[PATCH rtems v2 00/12] bsp/imxrt: Update SDK and prepare for new variant
    Gedare Bloom
    gedare at rtems.org
    Mon May 15 13:53:23 UTC 2023
I'm fine with the v2 now, thanks for reducing it. Do feel free to
start a separate discussion / ticket about how we should handle HALs.
I think this problem will only get worse not better.
On Tue, May 9, 2023 at 6:11 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Hello,
> this is the second version of the patch set to update the SDK files in
> the i.MXRT BSPs. Like said in the earlier version: I plan to add a
> i.MXRT1166 based BSP soon.
> The changes are:
> - I now only imported the SDK files for i.MXRT1050 and i.MXRT1166. With
>   that the imported files (mainly first patch) are now only 18MB instead
>   of 90MB.
> - The script to import the files is now removed. I added a link to it in
>   the description of the import patch. I'll create a short note for the
>   documentation soon.
> - I added some minor fixes that I noted during further tests.
> The full version of the two big patches (1 and 3) can be found on this
> branch:
> https://gitlab.com/c-mauderer/rtems/-/commits/cm/20230509_imxrt/
> Best regards
> Christian
> devel mailing list
> devel at rtems.org
