[PATCH 1/1] rtemsbsd/sdhci: Fix Arasan driver when no card present
Rick VanderWal rvanderwal at bellsouth.net
Fri Mar 24 00:19:29 UTC 2023
Kinsey,
Thanks for the feedback! I added the git config as recommended.
Response to your comment is inline below.
Regards,
-Rick
On 3/23/23 10:26, Kinsey Moore wrote:
> Hey Rick,
> This looks good for the most part and thanks for the contribution.
> For future patches, please make sure you specify the repository in
> your subject line if the patch isn't for the RTEMS repository. This
> can be configured to occur automatically in your local per-repo git
> configuration using this:
> git config format.subjectprefix "PATCH rtems-libbsd"
> This should actually be referenced in the git docs for this project,
> but it appears that there's a mistake in the markup that I'm about to
> go fix.
> Just one comment inline below:
> On Wed, Mar 22, 2023 at 7:02 PM <rvanderwal at bellsouth.net> wrote:
>     From: Rick VanderWal <rvanderwal at bellsouth.net>
>     This fixes an issue where the card present signal doesn't stabilize
>     quickly and indicates present when no card is inserted in a removable
>     slot.
>      rtemsbsd/sys/dev/sdhci/arasan_sdhci.c | 20 ++++++++++++++++++++
>      1 file changed, 20 insertions(+)
>     diff --git a/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
>     b/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
>     index 0e87d903..7ac0a971 100644
>     --- a/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
>     +++ b/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
>     @@ -195,6 +195,26 @@ arasan_sdhci_get_card_present(device_t dev,
>     struct sdhci_slot *slot)
>             struct arasan_sdhci_softc *sc = device_get_softc(dev);
>     +       // wait a maximum of 1 second for card stable to settle
>     +       const unsigned int max_tries = 20;
>     +       const rtems_interval sleep_ticks =
>     +               rtems_clock_get_ticks_per_second() / max_tries;
>     +       unsigned int count = 0;
>     +       while (!(RD4(sc, SDHCI_PRESENT_STATE) & SDHCI_CARD_STABLE) &&
>     +               (count < max_tries))
>     +               rtems_task_wake_after(sleep_ticks);
>     +               ++count;
>     +       if (!(RD4(sc, SDHCI_PRESENT_STATE) & SDHCI_CARD_STABLE))
>     +               device_printf(dev,
>     +                       "CD failed to stabilize, setting to not
>     present.\n");
> What is "CD"? Should this be "SD"?
CD is the "Card Detect" signal line from the SD card socket. In this
case it may be better to spell out to avoid confusion.
>     +               return false;
>             return (RD4(sc, SDHCI_PRESENT_STATE) & SDHCI_CARD_PRESENT);
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230323/ddb8deed/attachment.htm>
