCell UART in the ZynqMP hardware.
+NAND Controller Driver
+The ZynqMP BSP has a NAND controller driver which allows writing to and reading
+from one or more attached NAND chips. This driver was imported from the Xilinx
+embeddedsw repository and requires the clock to be configured since it is a
+polling driver and not interrupt-driven. This driver is only available for
+hardware BSPs since QEMU does not emulate the NAND controller.
 SDHCI Driver
2.30.2
