[PATCH] docs/user: add docs for riscv/kendrytek210 BSP variant
Alan Cudmore
alan.cudmore at gmail.com
Thu Mar 30 19:10:59 UTC 2023
Hi Padmarao,
Thanks for reviewing the changes. I agree with your suggestions and will
send out a V2 patch soon.
Thanks,
Alan
On Thu, Mar 30, 2023 at 11:28 AM <Padmarao.Begari at microchip.com> wrote:
> Hi Alan,
> > On Wed, 2023-03-29 at 10:32 -0400, Alan Cudmore wrote:
> > This patch adds the documentation for building and running RTEMS on
> > the Kendryte K210 RISC-V SoC. The generic riscv introducion
> > was re-arranged to list the multilib variants then the specific
> > hardware targets. In addition a couple of errors were fixed for
> > the generic QEMU commands.
> > Closes #4876
> > user/bsps/bsps-riscv.rst | 105 ++++++++++++++++++++++++++++++++++---
> > 1 file changed, 92 insertions(+), 13 deletions(-)
> > diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
> > index 41f369f..14055d0 100644
> > --- a/user/bsps/bsps-riscv.rst
> > +++ b/user/bsps/bsps-riscv.rst
> > @@ -8,7 +8,7 @@ riscv (RISC-V)
> > riscv
> > -This BSP offers 12 variants:
> > +**This BSP offers 10 variants, each corresponding to a GCC
> > multilib:**
> > * rv32i
> > @@ -30,23 +30,22 @@ This BSP offers 12 variants:
> > * rv64imafdc
> > -* frdme310arty
> > -* mpfs64imafdc
> > -Each rv* variant corresponds to a GCC multilib. A particular
> > variant reflects an
> > -ISA with ABI and code model choice. All rv64 BSPs have medany code
> > model by
> > +Each variant reflects an ISA with ABI and code model choice. All
> > rv64 BSPs have medany code model by
> > default, while rv32 BSPs are medlow. The reason is that RV32 medlow
> > can access
> > the entire 32-bit address space, while RV64 medlow can only access
> > addresses
> > below 0x80000000. With RV64 medany, it's possible to perform
> > accesses above
> > -0x80000000.
> > +0x80000000. The BSP must be started im machine mode.
> I think, it is "in machine mode" not "im"
> > +The reference platform for the rv* variants is the QEMU `virt`
> > machine.
> > +**The BSP also provides the following 3 variants for specific
> > hardware targets:**
> > -The BSP must be started im machine mode.
> > +* frdme310arty - The reference platform for this variant is the Arty
> > FPGA board with the Sifive Freedom E310 reference design.
> > -The reference platform for this BSP is the QEMU `virt` machine.
> > +* mpfs64imafdc - The reference platform for this variant is the
> > Microchip PolarFire SoC Icicle Kit.
> > +* kendrytek210 - The reference platform for this variant is the
> > Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
> > -The reference platform for the mpfs64imafdc BSP variant is the
> > Microchip
> > -PolarFire SoC Icicle Kit.
> > Build Configuration Options
> > @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
> > used to inspect the values.
> > The maximum number of NS16550 devices supported by the console
> > driver (2
> > by default).
> > +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
> > + Enable the Sifive console UART (disabled by default)
> > ``RISCV_RAM_REGION_BEGIN``
> > The begin of the RAM region for linker command file (default is
> > 0x80000000).
> > @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can
> > be used to inspect the values.
> > Enables support Microchip PolarFire SoC if defined to a non-
> > zero
> > value, otherwise it is disabled (disabled by default).
> > +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
> > + Enables support for the Kendtryte K210 SoC if defined to a non-
> > zero
> > + value, otherwise it is disabled (disabled by default).
> > ``RISCV_BOOT_HARTID``
> > The boot hartid (processor number) of risc-v cpu by default 0.
> > @@ -131,7 +137,7 @@ The console driver supports devices compatible to
> > * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
> > -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP
> > option).
> > +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP
> > option). This console driver is used by the frdme310arty and
> > kendrytek210 BSP variants.
