[PATCH 08/12] eng: Add design target item type
Sebastian Huber
Fri May 5 08:46:05 UTC 2023
Update #3715.
eng/req/items.rst | 25 +++++++++++++++++++++++++
1 file changed, 25 insertions(+)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 34b04a5..e51072b 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -111,6 +111,8 @@ The specification item types have the following hierarchy:
* :ref:`SpecTypeDesignGroupRequirementItemType`
+ * :ref:`SpecTypeDesignTargetItemType`
* :ref:`SpecTypeGenericNonFunctionalRequirementItemType`
* :ref:`SpecTypeRuntimeMeasurementEnvironmentItemType`
@@ -1951,6 +1953,8 @@ This type is refined by the following types:
+* :ref:`SpecTypeDesignTargetItemType`
@@ -1975,6 +1979,27 @@ attributes for this type are:
identifier
The attribute value shall be an :ref:`SpecTypeInterfaceGroupIdentifier`.
+.. _SpecTypeDesignTargetItemType:
+Design Target Item Type
+This type refines the :ref:`SpecTypeNonFunctionalRequirementItemType` through
+the ``non-functional-type`` attribute if the value is ``design-target``. This
+set of attributes specifies a design :term:`target`. All explicit attributes
+shall be specified. The explicit attributes for this type are:
+brief
+ The attribute value shall be an optional string. If the value is present,
+ then it shall briefly describe the target.
+description
+ then it shall thoroughly describe the target.
+name
+ The attribute value shall be a string. It shall be the target name.
.. _SpecTypeGenericNonFunctionalRequirementItemType:
Generic Non-Functional Requirement Item Type
2.35.3
