[PATCH 00/12] Update documentation of specification items
Gedare Bloom
gedare at rtems.org
Fri May 5 14:07:02 UTC 2023
these look ok. I'll leave the register one for Chris to comment.
On Fri, May 5, 2023 at 2:46 AM Sebastian Huber
> Sebastian Huber (12):
> eng: Rework performance meansurement items
> eng: Generalize external references
> eng: Add conditional build dependencies
> eng: Use type refinement for validation method
> eng: Add optional floating-point number type
> eng: Update application configuration how-to
> eng: Remove obsolete type listing
> eng: Add design target item type
> eng: Add proxy item type
> eng: Remove ambiguous interface types
> eng: Add an item type for not defined defines
> eng: Make design group identifiers optional
> eng/glossary.rst | 3 +
> eng/req/howto.rst | 54 +++----
> eng/req/items.rst | 384 ++++++++++++++++++++++++++++++++--------------
> 3 files changed, 296 insertions(+), 145 deletions(-)
> 2.35.3
> devel mailing list
> devel at rtems.org
