[PATCH rtems v2 12/12] imx_iomux: Don't set reserved bits in PAD_CTL
    Christian Mauderer
    christian.mauderer at embedded-brains.de
    Tue May  9 12:10:59 UTC 2023
On most i.MX* the upper bits in SW_PAD_CTL are reserved. On some chips,
like the i.MXRT1166, they are a domain write protection. Setting them to
1 can have unexpected side effects.
The device tree uses these bits for some flags. Make sure that they are
not accidentally written to some value.
 bsps/arm/shared/pins/imx_iomux.c | 10 ++++++++++
 1 file changed, 10 insertions(+)
diff --git a/bsps/arm/shared/pins/imx_iomux.c b/bsps/arm/shared/pins/imx_iomux.c
index 1ff4186360..e6c604481a 100644
--- a/bsps/arm/shared/pins/imx_iomux.c
+++ b/bsps/arm/shared/pins/imx_iomux.c
@@ -307,7 +307,17 @@ int imx_iomux_configure_pins(const void *fdt, uint32_t cfgxref)
 		WR4(sc, cfg->mux_reg, cfg->mux_val | sion);
 		iomux_configure_input(sc, cfg->input_reg, cfg->input_val);
 		if ((cfg->padconf_val & PADCONF_NONE) == 0)
+#ifndef __rtems__
 			WR4(sc, cfg->padconf_reg, cfg->padconf_val);
+#else /* __rtems__ */
+			 * Need to mask the flags. On (for example) i.MXRT1166
+			 * they are used for domain write protection. On other
+			 * i.MX* these are Reserved.
+			WR4(sc, cfg->padconf_reg, cfg->padconf_val
+				& ~(PADCONF_SION | PADCONF_NONE));
+#endif /* __rtems__ */
 #ifndef __rtems__
 		if (bootverbose) {
 			char name[32];
2.35.3
