[PATCH rtems-lwip] wscript: Build a header instead of using -D
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Mar 28 00:51:07 UTC 2023
On Mon, Mar 27, 2023 at 7:46 PM Chris Johns <chrisj at rtems.org> wrote:
> On 28/3/2023 2:28 am, Kinsey Moore wrote:
> > This change moves the use of items configured in config.ini from using
> > -D to set defines on the command line to using a header built by waf.
> > This also resolves an issue where configuration parameters were bleeding
> > between BSPs when multiple BSPs were configured.
> > rtemslwip/beaglebone/lwipopts.h | 2 ++
> > rtemslwip/zynqmp/lwipopts.h | 2 ++
> > wscript | 19 ++++++++++++++++---
> > 3 files changed, 20 insertions(+), 3 deletions(-)
> > diff --git a/rtemslwip/beaglebone/lwipopts.h
> b/rtemslwip/beaglebone/lwipopts.h
> > index 888fae4..71ddd9f 100644
> > --- a/rtemslwip/beaglebone/lwipopts.h
> > +++ b/rtemslwip/beaglebone/lwipopts.h
> > @@ -117,6 +117,8 @@
> > #ifndef __LWIPOPTS_H__
> > #define __LWIPOPTS_H__
> > +#include <configuredlwipbspopts.h>
> > ** CONFIGURATIONS
> > diff --git a/rtemslwip/zynqmp/lwipopts.h b/rtemslwip/zynqmp/lwipopts.h
> > index feabe73..d1b7334 100644
> > --- a/rtemslwip/zynqmp/lwipopts.h
> > +++ b/rtemslwip/zynqmp/lwipopts.h
> > @@ -27,6 +27,8 @@
> What about something simpler like `lwip-config.h`?
I'll simplify it to that. This needs a v2 anyway due to a different issue.
> What include "zynqmp/lwipopts.h"? Sorry I do not know the lwip directory
> structure. Is this by arch or a -I trick to allow just lwipopts.h?
> lwipopts.h is included directly by lwIP code and the target is selected by
varying include paths based on BSP as configured by the JSON files under
defs/. Eventually, all BSPs will use the same lwipopts.h and bsp-specific
variations will be introduced by this configuration generated file and the
existing BSP-specific include.
> > #define SYS_LIGHTWEIGHT_PROT 1
> > #define NO_SYS 0
> > diff --git a/wscript b/wscript
> > index f1b919e..5e30279 100644
> > --- a/wscript
> > +++ b/wscript
> > @@ -91,15 +91,23 @@ def get_configured_bsp_options(cp, arch, bsp):
> > return options
> > +bsp_opts_target = "bsps/include/configuredlwipbspopts.h"
> > def bsp_configure(conf, arch_bsp):
> > cp = get_config()
> > arch = rtems.arch(arch_bsp)
> > bsp = rtems.bsp(arch_bsp)
> > config_options = get_configured_bsp_options(cp, arch, bsp)
> > for key, val in config_options.items():
> > - flag = "-D"+key+"="+val
> > - conf.env.CFLAGS.append(flag)
> > - conf.env.CXXFLAGS.append(flag)
> > + conf.define(key, val, quote=False)
> > + conf.env.include_key = []
> > + conf.write_config_header(
> > + arch_bsp + "/" + bsp_opts_target,
> Is this a file name? If so should it be a bld.path.??? node?
This is based on how RTEMS generates its bspopts.h. I'll see if I can clean
it up a bit.
Thanks for the review!
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230327/878cb22a/attachment-0001.htm>
