[PATCH rtems-docs 2/2] user/zynqmp: Add NAND driver information
Kinsey Moore kinsey.moore at oarcorp.com
Wed Mar 22 02:18:03 UTC 2023
On Tue, Mar 21, 2023 at 7:39 PM Chris Johns <chrisj at rtems.org> wrote:
> On 22/3/2023 7:00 am, Kinsey Moore wrote:
> >  user/bsps/aarch64/xilinx-zynqmp.rst | 9 +++++++++
> >  1 file changed, 9 insertions(+)
> > diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst
> b/user/bsps/aarch64/xilinx-zynqmp.rst
> > index 4de0115..e30c3f6 100644
> > --- a/user/bsps/aarch64/xilinx-zynqmp.rst
> > +++ b/user/bsps/aarch64/xilinx-zynqmp.rst
> > @@ -250,6 +250,15 @@ Console Driver
> >  The console driver supports the default Qemu emulated ARM PL011
> PrimeCell UART
> >  as well as the physical ARM PL011 PrimeCell UART in the ZynqMP hardware.
> > +NAND Controller Driver
> > +The ZynqMP BSP has a NAND controller driver which allows writing to and
> reading
> > +from one or more attached NAND chips. This driver was imported from the
> Xilinx
> > +embeddedsw repository and requires the clock to be configured since it
> is a
> > +polling driver and not interrupt-driven. This driver is only available
> for
> > +hardware BSPs since QEMU does not emulate the NAND controller.
> Is the JFFS support that uses this driver for production or just an
> example?
> I ask because the QSPI driver takes control of the whole flash and that is
> confusing if you run an app that has a boot image in the same device
> because the
> JFFS erases it.
The JFFS2 glue in the ZynqMP BSP (both NAND and NOR) is perfectly usable in
production, but it does not encompass every use case that may exist which
is why it is not run by default. The user would need to customize their own
version of the glue code if they have requirements beyond "use the whole
device".
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230321/98d56be1/attachment.htm>
