[PATCH v4 1/3] cpukit/flash: Add API for Flash devices
    aaron.nyholm at unfoldedeffective.com
    Mon May  1 01:43:01 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
 cpukit/dev/flash/flashdev.c         | 902 ++++++++++++++++++++++++++++
 cpukit/include/dev/flash/flashdev.h | 459 ++++++++++++++
 spec/build/cpukit/librtemscpu.yml   |   4 +
 3 files changed, 1365 insertions(+)
 create mode 100644 cpukit/dev/flash/flashdev.c
 create mode 100644 cpukit/include/dev/flash/flashdev.h
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
new file mode 100644
index 0000000000..30dfb0a9a4
--- /dev/null
+++ b/cpukit/dev/flash/flashdev.c
@@ -0,0 +1,902 @@
+ * Copyright (C) 2023 Aaron Nyholm
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <dev/flash/flashdev.h>
+#include <rtems/imfs.h>
+#include <rtems/score/assert.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <assert.h>
+#define RTEMS_FLASHDEV_REGION_ALLOC_FULL 0xFFFFFFFFUL
+#define RTEMS_FLASHDEV_REGION_UNDEFINED 0xFFFFFFFFUL
+#define RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH 32
+#define RTEMS_FLASHDEV_BITALLOC_LENGTH(t) \
+  (t->max_regions/RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH)
+#define RTEMS_FLASHDEV_BITALLOC_FINAL_BITS(t) \
+  (t->max_regions%RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH)
+static int rtems_flashdev_do_init(
+  rtems_flashdev *flash,
+  void ( *destroy )( rtems_flashdev *flash )
+static int rtems_flashdev_read_write(
+  rtems_libio_t *iop,
+  const void *write_buff,
+  void *read_buff,
+  size_t count
+static int rtems_flashdev_ioctl_erase(
+  void *arg
+static off_t rtems_flashdev_get_region_offset(
+static size_t rtems_flashdev_get_region_size(
+static int rtems_flashdev_ioctl_set_region(
+  void *arg
+static int rtems_flashdev_ioctl_create_region(
+  rtems_flashdev_region *region_in
+static int rtems_flashdev_ioctl_update_region(
+static int rtems_flashdev_ioctl_clear_region(
+static uint32_t rtems_flashdev_ioctl_jedec_id(
+static uint32_t rtems_flashdev_ioctl_flash_type(
+  void *arg
+static int rtems_flashdev_ioctl_pageinfo_offset(
+  void *arg
+static int rtems_flashdev_ioctl_pageinfo_index(
+  void *arg
+static int rtems_flashdev_ioctl_page_count(
+  void *arg
+static int rtems_flashdev_ioctl_write_block_size(
+  void *arg
+static int rtems_flashdev_get_addr(
+  size_t count,
+  off_t *addr
+static int rtems_flashdev_update_and_return(
+  int status,
+  size_t count,
+  off_t new_offset
+static uint32_t rtems_flashdev_find_unallocated_region(
+  rtems_flashdev_region_table *region_table
+static uint32_t rtems_flashdev_set_region(
+  rtems_flashdev_region_table *region_table,
+  int index
+static uint32_t rtems_flashdev_unset_region(
+  int index
+static uint32_t rtems_flashdev_check_allocation(
+  int index
+static int rtems_flashdev_open(
+  const char *path,
+  int oflag,
+  mode_t mode
+static int rtems_flashdev_close(
+static ssize_t rtems_flashdev_read(
+  void *buffer,
+  size_t count
+static ssize_t rtems_flashdev_write(
+  const void *buffer,
+  size_t count
+static int rtems_flashdev_ioctl(
+  ioctl_command_t command,
+  void *arg
+static off_t rtems_flashdev_lseek(
+  off_t offset,
+  int whence
+static void rtems_flashdev_node_destroy(
+  IMFS_jnode_t *node
+static const rtems_filesystem_file_handlers_r rtems_flashdev_handler = {
+  .open_h = rtems_flashdev_open,
+  .close_h = rtems_flashdev_close,
+  .read_h = rtems_flashdev_read,
+  .write_h = rtems_flashdev_write,
+  .ioctl_h = rtems_flashdev_ioctl,
+  .lseek_h = rtems_flashdev_lseek,
+  .fstat_h = IMFS_stat,
+  .ftruncate_h = rtems_filesystem_default_ftruncate,
+  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fcntl_h = rtems_filesystem_default_fcntl,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .mmap_h = rtems_filesystem_default_mmap,
+  .poll_h = rtems_filesystem_default_poll,
+  .readv_h = rtems_filesystem_default_readv,
+  .writev_h = rtems_filesystem_default_writev };
+static const IMFS_node_control
+  rtems_flashdev_node_control = IMFS_GENERIC_INITIALIZER(
+    &rtems_flashdev_handler,
+    IMFS_node_initialize_generic,
