[RTEMS-NET-LEGACY PATCH v2 3/3] waf: Reformat to the PEP 8 coding style
Gedare Bloom
gedare at rtems.org
Wed Mar 22 13:38:58 UTC 2023
ok to v2. thanks
On Tue, Mar 21, 2023 at 10:38 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> netlegacy.py | 54 ++++++++++++++++++++++++++++------------------------
> wscript | 1 +
> 2 files changed, 30 insertions(+), 25 deletions(-)
> diff --git a/netlegacy.py b/netlegacy.py
> index 981fd4a..b08ccad 100644
> --- a/netlegacy.py
> +++ b/netlegacy.py
> @@ -32,7 +32,10 @@ import os
> source_files = []
> include_files = {}
> -exclude_dirs = ['pppd', 'nfsclient', 'testsuites', os.path.join('librpc', 'include'), 'bsps']
> +exclude_dirs = [
> + 'pppd', 'nfsclient', 'testsuites',
> + os.path.join('librpc', 'include'), 'bsps'
> exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
> for root, dirs, files in os.walk("."):
> @@ -57,11 +60,12 @@ def install_file_list(*paths):
> file_list = [os.path.join(path, f) for f in os.listdir(path)]
> return file_list
> def options(opt):
> pass
> -def bsp_configure(conf, arch_bsp, mandatory = True):
> +def bsp_configure(conf, arch_bsp, mandatory=True):
> pass
> @@ -69,9 +73,10 @@ def build(bld):
> include_path = []
> ip = ''
> bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
> - pppd_source = [os.path.join('pppd', s)
> - for s in os.listdir('pppd')
> - if os.path.splitext(s)[1] == '.c']
> + pppd_source = [
> + os.path.join('pppd', s) for s in os.listdir('pppd')
> + if os.path.splitext(s)[1] == '.c'
> nfs_source = []
> for root, dirs, files in os.walk('nfsclient'):
> for name in files:
> @@ -82,21 +87,21 @@ def build(bld):
> bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> - include_path.extend(['.',
> - 'include',
> - os.path.relpath(bld.env.PREFIX),
> - os.path.join('testsuites', 'include'),
> - os.path.relpath(os.path.join(bld.env.PREFIX,
> - 'include')),
> - os.path.join('bsps', 'include')])
> + include_path.extend([
> + '.', 'include',
> + os.path.relpath(bld.env.PREFIX),
> + os.path.join('testsuites', 'include'),
> + os.path.relpath(os.path.join(bld.env.PREFIX, 'include')),
> + os.path.join('bsps', 'include')
> arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> bld.env.RTEMS_ARCH_BSP)
> lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> - include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> - arch_lib_path)))
> - arch_lib_path,
> - 'include')))
> + include_path.append(
> + os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path)))
> + os.path.relpath(os.path.join(bld.env.PREFIX, arch_lib_path,
> + 'include')))
> include_path.append(find_node(bld, 'bsps', 'include', 'libchip'))
> bld.read_stlib('rtemsbsp', paths=[lib_path])
> @@ -138,15 +143,14 @@ def build(bld):
> bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
> ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
> - bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path,
> - 'include', 'libchip'),
> - install_file_list('bsps', 'include', 'libchip'))
> + bld.install_files(
> + os.path.join(bld.env.PREFIX, arch_lib_path, 'include', 'libchip'),
> + install_file_list('bsps', 'include', 'libchip'))
> for i in include_files:
> if 'include' in os.path.split(i):
> - arch_lib_path, i),
> + bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path, i),
> include_files[i])
> else:
> - arch_lib_path, 'include', i),
> - include_files[i])
> + os.path.join(bld.env.PREFIX, arch_lib_path, 'include', i),
> + include_files[i])
> diff --git a/wscript b/wscript
> index c790707..5492b51 100644
> --- a/wscript
> +++ b/wscript
> @@ -51,6 +51,7 @@ def options(opt):
> rtems.options(opt)
> netlegacy.options(opt)
> def bsp_configure(conf, arch_bsp):
> env = conf.env.derive()
> ab = conf.env.RTEMS_ARCH_BSP
> 2.37.1
> devel mailing list
> devel at rtems.org
