[PATCH 3/3] basedefs.h: Improve formatting
    Sebastian Huber
    Mon May  8 20:08:27 UTC 2023
 cpukit/include/rtems/score/basedefs.h | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index f01454a24b..bfc45f60c6 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -432,7 +432,7 @@ extern "C" {
  * @brief Gets the pointer reference type.
- * @param _level is the pointer indirection level expressed in *.
+ * @param _level is the pointer indirection level expressed in ``*``.
  * @param _target is the reference target type.
@@ -511,7 +511,7 @@ extern "C" {
  * @brief Performs a type cast which removes qualifiers without warnings to the
  *   type for the variable.
- * @param _ptr_level is the pointer indirection level expressed in *.
+ * @param _ptr_level is the pointer indirection level expressed in ``*``.
  * @param _type is the target type of the cast.
2.35.3