+    rtems_flashdev_node_destroy
+  rtems_flashdev *flash;
+  flash = IMFS_generic_get_context_by_node( node );
+  ( *flash->destroy )( flash );
+  IMFS_node_destroy_default( node );
+static uint32_t rtems_flashdev_get_region_index(
+  return (uint32_t)iop->data0;
+static int rtems_flashdev_is_region_defined(
+  return (rtems_flashdev_get_region_index( iop ) != RTEMS_FLASHDEV_REGION_UNDEFINED);
+static void rtems_flashdev_set_region_index(
+  uint32_t index
+  iop->data0 = index;
+static int rtems_flashdev_check_offset_region(
+  off_t offset
+  if ( ( rtems_flashdev_is_region_defined( iop ) ) &&
+       ( offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+    rtems_set_errno_and_return_minus_one( EINVAL );
+  return 0;
+static void rtems_flashdev_obtain( rtems_flashdev *flash )
+  rtems_recursive_mutex_lock( &flash->mutex );
+static void rtems_flashdev_release( rtems_flashdev *flash )
+  rtems_recursive_mutex_unlock( &flash->mutex );
+  void *buffer,
+  size_t count
+  return rtems_flashdev_read_write( iop, NULL, buffer, count );
+  size_t count
+  return rtems_flashdev_read_write( iop, buffer, NULL, count);
+  void *read_buff,
+  size_t count
+  rtems_flashdev *flash = IMFS_generic_get_context_by_iop( iop );
+  off_t addr;
+  int status;
+  if ( read_buff == NULL && write_buff == NULL ) {
+    return 0;
+  /* Get flash address */
+  status = rtems_flashdev_get_addr( flash, iop, count, &addr );
+  if ( status < 0 ) {
+    return status;
+  /* Read or Write to flash */
+  rtems_flashdev_obtain( flash );
+  if ( read_buff != NULL ) {
+    status = ( *flash->read )( flash, addr, count, read_buff );
+  } else if ( write_buff != NULL ) {
+    status = ( *flash->write )( flash, addr, count, write_buff );
+  rtems_flashdev_release( flash );
+  /* Update offset and return */
+  return rtems_flashdev_update_and_return( iop, status, count, addr + count );
+  void *arg
+  int err = 0;
+  switch ( command ) {
+    case RTEMS_FLASHDEV_IOCTL_OBTAIN:
+      err = 0;
+      break;
+    case RTEMS_FLASHDEV_IOCTL_RELEASE:
+      err = 0;
+      break;
+    case RTEMS_FLASHDEV_IOCTL_JEDEC_ID:
+      *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
+      err = 0;
+      break;
+    case RTEMS_FLASHDEV_IOCTL_ERASE:
+      err = rtems_flashdev_ioctl_erase( flash, iop, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_REGION_SET:
+      err = rtems_flashdev_ioctl_set_region( flash, iop, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_REGION_UNSET:
+      err = rtems_flashdev_ioctl_clear_region( flash, iop );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_TYPE:
+      err = rtems_flashdev_ioctl_flash_type( flash, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET:
+      err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX:
+      err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_PAGE_COUNT:
+      err = rtems_flashdev_ioctl_page_count( flash, arg );
+      break;
+    case RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE:
+      err = rtems_flashdev_ioctl_write_block_size( flash, arg );
+      break;
+  if ( err != 0 ) {
+    rtems_set_errno_and_return_minus_one( err );
+  } else {
+    return 0;
+  off_t offset,
+  int whence
+  off_t tmp_offset;
+  if ( offset < 0 ) {
+  switch ( whence ) {
+    case SEEK_CUR:
+      tmp_offset = iop->offset + offset;
+      break;
+    case SEEK_SET:
+      tmp_offset = offset;
+      break;
+    case SEEK_END:
+    default:
+  if ( ( rtems_flashdev_is_region_defined(iop) ) &&
+       ( tmp_offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+  iop->offset = tmp_offset;
+  return iop->offset;
+  rtems_flashdev_ioctl_clear_region( flash, iop );
+  return rtems_filesystem_default_close( iop );
+  const char *path,
+  int oflag,
+  mode_t mode
+  int ret = rtems_filesystem_default_open( iop, path, oflag, mode );
+  rtems_flashdev_set_region_index(iop, RTEMS_FLASHDEV_REGION_UNDEFINED);
+  return ret;
+int rtems_flashdev_register(
+  const char *flash_path
+  int rv;
+  rtems_flashdev_region_table *table = flash->region_table;
+  int alloc_array_len;
+  rv = IMFS_make_generic_node(
