[PATCH 12/12] eng: Make design group identifiers optional
Sebastian Huber
Fri May 5 08:46:09 UTC 2023
Update #3715.
eng/req/items.rst | 22 +++++++++++++++++++---
1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 6ff7dee..783800f 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -1992,7 +1992,8 @@ software source code. All explicit attributes shall be specified. The explicit
attributes for this type are:
identifier
- The attribute value shall be an :ref:`SpecTypeInterfaceGroupIdentifier`.
+ The attribute value shall be a
+ :ref:`SpecTypeRequirementDesignGroupIdentifier`.
.. _SpecTypeDesignTargetItemType:
@@ -4361,8 +4362,6 @@ The value shall match with the regular expression "``^[A-Z][a-zA-Z0-9]*$``".
This type is used by the following types:
-* :ref:`SpecTypeDesignGroupRequirementItemType`
* :ref:`SpecTypeInterfaceGroupItemType`
.. _SpecTypeInterfaceGroupMembershipLinkRole:
@@ -4715,6 +4714,23 @@ This type refines the :ref:`SpecTypeLink` through the ``role`` attribute if the
value is ``proxy-member``. It defines the proxy member role of links. Items
may use this role to link to :ref:`SpecTypeProxyItemTypes` items.
+.. _SpecTypeRequirementDesignGroupIdentifier:
+Requirement Design Group Identifier
+A value of this type shall be of one of the following variants:
+* There may be no value (null).
+* The value may be a string. It shall be the identifier of the requirement
+ design group. The value shall match with the regular expression
+ "``^[a-zA-Z0-9_]*$``".
+This type is used by the following types:
+* :ref:`SpecTypeDesignGroupRequirementItemType`
.. _SpecTypeRequirementRefinementLinkRole:
Requirement Refinement Link Role
2.35.3
