[PATCH v4 2/3] libmisc/shell: Add flashdev command
Joel Sherrill
joel at rtems.org
Tue May 16 13:52:03 UTC 2023
Aaron,
Please look at my recent post to devel@ about new defects reported by
Coverity Scan. There are two in main_flashdev.c. One is really easy and
reflects a missing close(fd) on an error path. The other looks harder. I
don't see how flashdev ever gets set. Looks like a NULL is passed to a lot
of methods.
Please submit patches for each and include the CID number in the commit.
Thanks.
--joel
On Mon, May 1, 2023 at 12:20 AM <aaron.nyholm at unfoldedeffective.com> wrote:
> From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
> cpukit/include/rtems/shellconfig.h | 7 +
> cpukit/libmisc/shell/main_flashdev.c | 592 +++++++++++++++++++++++++++
> spec/build/cpukit/objshell.yml | 1 +
> 3 files changed, 600 insertions(+)
> create mode 100644 cpukit/libmisc/shell/main_flashdev.c
> diff --git a/cpukit/include/rtems/shellconfig.h
> b/cpukit/include/rtems/shellconfig.h
> index a013840ee7..489f281400 100644
> --- a/cpukit/include/rtems/shellconfig.h
> +++ b/cpukit/include/rtems/shellconfig.h
> @@ -98,6 +98,7 @@ extern rtems_shell_cmd_t rtems_shell_MD5_Command;
> extern rtems_shell_cmd_t rtems_shell_RTC_Command;
> extern rtems_shell_cmd_t rtems_shell_SPI_Command;
> +extern rtems_shell_cmd_t rtems_shell_FLASHDEV_Command;
> extern rtems_shell_cmd_t rtems_shell_I2CDETECT_Command;
> extern rtems_shell_cmd_t rtems_shell_I2CGET_Command;
> extern rtems_shell_cmd_t rtems_shell_I2CSET_Command;
> @@ -556,6 +557,12 @@ extern rtems_shell_alias_t * const
> rtems_shell_Initial_aliases[];
> &rtems_shell_SPI_Command,
> #endif
> + #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
> + && !defined(CONFIGURE_SHELL_NO_COMMAND_FLASHDEV)) \
> + || defined(CONFIGURE_SHELL_COMMAND_FLASHDEV)
> + &rtems_shell_FLASHDEV_Command,
> + #endif
> && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CDETECT)) \
> || defined(CONFIGURE_SHELL_COMMAND_I2CDETECT)
> diff --git a/cpukit/libmisc/shell/main_flashdev.c
> b/cpukit/libmisc/shell/main_flashdev.c
> new file mode 100644
> index 0000000000..5484e7d7f9
> --- /dev/null
> +++ b/cpukit/libmisc/shell/main_flashdev.c
> @@ -0,0 +1,592 @@
> + * Copyright (C) 2023 Aaron Nyholm
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <fcntl.h>
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <errno.h>
> +#include <rtems/shell.h>
> +#include <dev/flash/flashdev.h>
> +static int flashdev_shell_read(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_write(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_erase(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_type(char *dev_path);
> +static int flashdev_shell_jedecid(char *dev_path);
> +static int flashdev_shell_page_off(char *dev_path, int argc, char
> *argv[]);
> +static int flashdev_shell_page_idx(char *dev_path, int argc, char
> *argv[]);
> +static int flashdev_shell_pg_count(char *dev_path);
> +static int flashdev_shell_wb_size(char *dev_path);
> +static int flashdev_shell_ioctl_value(
> + char *dev_path,
> + int ioctl_call,
> + void *ret
> +static int flashdev_shell_page(
> + char *dev_path,
> + int argc,
> + char *argv[],
> + int ioctl_call
> +static const char rtems_flashdev_shell_usage [] =
> + "simple flash read / write / erase\n"
> + "\n"
> + "flashdev <FLASH_DEV_PATH> [OPTION]\n"
> + " -r <address> <bytes> Read at address for bytes\n"
> + " -w <address> <file> Write file to address\n"
> + " -e <address> <bytes> Erase at address for bytes\n"
> + " -t Print the flash type\n"
> + " -d Print the JEDEC ID of flash device\n"
> + " -o <address> Print the page information of page at
> address\n"
> + " -i <index> Print the page information of page at index\n"
> + " -p Print the number of pages\n"
> + " -b Print the write block size\n"
> + " -h Print this help\n";
> +static int rtems_flashdev_shell_main( int argc, char *argv[] ) {
> + char *dev_path = NULL;
> + int i;
> + for (i = 1; i < argc; ++i) {
> + if (argv[i][0] == '-') {
> + switch (argv[i][1]) {
> + case ('r'):
> + /* Read */
> + return flashdev_shell_read(dev_path, argc, &argv[i]);
> + case ('w'):
> + /* Write */
> + return flashdev_shell_write(dev_path, argc, &argv[i]);
> + case ('e'):
> + /* Erase */
> + return flashdev_shell_erase(dev_path, argc, &argv[i]);
> + case ('t'):
> + /* Flash Type */
> + return flashdev_shell_type(dev_path);
> + case ('d'):
> + /* JEDEC Id */
> + return flashdev_shell_jedecid(dev_path);
> + case ('o'):
> + /* Page info by offset */
