[PATCH] Add support for ELF notes
Sebastian Huber
Thu Mar 23 14:47:28 UTC 2023
This is a prototype patch for adding ELF notes.
ELF notes can be used to attach domain-specific data to ELF files. This could
be used to store for example the RTEMS version, Git commit, configuration
options, expected test state, etc. in the executable ELF file.
Example:
readelf -n build/arm/xilinx_zynq_a9_qemu/testsuites/samples/ticker.exe
Displaying notes found in: .note.rtems
Owner Data size Description
RTEMS 0x00000004 Unknown note type: (0x00010000)
description data: 06 00 00 00
RTEMS 0x00000004 Unknown note type: (0x00010001)
description data: 00 00 00 00
RTEMS 0x00000004 Unknown note type: (0x00010002)
RTEMS 0x00000029 Unknown note type: (0x00010003)
description data: 37 39 34 38 31 66 39 61 37 61 31 32 35 62 64 31 66 64 65 31 66 38 32 39 61 65 64 39 33 62 31 38 36 36 39 38 66 62 38 32 00
RTEMS 0x00000008 Unknown note type: (0x00010004)
description data: 44 45 46 41 55 4c 54 00
RTEMS 0x00000004 Unknown note type: (0x00010005)
description data: 01 00 00 00
RTEMS 0x00000004 Unknown note type: (0x00010006)
RTEMS 0x00000004 Unknown note type: (0x00010007)
RTEMS 0x00000004 Unknown note type: (0x00010008)
RTEMS 0x00000004 Unknown note type: (0x00010009)
RTEMS 0x00000004 Unknown note type: (0x0001000a)
RTEMS 0x0000000b Unknown note type: (0x0001000b)
description data: 43 4c 4f 43 4b 20 54 49 43 4b 00
RTEMS 0x00000004 Unknown note type: (0x0001000c)
Update #4888.
bsps/arm/shared/start/linkcmds.base | 1 +
bsps/arm/shared/start/start.S | 2 +
bsps/include/bsp/startelfnotes.h | 98 +++++++++++++++++++
cpukit/include/rtems/score/elfnote.h | 139 +++++++++++++++++++++++++++
cpukit/include/rtems/test-info.h | 11 +++
testsuites/samples/ticker/init.c | 2 +-
6 files changed, 252 insertions(+), 1 deletion(-)
create mode 100644 bsps/include/bsp/startelfnotes.h
create mode 100644 cpukit/include/rtems/score/elfnote.h
diff --git a/bsps/arm/shared/start/linkcmds.base b/bsps/arm/shared/start/linkcmds.base
index 8c4d87dfdc..2c0fb87df0 100644
--- a/bsps/arm/shared/start/linkcmds.base
+++ b/bsps/arm/shared/start/linkcmds.base
@@ -436,6 +436,7 @@ SECTIONS {
.debug_sup 0 : { *(.debug_sup) }
.ARM.attributes 0 : { KEEP (*(.ARM.attributes)) KEEP (*(.gnu.attributes)) }
.note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
+ .note.rtems 0 : { KEEP (*(.note.rtems)) }
/DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index bc8753df93..dd17197ee0 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -596,3 +596,5 @@ bsp_start_hook_0_done:
.set bsp_start_vector_table_size, bsp_start_vector_table_end - bsp_start_vector_table_begin
.set bsp_vector_table_size, bsp_start_vector_table_size
+#include <bsp/startelfnotes.h>
diff --git a/bsps/include/bsp/startelfnotes.h b/bsps/include/bsp/startelfnotes.h
new file mode 100644
index 0000000000..ad38edb03c
--- /dev/null
+++ b/bsps/include/bsp/startelfnotes.h
@@ -0,0 +1,98 @@
+ * @file
+ * @ingroup RTEMSBSPsSharedStartup
+ * @brief This header file provides ELF notes for the start file.
