[PATCH 2/2] includes: Update to use the latest networking headers
chrisj at rtems.org chrisj at rtems.org
Wed Mar 22 00:36:18 UTC 2023
- Add support for BSP configs and options if we need them
Closes #4882
 netlegacy.py | 11 +++++++++++
 wscript      | 11 ++++++++++-
 2 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/netlegacy.py b/netlegacy.py
index ebab745..981fd4a 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -46,15 +46,25 @@ for root, dirs, files in os.walk("."):
         if ext == '.h' and name not in exclude_headers:
             include_files[root[2:]].append(os.path.join(root, name))
 def find_node(bld, *paths):
     path = os.path.join(*paths)
     return os.path.relpath(str(bld.path.find_node(path)))
 def install_file_list(*paths):
     file_list = [os.path.join(path, f) for f in os.listdir(path)]
     return file_list
+def options(opt):
+    pass
+def bsp_configure(conf, arch_bsp, mandatory = True):
+    pass
 def build(bld):
     include_path = []
     ip = ''
@@ -107,6 +117,7 @@ def build(bld):
     bld(target='network_objects',
         features='c',
         includes=ip,
+        defines=['IN_HISTORICAL_NETS=1'],
         source=source_files)
     bld(target='networking',
diff --git a/wscript b/wscript
index 518108b..c790707 100644
--- a/wscript
+++ b/wscript
@@ -49,10 +49,19 @@ def init(ctx):
 def options(opt):
     rtems.options(opt)
+    netlegacy.options(opt)
+def bsp_configure(conf, arch_bsp):
+    env = conf.env.derive()
+    ab = conf.env.RTEMS_ARCH_BSP
+    conf.msg('Configure variant: ', ab)
+    conf.setenv(ab, env)
+    netlegacy.bsp_configure(conf, arch_bsp)
+    conf.setenv(ab)
 def configure(conf):
-    rtems.configure(conf)
+    rtems.configure(conf, bsp_configure)
 def recurse(ctx):
2.37.1
