[PATCH rtems-lwip] wscript: Build a header instead of using -D
Chris Johns
chrisj at rtems.org
Tue Mar 28 00:46:05 UTC 2023
On 28/3/2023 2:28 am, Kinsey Moore wrote:
> This change moves the use of items configured in config.ini from using
> -D to set defines on the command line to using a header built by waf.
> This also resolves an issue where configuration parameters were bleeding
> between BSPs when multiple BSPs were configured.
> rtemslwip/beaglebone/lwipopts.h | 2 ++
> rtemslwip/zynqmp/lwipopts.h | 2 ++
> wscript | 19 ++++++++++++++++---
> 3 files changed, 20 insertions(+), 3 deletions(-)
> diff --git a/rtemslwip/beaglebone/lwipopts.h b/rtemslwip/beaglebone/lwipopts.h
> index 888fae4..71ddd9f 100644
> --- a/rtemslwip/beaglebone/lwipopts.h
> +++ b/rtemslwip/beaglebone/lwipopts.h
> @@ -117,6 +117,8 @@
> #ifndef __LWIPOPTS_H__
> #define __LWIPOPTS_H__
> +#include <configuredlwipbspopts.h>
> ** CONFIGURATIONS
> diff --git a/rtemslwip/zynqmp/lwipopts.h b/rtemslwip/zynqmp/lwipopts.h
> index feabe73..d1b7334 100644
> --- a/rtemslwip/zynqmp/lwipopts.h
> +++ b/rtemslwip/zynqmp/lwipopts.h
> @@ -27,6 +27,8 @@
What about something simpler like `lwip-config.h`?
What include "zynqmp/lwipopts.h"? Sorry I do not know the lwip directory
structure. Is this by arch or a -I trick to allow just lwipopts.h?
> #define SYS_LIGHTWEIGHT_PROT 1
> #define NO_SYS 0
> diff --git a/wscript b/wscript
> index f1b919e..5e30279 100644
> --- a/wscript
> +++ b/wscript
> @@ -91,15 +91,23 @@ def get_configured_bsp_options(cp, arch, bsp):
> return options
> +bsp_opts_target = "bsps/include/configuredlwipbspopts.h"
> def bsp_configure(conf, arch_bsp):
> cp = get_config()
> arch = rtems.arch(arch_bsp)
> bsp = rtems.bsp(arch_bsp)
> config_options = get_configured_bsp_options(cp, arch, bsp)
> for key, val in config_options.items():
> - flag = "-D"+key+"="+val
> - conf.env.CFLAGS.append(flag)
> - conf.env.CXXFLAGS.append(flag)
> + conf.define(key, val, quote=False)
> + conf.env.include_key = []
> + conf.write_config_header(
> + arch_bsp + "/" + bsp_opts_target,
Is this a file name? If so should it be a bld.path.??? node?
> + guard="CONFIGURED_LWIP_BSP_OPTS_H",
> + top=True
> + conf.env.include_key = None
> lwip.bsp_configure(conf, arch_bsp)
> @@ -112,4 +120,9 @@ def configure(conf):
> def build(bld):
> rtems.build(bld)
> + arch_bsp = bld.env.RTEMS_ARCH_BSP
> + arch = rtems._arch_from_arch_bsp(arch_bsp)
> + bsp = rtems.bsp(arch_bsp)
> + install_target = os.path.join(bld.env.PREFIX, arch, bsp, "lib", "include")
> + bld.install_files(install_target, bsp_opts_target)
> lwip.build(bld)
