[RTEMS-NET-LEGACY PATCH v2 3/3] waf: Reformat to the PEP 8 coding style
chrisj at rtems.org
chrisj at rtems.org
Wed Mar 22 04:38:26 UTC 2023
netlegacy.py | 54 ++++++++++++++++++++++++++++------------------------
wscript | 1 +
2 files changed, 30 insertions(+), 25 deletions(-)
diff --git a/netlegacy.py b/netlegacy.py
index 981fd4a..b08ccad 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -32,7 +32,10 @@ import os
source_files = []
include_files = {}
-exclude_dirs = ['pppd', 'nfsclient', 'testsuites', os.path.join('librpc', 'include'), 'bsps']
+exclude_dirs = [
+ 'pppd', 'nfsclient', 'testsuites',
+ os.path.join('librpc', 'include'), 'bsps'
exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
for root, dirs, files in os.walk("."):
@@ -57,11 +60,12 @@ def install_file_list(*paths):
file_list = [os.path.join(path, f) for f in os.listdir(path)]
return file_list
def options(opt):
pass
-def bsp_configure(conf, arch_bsp, mandatory = True):
+def bsp_configure(conf, arch_bsp, mandatory=True):
pass
@@ -69,9 +73,10 @@ def build(bld):
include_path = []
ip = ''
bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
- pppd_source = [os.path.join('pppd', s)
- for s in os.listdir('pppd')
- if os.path.splitext(s)[1] == '.c']
+ pppd_source = [
+ os.path.join('pppd', s) for s in os.listdir('pppd')
+ if os.path.splitext(s)[1] == '.c'
nfs_source = []
for root, dirs, files in os.walk('nfsclient'):
for name in files:
@@ -82,21 +87,21 @@ def build(bld):
bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
- include_path.extend(['.',
- 'include',
- os.path.relpath(bld.env.PREFIX),
- os.path.join('testsuites', 'include'),
- os.path.relpath(os.path.join(bld.env.PREFIX,
- 'include')),
- os.path.join('bsps', 'include')])
+ include_path.extend([
+ '.', 'include',
+ os.path.relpath(bld.env.PREFIX),
+ os.path.join('testsuites', 'include'),
+ os.path.relpath(os.path.join(bld.env.PREFIX, 'include')),
+ os.path.join('bsps', 'include')
arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
bld.env.RTEMS_ARCH_BSP)
lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
- include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
- arch_lib_path)))
- arch_lib_path,
- 'include')))
+ include_path.append(
+ os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path)))
+ os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path,
+ 'include')))
include_path.append(find_node(bld, 'bsps', 'include', 'libchip'))
bld.read_stlib('rtemsbsp', paths=[lib_path])
@@ -138,15 +143,14 @@ def build(bld):
bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
["libnetworking.a", 'libpppd.a', 'libnfs.a'])
- bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path,
- 'include', 'libchip'),
- install_file_list('bsps', 'include', 'libchip'))
+ bld.install_files(
+ os.path.join(bld.env.PREFIX, arch_lib_path, 'include', 'libchip'),
+ install_file_list('bsps', 'include', 'libchip'))
for i in include_files:
if 'include' in os.path.split(i):
- arch_lib_path, i),
+ bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path, i),
include_files[i])
else:
- arch_lib_path, 'include', i),
- include_files[i])
+ os.path.join(bld.env.PREFIX, arch_lib_path, 'include', i),
+ include_files[i])
diff --git a/wscript b/wscript
index c790707..5492b51 100644
--- a/wscript
+++ b/wscript
@@ -51,6 +51,7 @@ def options(opt):
rtems.options(opt)
netlegacy.options(opt)
def bsp_configure(conf, arch_bsp):
env = conf.env.derive()
ab = conf.env.RTEMS_ARCH_BSP
2.37.1
