[PATCH rtems-lwip 2/2] wscript: Build a header instead of using -D
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Mar 29 20:51:12 UTC 2023
This change moves the use of items configured in config.ini from using
-D to set defines on the command line to using a header built by waf.
This also resolves an issue where configuration parameters were bleeding
between BSPs when multiple BSPs were configured.
rtemslwip/include/lwipopts.h | 2 ++
wscript | 19 ++++++++++++++++---
2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/rtemslwip/include/lwipopts.h b/rtemslwip/include/lwipopts.h
index 157cce8..27e2c91 100644
--- a/rtemslwip/include/lwipopts.h
+++ b/rtemslwip/include/lwipopts.h
@@ -27,6 +27,8 @@
#ifndef __LWIPOPTS_H__
#define __LWIPOPTS_H__
+#include <lwipconfig.h>
/* Critical items that all BSPs must use for full functionality */
#define SYS_LIGHTWEIGHT_PROT 1
#define NO_SYS 0
diff --git a/wscript b/wscript
index f1b919e..59bf81d 100644
--- a/wscript
+++ b/wscript
@@ -91,15 +91,23 @@ def get_configured_bsp_options(cp, arch, bsp):
return options
+bsp_opts_target = os.path.join("rtemslwip", "include", "lwipconfig.h")
def bsp_configure(conf, arch_bsp):
cp = get_config()
arch = rtems.arch(arch_bsp)
bsp = rtems.bsp(arch_bsp)
config_options = get_configured_bsp_options(cp, arch, bsp)
for key, val in config_options.items():
- flag = "-D"+key+"="+val
- conf.env.CFLAGS.append(flag)
- conf.env.CXXFLAGS.append(flag)
+ conf.define(key, val, quote=False)
+ conf.env.include_key = []
+ conf.write_config_header(
+ os.path.join(arch_bsp, bsp_opts_target),
+ guard="CONFIGURED_LWIP_BSP_OPTS_H",
+ top=True
+ conf.env.include_key = None
lwip.bsp_configure(conf, arch_bsp)
@@ -112,4 +120,9 @@ def configure(conf):
def build(bld):
rtems.build(bld)
+ arch_bsp = bld.env.RTEMS_ARCH_BSP
+ arch = rtems._arch_from_arch_bsp(arch_bsp)
+ bsp = rtems.bsp(arch_bsp)
+ install_target = os.path.join(bld.env.PREFIX, arch, bsp, "lib", "include")
+ bld.install_files(install_target, bsp_opts_target)
lwip.build(bld)
2.30.2