+ * Copyright (C) 2023 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _BSP_STARTELFNOTES_H
+#define _BSP_STARTELFNOTES_H
+#include <rtems/score/elfnote.h>
+#include <bspopts.h>
+#include <version-vc-key.h>
+#ifndef ASM
+#error "This header file shall be included by assembly files only."
+#endif
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_MAJOR, .long __RTEMS_MAJOR__ )
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_MINOR, .long __RTEMS_MINOR__ )
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_REVISION, .long __RTEMS_REVISION__ )
+#ifdef RTEMS_VERSION_VC_KEY
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_VERSION_VC_KEY, .asciz RTEMS_VERSION_VC_KEY )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_VERSION_VC_KEY, .asciz "" )
+#endif
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_BUILD_LABEL, .asciz RTEMS_BUILD_LABEL )
+#ifdef RTEMS_DEBUG
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_DEBUG, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_DEBUG, .long 0 )
+#endif
+#ifdef RTEMS_MULTIPROCESSING
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_MULTIPROCESSING, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_MULTIPROCESSING, .long 0 )
+#endif
+#ifdef RTEMS_PARAVIRT
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_PARAVIRT, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_PARAVIRT, .long 0 )
+#endif
+#ifdef RTEMS_POSIX_API
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_POSIX_API, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_POSIX_API, .long 0 )
+#endif
+#ifdef RTEMS_PROFILING
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_PROFILING, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_PROFILING, .long 0 )
+#endif
+#ifdef RTEMS_SMP
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_SMP, .long 1 )
+#else
+ELF_NOTE_ASM_RTEMS( ELF_NOTE_RTEMS_SMP, .long 0 )
+#endif
+#endif /* _BSP_STARTELFNOTES_H */
diff --git a/cpukit/include/rtems/score/elfnote.h b/cpukit/include/rtems/score/elfnote.h
index 0000000000..af97b6ee50
--- /dev/null
+++ b/cpukit/include/rtems/score/elfnote.h
@@ -0,0 +1,139 @@
+ * @file
+ * @ingroup RTEMSScoreELFNote
+ * @brief This header file provides the interfaces of the
+ * @ref RTEMSScoreELFNote.
+ * are met:
+#ifndef _RTEMS_SCORE_ELFNOTE_H
+#define _RTEMS_SCORE_ELFNOTE_H
+#include <rtems/score/basedefs.h>
+#ifndef ASM
+#include <elf.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup RTEMSScoreELFNote ELF Note Handler
+ * @brief This group contains the ELF Note Handler implementation.
+ * @brief Defines an ELF note.
+ * @param _elf_size is the ELF size of the executable, either 32 or 64.
+ * @param _section is the note section name.
+ * @param _name is the name. It shall be a NUL-terminated string.
+ * @param _unique is a unique number for each use of the macro in a translation
+ * unit.
+ * @param _type is the type of the note. It shall be an ELF word integer.
+ * @param _desc is the description of the note.
+#define ELF_NOTE_DEFINE( _elf_size, _section, _name, _unique, _type, _desc ) \
+ static const struct { \
+ Elf##_elf_size##_Nhdr Note_header; \
