[PATCH 00/12] Update documentation of specification items
    Chris Johns
    chrisj at rtems.org
    Mon May 15 03:12:33 UTC 2023
No issues here.
On 6/5/2023 12:07 am, Gedare Bloom wrote:
> these look ok. I'll leave the register one for Chris to comment.
> On Fri, May 5, 2023 at 2:46 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Sebastian Huber (12):
>>   eng: Rework performance meansurement items
>>   eng: Generalize external references
>>   eng: Add conditional build dependencies
>>   eng: Use type refinement for validation method
>>   eng: Add optional floating-point number type
>>   eng: Update application configuration how-to
>>   eng: Remove obsolete type listing
>>   eng: Add design target item type
>>   eng: Add proxy item type
>>   eng: Remove ambiguous interface types
>>   eng: Add an item type for not defined defines
>>   eng: Make design group identifiers optional
>>  eng/glossary.rst  |   3 +
>>  eng/req/howto.rst |  54 +++----
>>  eng/req/items.rst | 384 ++++++++++++++++++++++++++++++++--------------
>>  3 files changed, 296 insertions(+), 145 deletions(-)
>> 2.35.3
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
