[PATCH 09/12] eng: Add proxy item type
    Sebastian Huber
    Fri May  5 08:46:06 UTC 2023
Update #3715.
 eng/req/items.rst | 29 +++++++++++++++++++++++++++++
 1 file changed, 29 insertions(+)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index e51072b..ce6a435 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -99,6 +99,8 @@ The specification item types have the following hierarchy:
     * :ref:`SpecTypeInterfaceVariableItemType`
+  * :ref:`SpecTypeProxyItemTypes`
   * :ref:`SpecTypeRequirementItemType`
     * :ref:`SpecTypeFunctionalRequirementItemType`
@@ -193,6 +195,8 @@ This type is refined by the following types:
 * :ref:`SpecTypeInterfaceItemType`
+* :ref:`SpecTypeProxyItemTypes`
 * :ref:`SpecTypeRequirementValidationItemType`
@@ -1607,6 +1611,20 @@ name
 notes
     The attribute value shall be an :ref:`SpecTypeInterfaceNotes`.
+.. _SpecTypeProxyItemTypes:
+Proxy Item Types
+This type refines the :ref:`SpecTypeRootItemType` through the ``type``
+attribute if the value is ``proxy``. Items of similar characteristics may link
+to a proxy item through links with the :ref:`SpecTypeProxyMemberLinkRole`.  A
+proxy item resolves to the first member item which is enabled.  Proxies may be
+used to provide an interface with a common name and implementations which
+depend on configuration options.  For example, in one configuration a constant
+could be a compile time constant and in another configuration it could be a
+read-only object.
 .. _SpecTypeRequirementItemType:
 Requirement Item Type
@@ -4575,6 +4593,8 @@ This type is refined by the following types:
 * :ref:`SpecTypePlacementOrderLinkRole`
+* :ref:`SpecTypeProxyMemberLinkRole`
 * :ref:`SpecTypeRequirementRefinementLinkRole`
 * :ref:`SpecTypeRequirementValidationLinkRole`
@@ -4689,6 +4709,15 @@ value is ``placement-order``. This link role defines the placement order of
 items in a container item (for example an interface function in a header file
 or a documentation section).
+.. _SpecTypeProxyMemberLinkRole:
+Proxy Member Link Role
+This type refines the :ref:`SpecTypeLink` through the ``role`` attribute if the
+value is ``proxy-member``. It defines the proxy member role of links.  Items
+may use this role to link to :ref:`SpecTypeProxyItemTypes` items.
 .. _SpecTypeRequirementRefinementLinkRole:
 Requirement Refinement Link Role
2.35.3
