[PATCH 00/10] Validation test improvements
Sebastian Huber
Mon May 8 20:11:51 UTC 2023
Sebastian Huber (10):
validation: Test the global construction
validation: Validate RTEMS_NO_TIMEOUT
validation: Fix typo
validation: Fix formatting
validation: Use spec:* references
validation: Add group for runtime measurements
validation: Improve formatting
validation: rtems_scheduler_get_maximum_priority()
validation: RTEMS_STATIC_ANALYSIS
.../testsuites/validation/objpreinitarray.yml | 16 ++
.../validation/validation-no-clock-0.yml | 2 +
testsuites/validation/tc-acfg-one-cpu.c | 4 +-
testsuites/validation/tc-acfg.c | 15 +-
testsuites/validation/tc-attr.c | 4 +-
testsuites/validation/tc-barrier-ident.c | 4 +-
.../validation/tc-barrier-performance.c | 36 +++++
testsuites/validation/tc-basedefs.c | 146 +++++++----------
testsuites/validation/tc-clock-nanosleep.c | 4 +-
testsuites/validation/tc-event-performance.c | 42 +++++
testsuites/validation/tc-event-send-receive.c | 8 +-
testsuites/validation/tc-intr-vector-enable.c | 2 +-
testsuites/validation/tc-message-ident.c | 4 +-
.../validation/tc-message-performance.c | 62 ++++++++
testsuites/validation/tc-options.c | 4 +-
testsuites/validation/tc-part-ident.c | 4 +-
testsuites/validation/tc-part-performance.c | 26 +++
testsuites/validation/tc-preinit-array.c | 150 ++++++++++++++++++
testsuites/validation/tc-ratemon-ident.c | 4 +-
testsuites/validation/tc-scheduler-smp-only.c | 24 ++-
testsuites/validation/tc-score-thread.c | 49 ++++++
testsuites/validation/tc-sem-flush.c | 8 +-
testsuites/validation/tc-sem-ident.c | 4 +-
testsuites/validation/tc-sem-obtain.c | 34 ++--
testsuites/validation/tc-sem-performance.c | 70 ++++++++
testsuites/validation/tc-sem-release.c | 26 +--
testsuites/validation/tc-sem-timeout.c | 6 +-
testsuites/validation/tc-task-ident.c | 2 +-
testsuites/validation/tc-task-performance.c | 86 ++++++++++
testsuites/validation/tc-timer-ident.c | 4 +-
testsuites/validation/tc-type.c | 20 +++
testsuites/validation/tc-userext-ident.c | 4 +-
32 files changed, 709 insertions(+), 165 deletions(-)
create mode 100644 spec/build/testsuites/validation/objpreinitarray.yml
create mode 100644 testsuites/validation/tc-preinit-array.c
2.35.3