+ RTEMS_ALIGNED( sizeof( Elf##_elf_size##_Word ) ) \
+ unsigned char Name[sizeof( _name )]; \
+ __typeof__( _desc ) Description; \
+ RTEMS_CONCAT( _note_, _unique ) \
+ RTEMS_USED \
+ RTEMS_UNUSED \
+ RTEMS_SECTION( ".note." _section ) \
+ RTEMS_ALIGNED( sizeof( Elf##_elf_size##_Word ) ) = \
+ { { sizeof( _name ), sizeof( _desc ), _type }, _name, _desc }
+#define ELF_NOTE_ASM_DEFINE( _section, _name, _type, _desc ) \
+ .pushsection RTEMS_STRING( .note.##_section ), "a", %note ; \
+ .balign 4 ; \
+ .long 2f - 1f ; \
+ .long 4f - 3f ; \
+ .long _type ; \
+ 1: .asciz _name ; \
+ 2: .balign 4 ; \
+ 3: _desc ; \
+ 4: .balign 4 ; \
+ .popsection
+#define ELF_NOTE_RTEMS_TYPE( _index ) ( ( _index ) + 0x10000 )
+#if CPU_SIZEOF_POINTER == 8
+#define ELF_NOTE_RTEMS( _type, _desc ) \
+ ELF_NOTE_DEFINE( 64, "rtems", "RTEMS", _type, \
+ ELF_NOTE_RTEMS_TYPE( _type ), _desc )
+#else
+ ELF_NOTE_DEFINE( 32, "rtems", "RTEMS", _type, \
+#endif
+#define ELF_NOTE_ASM_RTEMS( _type, _desc ) \
+ ELF_NOTE_ASM_DEFINE(rtems, "RTEMS", ELF_NOTE_RTEMS_TYPE( _type ), _desc )
+#define ELF_NOTE_RTEMS_MAJOR 0
+#define ELF_NOTE_RTEMS_MINOR 1
+#define ELF_NOTE_RTEMS_REVISION 2
+#define ELF_NOTE_RTEMS_VERSION_VC_KEY 3
+#define ELF_NOTE_RTEMS_BUILD_LABEL 4
+#define ELF_NOTE_RTEMS_DEBUG 5
+#define ELF_NOTE_RTEMS_MULTIPROCESSING 6
+#define ELF_NOTE_RTEMS_PARAVIRT 7
+#define ELF_NOTE_RTEMS_POSIX_API 8
+#define ELF_NOTE_RTEMS_PROFILING 9
+#define ELF_NOTE_RTEMS_SMP 10
+#define ELF_NOTE_RTEMS_TEST_NAME 11
+#define ELF_NOTE_RTEMS_TEST_STATE 12
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_ELFNOTE_H */
diff --git a/cpukit/include/rtems/test-info.h b/cpukit/include/rtems/test-info.h
index 3b839533c2..aa67dc04d9 100644
--- a/cpukit/include/rtems/test-info.h
+++ b/cpukit/include/rtems/test-info.h
@@ -31,6 +31,7 @@
#include <rtems/printer.h>
#include <rtems/score/atomic.h>
#include <rtems/score/smpbarrier.h>
#ifdef __cplusplus
@@ -95,16 +96,26 @@ typedef enum
#if TEST_STATE_EXPECTED_FAIL
#define TEST_STATE RTEMS_TEST_STATE_FAIL
+ #define TEST_STATE_NOTE 1
#elif TEST_STATE_USER_INPUT
#define TEST_STATE RTEMS_TEST_STATE_USER_INPUT
+ #define TEST_STATE_NOTE 2
#elif TEST_STATE_INDETERMINATE
#define TEST_STATE RTEMS_TEST_STATE_INDETERMINATE
+ #define TEST_STATE_NOTE 3
#elif TEST_STATE_BENCHMARK
#define TEST_STATE RTEMS_TEST_STATE_BENCHMARK
+ #define TEST_STATE_NOTE 4
#else
#define TEST_STATE RTEMS_TEST_STATE_PASS
+ #define TEST_STATE_NOTE 0
#endif
+#define RTEMS_TEST_IDENT( name ) \
+ ELF_NOTE_RTEMS( ELF_NOTE_RTEMS_TEST_NAME, name ); \
+ ELF_NOTE_RTEMS( ELF_NOTE_RTEMS_TEST_STATE, TEST_STATE_NOTE ); \
+ const char rtems_test_name[] = name
* @brief Prints a begin of test message using printf().
diff --git a/testsuites/samples/ticker/init.c b/testsuites/samples/ticker/init.c
index 86f87ad736..370f308dc4 100644
--- a/testsuites/samples/ticker/init.c
+++ b/testsuites/samples/ticker/init.c
@@ -33,7 +33,7 @@
#define CONFIGURE_INIT
#include "system.h"
-const char rtems_test_name[] = "CLOCK TICK";
+RTEMS_TEST_IDENT( "CLOCK TICK" );
* Keep the names and IDs in global variables so another task can use them.
2.35.3
