[PATCH rtems 07/12] bsps/shared: Fix header for fsl-edma
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu May 4 15:00:48 UTC 2023
If a different chip variant is used in the i.mxrt BSP, a different
header would have to be included. Make sure that the fsl-edma driver
uses a header that doesn't have to be adapted.
bsps/shared/dev/dma/fsl-edma.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/shared/dev/dma/fsl-edma.c b/bsps/shared/dev/dma/fsl-edma.c
index b3e1bb2fc5..3cb91c14e6 100644
--- a/bsps/shared/dev/dma/fsl-edma.c
+++ b/bsps/shared/dev/dma/fsl-edma.c
@@ -40,7 +40,7 @@
#include <bsp/fatal.h>
#include <bsp/irq.h>
#ifdef LIBBSP_ARM_IMXRT_BSP_H
-#include <MIMXRT1052.h>
+#include <fsl_device_registers.h>
#endif
#define EDMA_CHANNELS_PER_GROUP 32U
2.35.3