+    flash_path,
+    S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+    &rtems_flashdev_node_control,
+    flash
+  if ( rv != 0 ) {
+  alloc_array_len = RTEMS_FLASHDEV_BITALLOC_LENGTH(table) +
+    ((RTEMS_FLASHDEV_BITALLOC_FINAL_BITS(table)) != 0);
+  memset(table->bit_allocator, 0, alloc_array_len);
+  return rv;
+  rtems_recursive_mutex_init( &flash->mutex, "RTEMS_FLASHDEV Flash" );
+  flash->destroy = destroy;
+  flash->read = NULL;
+  flash->write = NULL;
+  flash->erase = NULL;
+  flash->jedec_id = NULL;
+  flash->flash_type = NULL;
+  flash->page_info_by_offset = NULL;
+  flash->page_info_by_index = NULL;
+  flash->page_count = NULL;
+  flash->write_block_size = NULL;
+  flash->region_table = NULL;
+  return 0;
+void rtems_flashdev_destroy( rtems_flashdev *flash )
+  rtems_recursive_mutex_destroy( &flash->mutex );
+void rtems_flashdev_destroy_and_free( rtems_flashdev *flash )
+  if ( flash == NULL ) {
+    return;
+  rtems_recursive_mutex_destroy( &( flash->mutex ) );
+  free( flash );
+  flash = NULL;
+  return;
+int rtems_flashdev_init( rtems_flashdev *flash )
+  memset( flash, 0, sizeof( *flash ) );
+  return rtems_flashdev_do_init( flash, rtems_flashdev_destroy );
+rtems_flashdev *rtems_flashdev_alloc_and_init( size_t size )
+  rtems_flashdev *flash = NULL;
+  if ( size >= sizeof( *flash ) ) {
+    flash = calloc( 1, size );
+    if ( flash != NULL ) {
+      int rv;
+      rv = rtems_flashdev_do_init( flash, rtems_flashdev_destroy_and_free );
+      if ( rv != 0 ) {
+        free( flash );
+        return NULL;
+  return flash;
+  size_t count,
+  off_t *addr
+  off_t new_offset;
+  /* Check address is in valid region */
+  new_offset = iop->offset + count;
+  if (rtems_flashdev_check_offset_region(flash, iop, new_offset)) {
+    return -1;
+  /* Get address for operation */
+  if ( !rtems_flashdev_is_region_defined( iop ) ) {
+    *addr = iop->offset;
+  } else {
+    *addr = ( iop->offset + rtems_flashdev_get_region_offset( flash, iop ) );
+  return 0;
+  int status,
+  size_t count,
+  off_t new_offset
+  if ( status == 0 ) {
+    iop->offset = new_offset;
+    return count;
+  } else {
+    rtems_set_errno_and_return_minus_one( status );
+  void *arg
+  rtems_flashdev_region *erase_args_1;
+  off_t check_offset;
+  int status;
+  if ( flash->erase == NULL ) {
+    return 0;
+  erase_args_1 = (rtems_flashdev_region *) arg;
+  /* Check erasing valid region */
+  check_offset = erase_args_1->offset + erase_args_1->size;
+  if ( rtems_flashdev_is_region_defined( iop ) && (
+         rtems_flashdev_check_offset_region(flash, iop, check_offset) ||
+         ( erase_args_1->offset <
+           rtems_flashdev_get_region_offset( flash, iop ) ) ) ) {
+  /* Erase flash */
+  status = ( *flash->erase )( flash, erase_args_1->offset, erase_args_1->size );
+  return status;
+  void *arg
+  rtems_flashdev_region *region_in;
+  region_in = (rtems_flashdev_region *) arg;
+  if (flash->region_table == NULL) {
+    rtems_set_errno_and_return_minus_one( ENOMEM );
+    if (
+      rtems_flashdev_find_unallocated_region(table)
+        == RTEMS_FLASHDEV_REGION_ALLOC_FULL
+      /* New region to allocate and all regions allocated */
+    } else {
+      /* New region to allocate and space to allocate region */
+      return rtems_flashdev_ioctl_create_region( flash, iop, region_in );
+  } else {
+    /* Updating existing region */
+    return rtems_flashdev_ioctl_update_region( flash, iop, region_in );
+  int i;
+  /* Find unallocated region slot */
+  i = rtems_flashdev_find_unallocated_region(flash->region_table);
+  if (i == RTEMS_FLASHDEV_REGION_ALLOC_FULL) {
+  /* Set region values */
+  table->regions[ i ].offset = region_in->offset;
+  table->regions[ i ].size = region_in->size;
+  /* Set region as allocated and link iop */
+  rtems_flashdev_set_region(flash->region_table, i);
+  rtems_flashdev_set_region_index( iop, i );
+  return 0;
+  uint32_t region_index = rtems_flashdev_get_region_index( iop );
+   * If region index is larger then maximum region index or region
+   * index at given index is undefined return an error.
