[PATCH] docs/user: add docs for riscv/kendrytek210 BSP variant
Padmarao.Begari at microchip.com
Thu Mar 30 15:28:49 UTC 2023
Hi Alan,
> On Wed, 2023-03-29 at 10:32 -0400, Alan Cudmore wrote:
> This patch adds the documentation for building and running RTEMS on
> the Kendryte K210 RISC-V SoC. The generic riscv introducion
> was re-arranged to list the multilib variants then the specific
> hardware targets. In addition a couple of errors were fixed for
> the generic QEMU commands.
> Closes #4876
> user/bsps/bsps-riscv.rst | 105 ++++++++++++++++++++++++++++++++++---
> 1 file changed, 92 insertions(+), 13 deletions(-)
> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
> index 41f369f..14055d0 100644
> --- a/user/bsps/bsps-riscv.rst
> +++ b/user/bsps/bsps-riscv.rst
> @@ -8,7 +8,7 @@ riscv (RISC-V)
> riscv
> -This BSP offers 12 variants:
> +**This BSP offers 10 variants, each corresponding to a GCC
> multilib:**
> * rv32i
> @@ -30,23 +30,22 @@ This BSP offers 12 variants:
> * rv64imafdc
> -* frdme310arty
> -* mpfs64imafdc
> -Each rv* variant corresponds to a GCC multilib. A particular
> variant reflects an
> -ISA with ABI and code model choice. All rv64 BSPs have medany code
> model by
> +Each variant reflects an ISA with ABI and code model choice. All
> rv64 BSPs have medany code model by
> default, while rv32 BSPs are medlow. The reason is that RV32 medlow
> can access
> the entire 32-bit address space, while RV64 medlow can only access
> addresses
> below 0x80000000. With RV64 medany, it's possible to perform
> accesses above
> -0x80000000.
> +0x80000000. The BSP must be started im machine mode.
I think, it is "in machine mode" not "im"
> +The reference platform for the rv* variants is the QEMU `virt`
> machine.
> +**The BSP also provides the following 3 variants for specific
> hardware targets:**
> -The BSP must be started im machine mode.
> +* frdme310arty - The reference platform for this variant is the Arty
> FPGA board with the Sifive Freedom E310 reference design.
> -The reference platform for this BSP is the QEMU `virt` machine.
> +* mpfs64imafdc - The reference platform for this variant is the
> Microchip PolarFire SoC Icicle Kit.
> +* kendrytek210 - The reference platform for this variant is the
> Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
> -The reference platform for the mpfs64imafdc BSP variant is the
> Microchip
> -PolarFire SoC Icicle Kit.
> Build Configuration Options
> @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
> used to inspect the values.
> The maximum number of NS16550 devices supported by the console
> driver (2
> by default).
> +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
> + Enable the Sifive console UART (disabled by default)
> ``RISCV_RAM_REGION_BEGIN``
> The begin of the RAM region for linker command file (default is
> 0x80000000).
> @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can
> be used to inspect the values.
> Enables support Microchip PolarFire SoC if defined to a non-
> zero
> value, otherwise it is disabled (disabled by default).
> +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
> + Enables support for the Kendtryte K210 SoC if defined to a non-
> zero
> + value, otherwise it is disabled (disabled by default).
> ``RISCV_BOOT_HARTID``
> The boot hartid (processor number) of risc-v cpu by default 0.
> @@ -131,7 +137,7 @@ The console driver supports devices compatible to
> * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
> -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP
> option).
> +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP
> option). This console driver is used by the frdme310arty and
> kendrytek210 BSP variants.
> They are initialized according to the device tree. The console
> driver does not
> configure the pins or peripheral clocks. The console device is
> selected
> @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
> ``rv64imafdc`` BSP with the
> following "config.ini" file.
> .. code-block:: none
> [riscv/rv64imafdc]
> Run the following QEMU command.
> .. code-block:: shell
> $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
> $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
> @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP
> with the following
> "config.ini" file.
> [riscv/rv64imafdc]
> Run the following Spike command.
> $ spike --isa=rv64imafdc $RTEMS_EXE
> Unlike QEMU, Spike supports enabling/disabling a subset of the
> imafdc extensions
> @@ -277,6 +287,75 @@ Serial terminal UART1 displays the SMP example
> messages
> *** END OF TEST SMP 1 ***
> +Kendryte K210
> +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI
> NPU,
> +built in SRAM, and a variety of peripherals. Currently just the
> console UART, interrupt controller, and timer are supported.
> +The device tree blob is embedded in the ``kendrytek210`` BSP variant
> by default.
> +When the kendrytek210 BSP variant is selected,
> ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
> +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
> +The ``kendrytek210`` BSP variant has been tested on the following
> simulator and boards:
> +* Renode.io simulator using the Kendrtye k210 model
> +* Sipeed MAix BiT board
> +* Sipeed MaixDuino board
> +**Building the Kendryte K210 BSP**
> +Configuration file ``config.ini``:
> +.. code-block:: none
> + [riscv/kendrytek210]
> + RTEMS_SMP = True
> +Build RTEMS:
> +.. code-block:: shell
> + $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
> + $ ./waf
> +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
> +Binary images can be flashed to the Sipeed boards through the USB
> port using the kflash.py utility available from the python pip
> utility.
> + $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
> + $ kflash.py --uart /dev/ttyUSB0 ticker.bin
> +After the image is flashed, the RTEMS image will automatically boot.
> It will also run when the board is reset or powered through the USB
> cable. The USB port provides the power and console UART. Plug the USB
> cable into a host PC and bring up a terminal emulator at 115k baud,
> 8N1. On linux the UART device is often ``/dev/ttyUSB0``.
May be like this: "at 115200 baud, 8 data bits, 1 stop bit, no parity,
and no flow control. On Linux the UART device is often
``/dev/ttyUSB0``."
> +**Run a RTEMS application on the Renode.io simulator**
> +RTEMS executables compiled with the kendrytek210 BSP can run on the
> renode.io simulator using the built-in K210 model. The simulator
> currently supports the console UART, interrupt controller, and timer.
> +To install renode.io please refer to the instructions on the
> website.
Can we name the website with hyperlink or share the installation link "
https://github.com/renode/renode#installation"
Regards
Padmarao
> Once installed make a local copy of the ``kendryte_k210.resc``
> script from the ``renode/scripts/single-node`` directory to a local
> directory where it can be edited. Edit the script and change the line
> that loads the Linux image to load a RTEMS elf image instead. The
> default extension for the RTEMS sample ELF images is ``.exe``.
> + sysbus LoadELF ticker.exe
> +After editing the script, start renode and load the
> kendryte_k210.resc script to start the emulation.
> + (monitor) s @kendryte_k210.resc
> +**Generating the Device Tree Header**
> +The kendrytek210 BSP uses a built in device tree blob. If additional
> peripheral support is added to the BSP, the device tree may need to
> be updated. After editing the device tree source, compile it to a
> device tree blob with the following command:
> + $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
> +The dtb file can then be converted to a C array using the rtems-
> bin2c tool. The data for the device tree binary can then replace the
> existing device tree binary data in the ``kendryte-k210-dtb.h``
> header file.
> noel
> 2.25.1
> devel mailing list
> devel at rtems.org