> > They are initialized according to the device tree. The console
> > driver does not
> > configure the pins or peripheral clocks. The console device is
> > selected
> > @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
> > ``rv64imafdc`` BSP with the
> > following "config.ini" file.
> > .. code-block:: none
> > [riscv/rv64imafdc]
> > Run the following QEMU command.
> > .. code-block:: shell
> > $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
> > $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
> > @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP
> > with the following
> > "config.ini" file.
> > [riscv/rv64imafdc]
> > Run the following Spike command.
> > $ spike --isa=rv64imafdc $RTEMS_EXE
> > Unlike QEMU, Spike supports enabling/disabling a subset of the
> > imafdc extensions
> > @@ -277,6 +287,75 @@ Serial terminal UART1 displays the SMP example
> > messages
> > *** END OF TEST SMP 1 ***
> > +Kendryte K210
> > +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI
> > NPU,
> > +built in SRAM, and a variety of peripherals. Currently just the
> > console UART, interrupt controller, and timer are supported.
> > +The device tree blob is embedded in the ``kendrytek210`` BSP variant
> > by default.
> > +When the kendrytek210 BSP variant is selected,
> > ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
> > +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
> > +The ``kendrytek210`` BSP variant has been tested on the following
> > simulator and boards:
> > +* Renode.io simulator using the Kendrtye k210 model
> > +* Sipeed MAix BiT board
> > +* Sipeed MaixDuino board
> > +**Building the Kendryte K210 BSP**
> > +Configuration file ``config.ini``:
> > +.. code-block:: none
> > + [riscv/kendrytek210]
> > + RTEMS_SMP = True
> > +Build RTEMS:
> > +.. code-block:: shell
> > + $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
> > + $ ./waf
> > +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
> > +Binary images can be flashed to the Sipeed boards through the USB
> > port using the kflash.py utility available from the python pip
> > utility.
> > + $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
> > + $ kflash.py --uart /dev/ttyUSB0 ticker.bin
> > +After the image is flashed, the RTEMS image will automatically boot.
> > It will also run when the board is reset or powered through the USB
> > cable. The USB port provides the power and console UART. Plug the USB
> > cable into a host PC and bring up a terminal emulator at 115k baud,
> > 8N1. On linux the UART device is often ``/dev/ttyUSB0``.
> May be like this: "at 115200 baud, 8 data bits, 1 stop bit, no parity,
> and no flow control. On Linux the UART device is often
> ``/dev/ttyUSB0``."
> > +**Run a RTEMS application on the Renode.io simulator**
> > +RTEMS executables compiled with the kendrytek210 BSP can run on the
> > renode.io simulator using the built-in K210 model. The simulator
> > currently supports the console UART, interrupt controller, and timer.
> > +To install renode.io please refer to the instructions on the
> > website.
> Can we name the website with hyperlink or share the installation link "
> https://github.com/renode/renode#installation"
> Regards
> Padmarao
> > Once installed make a local copy of the ``kendryte_k210.resc``
> > script from the ``renode/scripts/single-node`` directory to a local
> > directory where it can be edited. Edit the script and change the line
> > that loads the Linux image to load a RTEMS elf image instead. The
> > default extension for the RTEMS sample ELF images is ``.exe``.
> > + sysbus LoadELF ticker.exe
> > +After editing the script, start renode and load the
> > kendryte_k210.resc script to start the emulation.
> > + (monitor) s @kendryte_k210.resc
> > +**Generating the Device Tree Header**
> > +The kendrytek210 BSP uses a built in device tree blob. If additional
> > peripheral support is added to the BSP, the device tree may need to
> > be updated. After editing the device tree source, compile it to a
> > device tree blob with the following command:
> > + $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
> > +The dtb file can then be converted to a C array using the rtems-
> > bin2c tool. The data for the device tree binary can then replace the
> > existing device tree binary data in the ``kendryte-k210-dtb.h``
> > header file.
> > noel
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230330/eacbb188/attachment-0001.htm>