+  if (
+       ( region_index >= flash->region_table->max_regions ) ||
+       ( rtems_flashdev_check_allocation( table, region_index ) == 0)
+  table->regions[ region_index ].offset = region_in->offset;
+  table->regions[ region_index ].size = region_in->size;
+  return 0;
+  /* Check region to clear */
+  if ( region_index == RTEMS_FLASHDEV_REGION_UNDEFINED ) {
+  /* Clear region */
+  rtems_flashdev_unset_region( flash->region_table, region_index );
+  rtems_flashdev_set_region_index( iop, RTEMS_FLASHDEV_REGION_UNDEFINED );
+  return 0;
+  /* Region is already checked to be defined */
+  assert( rtems_flashdev_get_region_index( iop ) != RTEMS_FLASHDEV_REGION_UNDEFINED );
+  return table->regions[ rtems_flashdev_get_region_index( iop ) ].offset;
+  return table->regions[ rtems_flashdev_get_region_index( iop ) ].size;
+static uint32_t rtems_flashdev_ioctl_jedec_id( rtems_flashdev *flash )
+  if ( flash->jedec_id == NULL ) {
+    return 0;
+  } else {
+    return ( *flash->jedec_id )( flash );
+  void *arg
+  rtems_flashdev_flash_type *type = (rtems_flashdev_flash_type*)arg;
+  if ( flash->flash_type == NULL ) {
+    return 0;
+  } else {
+    return ( *flash->flash_type )( flash, type );
+  void *arg
+  rtems_flashdev_ioctl_page_info *page_info;
+  if ( arg == NULL ) {
+  if ( flash->page_info_by_offset == NULL ) {
+    return 0;
+  } else {
+    page_info = (rtems_flashdev_ioctl_page_info *) arg;
+    return ( *flash->page_info_by_offset )( flash,
+                                         page_info->location,
+                                         &page_info->page_info.offset,
+                                         &page_info->page_info.size );
+static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
+                                                void *arg )
+  if ( flash->page_info_by_index == NULL ) {
+    return 0;
+  } else {
+    return ( *flash->page_info_by_index )( flash,
+static int rtems_flashdev_ioctl_page_count( rtems_flashdev *flash, void *arg )
+  if ( flash->page_count == NULL ) {
+    return 0;
+  } else {
+    return ( *flash->page_count )( flash, ( (int *) arg ) );
+  void *arg
+  if ( flash->write_block_size == NULL ) {
+    return 0;
+  } else {
+    return ( *flash->write_block_size )( flash, ( (size_t *) arg ) );
+  int array_index = 0;
+  int bit_index = 0;
+  int shift;
+  while ( bit_index < region_table->max_regions) {
+    /* Get uint32_t holding the ith bit */
+    array_index = bit_index / RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+    shift = bit_index % RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+    /* Check if region available in next BITALLOC_LENGTH regions */
+    if (
+        (shift == 0) &&
+        (region_table->bit_allocator[ array_index ] == RTEMS_FLASHDEV_REGION_ALLOC_FULL)
+      bit_index = bit_index + RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+      continue;
+    /* Check individual bit */
+    if ( ! ( ( ( region_table->bit_allocator[ array_index ] ) >> shift ) & 1UL ) ) {
+      return bit_index;
+    bit_index++;
+  return RTEMS_FLASHDEV_REGION_ALLOC_FULL;
+  int index
+  int array_index = index / RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+  int shift = index % RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+  region_table->bit_allocator[ array_index ] |= 1UL << shift;
+  return index;
+  int index
+  region_table->bit_allocator[ array_index ] &= ~( 1UL << shift );
+  return index;
+  int index
+  int shift = index%RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+  return ( ( region_table->bit_allocator[ array_index ] >> shift ) & 1UL );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 0000000000..a2b9bad4bd
--- /dev/null
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -0,0 +1,459 @@
+ * @file
+ * @ingroup Flash
+ * @brief Generic Flash API
+ * are met:
+#ifndef _DEV_FLASHDEV_H
+#define _DEV_FLASHDEV_H
+#include <rtems/thread.h>
+#include <sys/types.h>
+typedef struct rtems_flashdev rtems_flashdev;
+ * @defgroup Generic Flash API
+ * @ingroup RTEMSDeviceDrivers
+ * @brief Generic Flash API to wrap specific device drivers.
