[PATCH rtems 08/12] bsps/imxrt: Remove unmaintained defines
Christian Mauderer christian.mauderer at embedded-brains.de
Thu May 4 15:00:49 UTC 2023
The defines for the different clock frequencies in the
fsl_clock_config.h do not represent the clock frequencies that have been
set up in the registers. Remove them to avoid someone trusting in
correct values.
 bsps/arm/imxrt/include/fsl_clock_config.h     | 58 +------------------
 .../nxp/boards/evkbimxrt1050/clock_config.c   |  2 +-
 2 files changed, 4 insertions(+), 56 deletions(-)
diff --git a/bsps/arm/imxrt/include/fsl_clock_config.h b/bsps/arm/imxrt/include/fsl_clock_config.h
index f213ac7e23..5c09daf59d 100644
--- a/bsps/arm/imxrt/include/fsl_clock_config.h
+++ b/bsps/arm/imxrt/include/fsl_clock_config.h
@@ -8,6 +8,7 @@
 #ifndef _CLOCK_CONFIG_H_
 #define _CLOCK_CONFIG_H_
+#include <bspopts.h>
 #include "fsl_common.h"
@@ -34,61 +35,7 @@ void BOARD_InitBootClocks(void);
 #endif /* __cplusplus*/
- ********************** Configuration BOARD_BootClockRUN ***********************
- * Definitions for BOARD_BootClockRUN configuration
-#define BOARD_BOOTCLOCKRUN_CORE_CLOCK 600000000U /*!< Core clock frequency: 600000000Hz */
-/* Clock outputs (values are in Hz): */
-#define BOARD_BOOTCLOCKRUN_AHB_CLK_ROOT 600000000UL
-#define BOARD_BOOTCLOCKRUN_CAN_CLK_ROOT 40000000UL
-#define BOARD_BOOTCLOCKRUN_CKIL_SYNC_CLK_ROOT 32768UL
-#define BOARD_BOOTCLOCKRUN_CLKO1_CLK 0UL
-#define BOARD_BOOTCLOCKRUN_CLKO2_CLK 0UL
-#define BOARD_BOOTCLOCKRUN_CLK_1M 1000000UL
-#define BOARD_BOOTCLOCKRUN_CLK_24M 24000000UL
-#define BOARD_BOOTCLOCKRUN_CSI_CLK_ROOT 12000000UL
-#define BOARD_BOOTCLOCKRUN_ENET1_TX_CLK 2400000UL
-#define BOARD_BOOTCLOCKRUN_ENET_125M_CLK 2400000UL
-#define BOARD_BOOTCLOCKRUN_ENET_25M_REF_CLK 1200000UL
-#define BOARD_BOOTCLOCKRUN_FLEXIO1_CLK_ROOT 30000000UL
-#define BOARD_BOOTCLOCKRUN_FLEXIO2_CLK_ROOT 30000000UL
-#define BOARD_BOOTCLOCKRUN_FLEXSPI_CLK_ROOT 160000000UL
-#define BOARD_BOOTCLOCKRUN_GPT1_IPG_CLK_HIGHFREQ 75000000UL
-#define BOARD_BOOTCLOCKRUN_GPT2_IPG_CLK_HIGHFREQ 75000000UL
-#define BOARD_BOOTCLOCKRUN_IPG_CLK_ROOT 150000000UL
-#define BOARD_BOOTCLOCKRUN_LCDIF_CLK_ROOT 9642857UL
-#define BOARD_BOOTCLOCKRUN_LPI2C_CLK_ROOT 60000000UL
-#define BOARD_BOOTCLOCKRUN_LPSPI_CLK_ROOT 105600000UL
-#define BOARD_BOOTCLOCKRUN_LVDS1_CLK 1200000000UL
-#define BOARD_BOOTCLOCKRUN_MQS_MCLK 63529411UL
-#define BOARD_BOOTCLOCKRUN_PERCLK_CLK_ROOT 75000000UL
-#define BOARD_BOOTCLOCKRUN_PLL7_MAIN_CLK 24000000UL
-#define BOARD_BOOTCLOCKRUN_SAI1_CLK_ROOT 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI1_MCLK1 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI1_MCLK2 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI1_MCLK3 30000000UL
-#define BOARD_BOOTCLOCKRUN_SAI2_CLK_ROOT 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI2_MCLK1 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI2_MCLK2 0UL
-#define BOARD_BOOTCLOCKRUN_SAI2_MCLK3 30000000UL
-#define BOARD_BOOTCLOCKRUN_SAI3_CLK_ROOT 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI3_MCLK1 63529411UL
-#define BOARD_BOOTCLOCKRUN_SAI3_MCLK2 0UL
-#define BOARD_BOOTCLOCKRUN_SAI3_MCLK3 30000000UL
-#define BOARD_BOOTCLOCKRUN_SEMC_CLK_ROOT 75000000UL
-#define BOARD_BOOTCLOCKRUN_SPDIF0_CLK_ROOT 30000000UL
-#define BOARD_BOOTCLOCKRUN_SPDIF0_EXTCLK_OUT 0UL
-#define BOARD_BOOTCLOCKRUN_TRACE_CLK_ROOT 117333333UL
-#define BOARD_BOOTCLOCKRUN_UART_CLK_ROOT 80000000UL
-#define BOARD_BOOTCLOCKRUN_USBPHY1_CLK 0UL
-#define BOARD_BOOTCLOCKRUN_USBPHY2_CLK 0UL
-#define BOARD_BOOTCLOCKRUN_USDHC1_CLK_ROOT 198000000UL
-#define BOARD_BOOTCLOCKRUN_USDHC2_CLK_ROOT 198000000UL
+#if IMXRT_IS_MIMXRT10xx
 /*! @brief Arm PLL set for BOARD_BootClockRUN configuration.
 extern const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN;
@@ -98,6 +45,7 @@ extern const clock_usb_pll_config_t usb1PllConfig_BOARD_BootClockRUN;
 /*! @brief Sys PLL for BOARD_BootClockRUN configuration.
 extern const clock_sys_pll_config_t sysPllConfig_BOARD_BootClockRUN;
+#endif
  * API for BOARD_BootClockRUN configuration
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
index 4ab5216ee1..8f6980d0ef 100644
--- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
+++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
@@ -487,5 +487,5 @@ void BOARD_BootClockRUN(void)
     /* Set GPT2 High frequency reference clock source. */
     IOMUXC_GPR->GPR5 &= ~IOMUXC_GPR_GPR5_VREF_1M_CLK_GPT2_MASK;
     /* Set SystemCoreClock variable. */
-    SystemCoreClock = BOARD_BOOTCLOCKRUN_CORE_CLOCK;
+    SystemCoreClock = 600000000U;
2.35.3
