[PATCH 2/2] includes: Update to use the latest networking headers
Gedare Bloom
gedare at rtems.org
Wed Mar 22 04:29:13 UTC 2023
These patches look ok for rtems-net-legacy.
In general, net-legacy is ok for maintenance patches. Any new features
will be heavily scrutinized and need additional discussions.
Please run the python file through yapf consistent with
https://docs.rtems.org/branches/master/eng/python-devel.html
feel free to send the format fix separately. this should help reduce
whitespace changes in the future patches to net-legacy.
Thanks!
On Tue, Mar 21, 2023 at 6:36 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Add support for BSP configs and options if we need them
> Closes #4882
> netlegacy.py | 11 +++++++++++
> wscript | 11 ++++++++++-
> 2 files changed, 21 insertions(+), 1 deletion(-)
> diff --git a/netlegacy.py b/netlegacy.py
> index ebab745..981fd4a 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -46,15 +46,25 @@ for root, dirs, files in os.walk("."):
> if ext == '.h' and name not in exclude_headers:
> include_files[root[2:]].append(os.path.join(root, name))
> def find_node(bld, *paths):
> path = os.path.join(*paths)
> return os.path.relpath(str(bld.path.find_node(path)))
> def install_file_list(*paths):
> file_list = [os.path.join(path, f) for f in os.listdir(path)]
> return file_list
> +def options(opt):
> + pass
> +def bsp_configure(conf, arch_bsp, mandatory = True):
> + pass
> def build(bld):
> include_path = []
> ip = ''
> @@ -107,6 +117,7 @@ def build(bld):
> bld(target='network_objects',
> features='c',
> includes=ip,
> + defines=['IN_HISTORICAL_NETS=1'],
> source=source_files)
> bld(target='networking',
> diff --git a/wscript b/wscript
> index 518108b..c790707 100644
> --- a/wscript
> +++ b/wscript
> @@ -49,10 +49,19 @@ def init(ctx):
> def options(opt):
> rtems.options(opt)
> + netlegacy.options(opt)
> +def bsp_configure(conf, arch_bsp):
> + env = conf.env.derive()
> + ab = conf.env.RTEMS_ARCH_BSP
> + conf.msg('Configure variant: ', ab)
> + conf.setenv(ab, env)
> + netlegacy.bsp_configure(conf, arch_bsp)
> + conf.setenv(ab)
> def configure(conf):
> - rtems.configure(conf)
> + rtems.configure(conf, bsp_configure)
> def recurse(ctx):
> 2.37.1
> devel mailing list
> devel at rtems.org