+/* IOCTL Calls */
+ * @brief Obtains the flash device.
+ * This command has no argument.
+#define RTEMS_FLASHDEV_IOCTL_OBTAIN 0
+ * @brief Releases the flash device.
+#define RTEMS_FLASHDEV_IOCTL_RELEASE 1
+ * @brief Returns the JEDEC ID of the flash device. This IOCTL call
+ * is informational only.
+ * @param[out] jedec_id Pointer to uint32_t in which the JEDEC ID is
+ * returned in.
+#define RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2
+ * @brief Erases flash device.
+ * @param[in] erase_args Pointer to rtems_flashdev_region struct
+ * containing offset and size of erase to be performed.
+#define RTEMS_FLASHDEV_IOCTL_ERASE 3
+ * @brief Set a region that limits read, write and erase calls to within it.
+ * Regions are file descriptor specific and limited to a single region per
+ * file descriptor and 32 regions total per flash device. Regions can be
+ * changed or updated by calling this IOCTL again.
+ * @param[in] region Pointer to rtems_flashdev_region struct containing
+ * base and length of defined region.
+#define RTEMS_FLASHDEV_IOCTL_REGION_SET 4
+ * @brief Removes the set region on the file descriptor.
+#define RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5
+ * @brief Returns the type of flash device (e.g. NOR or NAND).
+ * @param[out] flash_type Pointer to integer which is set to the flash
+ * type macro value.
+#define RTEMS_FLASHDEV_IOCTL_TYPE 6
+ * @brief Get the size and address of flash page at given offset
+ * The offset ignores the region limiting. To find page of region
+ * limited offset add the base of the region to the desired offset.
+ * @param[in,out] rtems_flashdev_ioctl_page_info arg Pointer to struct
+ * with offset and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7
+ * @brief Get the size and address of nth flash page where n is index passed in.
+ * The index ignores the region limiting.
+ * with index and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8
+ * @brief Get the number of pages in flash device.
+ * @param[out] count Integer containing the number of pages.
+#define RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9
+ * @brief Get the minimum write size supported by the driver.
+ * @param[out] count Integer containing the minimum write size.
+#define RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10
+ * @brief The maximum number of region limited file descriptors
+ * allowed to be open at once.
+#define RTEMS_FLASHDEV_MAX_REGIONS 32
+ * @brief Enum for flash type returned from IOCTL call.
+typedef enum rtems_flashdev_flash_type {
+   * @brief The flash device is NOR flash.
+  RTEMS_FLASHDEV_NOR,
+   * @brief The flash device is NAND flash.
+  RTEMS_FLASHDEV_NAND
+} rtems_flashdev_flash_type;
+ * @brief General definition for on flash device.
+typedef struct rtems_flashdev_region {
+   * @brief Base of region.
+  off_t offset;
+   * @brief Length of region.
+  size_t size;
+} rtems_flashdev_region;
+ * @brief Struct holding region definitions
+typedef struct rtems_flashdev_region_table {
+   * @brief The maximum regions that can be defined at once.
+  int max_regions;
+   * @brief Pointer to array of rtems_flashdev_region of length
+   * max_regions
+  rtems_flashdev_region* regions;
+   * @brief Array of uint32_t acting as bit allocator
+   * for regions array.
+  uint32_t *bit_allocator;
+} rtems_flashdev_region_table;
+ * @brief Page information returned from IOCTL calls.
+typedef struct rtems_flashdev_ioctl_page_info {
+   * @brief Offset or index to find page at.
+  off_t location;
+   * @brief Information returned about the page. Including the
+   * base offset and size of page.
+  rtems_flashdev_region page_info;
+} rtems_flashdev_ioctl_page_info;
+ * @brief Flash device.
+struct rtems_flashdev {
+   * @brief Call to the device driver to read the flash device.
+   * @param[in] flash Pointer to flash device.
+   * @param[in] offset Address to read from.
+   * @param[in] count Number of bytes to read.
+   * @param[out] buffer Buffer for data to be read into.
+   * @retval 0 Successful operation.
+   * @retval 1 Failed operation.
+  int ( *read )(
+    uintptr_t offset,
+    size_t count,
+    void *buffer
+   * @brief Call to the device driver to write to the flash device.
+   * @param[in] offset Address to write to.
+   * @param[in] buffer Buffer for data to be written from.
+  int ( *write )(
+    uintptr_t offset,
+    size_t count,
+   * @brief Call to the device driver to erase the flash device.
+   * @param[in] offset Address to erase at.
+   * @param[in] count Number of bytes to erase.
+  int ( *erase )(
+    uintptr_t offset,
+    size_t count
+   * @brief Call to the device driver to return the JEDEC ID.
+   * @param[in] flash The flash device.
+   * @retval JEDEC ID.
+  uint32_t ( *jedec_id )(
+   * @brief Call to the device driver to return the flash type.
+   * @param[out] type The type of flash device.
+   * @retbal Other Failure
+  int ( *flash_type )(
+   * @brief Call to device driver to get size and offset of page at
+   * given offset.
+   * @param[in] search_offset The offset of the page which info is to be
+   * returned.
+   * @param[out] page_offset The offset of the start of the page
+   * @param[out] page_size The size of the page
+   * @retval 0 Success.
+   * @retval non-zero Failed.
+  int ( *page_info_by_offset )(
+    off_t search_offset,
+    off_t *page_offset,
+    size_t *page_size
+   * given index.
+   * @param[in] search_index The index of the page which info is to be returned.
+  int ( *page_info_by_index )(
+    rtems_flashdev *flashdev,
+    off_t search_index,
+    size_t *page_size
+   * @brief Call to device driver to return the number of pages on the flash
+   * device.
+   * @param[out] page_count The number of pages on the flash device.
+  int ( *page_count )(
+    int *page_count
+   * @brief Call to device driver to return the minimum write size of the
+   * flash device.
+   * @param[out] write_block_size The minimum write size of the flash device.
+  int ( *write_block_size )(
+    size_t *write_block_size
+   * @brief Destroys the flash device.
+   * @brief Pointer to device driver.
+  void *driver;
+   * @brief Mutex to protect the flash device access.
+  rtems_recursive_mutex mutex;
+   * @brief Region table defining size and memory for region allocations
+  rtems_flashdev_region_table *region_table;
+ * @brief Allocate and initialize the flash device.
+ * After a successful allocation and initialization of the flash device
+ * it must be destroyed via rtems_flashdev_destroy_and_free().
+ * @param[in] size The number of bytes to allocate.
+ * @retval NULL Failed to set up flash device.
+ * @retval non-NULL The new flash device.
+  size_t size
+ * @brief Initialize the flash device.
+ * After a successful initialization of the flash device it must be
+ * destroyed via rtems_flashdev_destory().
+ * After initialization and before registration read, write, erase, jedec_id
+ * and flash_type functions need to be set in the flashdev.
+ * @param[in] flash The flash device to initialize.
+ * @retval 1 Failed to set up flash device.
+ * @retval 0 Successful set up of flash device.
+ * @brief Register the flash device.
+ * This function always claims ownership of the flash device.
+ * @param[in] flash_path The path to the flash device file.
+ * @retval non-zero Failed operation.
+ * @brief Destroys the flash device and frees its memory.
+#endif /* _DEV_FLASHDEV_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index e80be5ebf0..e4a9351c93 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -52,6 +52,9 @@ install:
 - destination: ${BSP_INCLUDEDIR}/dev/spi
   source:
   - cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/flash
+  source:
+  - cpukit/include/dev/flash/flashdev.h
 - destination: ${BSP_INCLUDEDIR}/dev/can
   source:
   - cpukit/include/dev/can/can.h
@@ -522,6 +525,7 @@ links:
 - role: build-dependency
   uid: vckey
 source:
+- cpukit/dev/flash/flashdev.c
 - cpukit/dev/i2c/eeprom.c
 - cpukit/dev/i2c/fpga-i2c-slave.c
 - cpukit/dev/i2c/gpio-nxp-pca9535.c
2.25.1