> + return flashdev_shell_page_off(dev_path, argc, &argv[i]);
> + case ('i'):
> + /* Page info by index */
> + return flashdev_shell_page_idx(dev_path, argc, &argv[i]);
> + case ('p'):
> + /* Page count */
> + return flashdev_shell_pg_count(dev_path);
> + case ('b'):
> + /* Write block size */
> + return flashdev_shell_wb_size(dev_path);
> + //return flashdev_shell_pg_count(dev_path);
> + case ('h'):
> + default:
> + /* Help */
> + printf(rtems_flashdev_shell_usage);
> + break;
> + } else if (dev_path == NULL) {
> + dev_path = argv[i];
> + } else {
> + printf("Invalid argument: %s\n", argv[i]);
> + return 1;
> + if (argc == 1) {
> + return 0;
> +int flashdev_shell_read(
> + char *dev_path,
> + int argc,
> + char *argv[]
> + uint32_t address;
> + uint32_t bytes;
> + int fd;
> + int status;
> + void *buffer;
> + /* Check arguments */
> + if (argc < 5) {
> + printf("Missing argument\n");
> + return -1;
> + if (dev_path == NULL) {
> + printf("Please input FLASH_DEV_PATH before instruction\n");
> + return 1;
> + /* Get arguments */
> + errno = 0;
> + address = (uint32_t) strtoul(argv[1], NULL, 0);
> + if (errno != 0) {
> + printf("Could not read address\n");
> + errno = 0;
> + bytes = (uint32_t) strtoul(argv[2], NULL, 0);
> + if (errno != 0) {
> + /* Open flash device */
> + fd = open(dev_path, O_RDONLY);
> + if (fd == -1) {
> + printf("Couldn't open %s\n", dev_path);
> + return -1;
> + /* Move to address */
> + status = lseek(fd, address, SEEK_SET);
> + if (status == -1) {
> + printf("Reading failed\n");
> + close(fd);
> + return -1;
> + /* Create a buffer to read into */
> + buffer = calloc((bytes + bytes%4), 1);
> + if (buffer == NULL) {
> + printf("Failed to allocate read buffer\n");
> + return -1;
> + /* Read into buffer */
> + status = read(fd, buffer, bytes);
> + free(buffer);
> + close(fd);
> + return -1;
> + /* Print buffer out in 32bit blocks */
> + printf("Reading %s at 0x%08x for %d bytes\n", dev_path, address, bytes);
> + for (int i = 0; i < (bytes/4); i++) {
> + printf("%08x ", ((uint32_t*)buffer)[i]);
> + if ((i+1)%4 == 0) {
> + printf("\n");
> + printf("\n");
> + /* Clean up */
> + free(buffer);
> + close(fd);
> + return 0;
> +int flashdev_shell_write(
> + char *dev_path,
> + int argc,
> + char *argv[]
> + uint32_t address;
> + int flash;
> + int file;
> + int status;
> + int read_len;
> + off_t length;
> + void *buffer;
> + uint32_t offset;
> + char *file_path;
> + if (argc < 5) {
> + return -1;
> + return 1;
> + errno = 0;
> + if (errno != 0) {
> + errno = 0;
> + file_path = argv[2];
> + /* Open flash device and move to write offset */
> + flash = open(dev_path, O_WRONLY);
> + if (flash == -1) {
> + return -1;
> + status = lseek(flash, address, SEEK_SET);
> + close(flash);
> + return -1;
> + /* Open file and get file length */
> + file = open(file_path, O_RDONLY);
> + if (file == -1) {
> + printf("Couldn't open %s\n", file_path);
> + close(flash);
> + return -1;
> + length = lseek(file, 0, SEEK_END);
> + if (length == -1) {
> + close(flash);
> + close(file);
> + printf("Couldn't find length of file\n");
> + return -1;
> + if (lseek(file, 0, SEEK_SET) == -1) {
> + close(flash);
> + close(file);
> + return -1;
> + /* Create buffer */
> + buffer = calloc(1, 0x1000);
> + /* Write file to flash device in 0x1000 byte chunks */
> + offset = 0;
> + while (offset != length) {
> + read_len = length - offset;
> + if (read_len > 0x1000) {
> + read_len = 0x1000;
> + status = read(file, buffer, read_len);
> + free(buffer);
> + close(flash);
> + close(file);
> + printf("Can't read %s\n", file_path);
> + return -1;
> + status = write(flash, buffer, read_len);
> + free(buffer);
> + close(flash);
> + close(file);
> + printf("Can't write %s\n", dev_path);
> + return -1;
> + offset = offset + read_len;
> + /* Clean up */
> + close(flash);
> + close(file);
> + free(buffer);
> + return 0;
> +int flashdev_shell_erase(
> + char *dev_path,
> + int argc,
> + char *argv[]
> + uint32_t address;
> + uint32_t bytes;
> + int fd;
> + int status;
> + rtems_flashdev_region args;
> + if (argc < 5) {
> + return -1;
> + return 1;
> + errno = 0;
> + if (errno != 0) {
> + errno = 0;
> + if (errno != 0) {
> + fd = open(dev_path, O_RDWR);
> + if (fd == -1) {
> + return -1;
> + printf("Erasing at %08x for %x bytes\n", address, bytes);
> + /* Erase flash */
> + args.offset = address;
> + args.size = bytes;
> + status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &args);
> + printf("Erase failed\n");
> + close(fd);
> + return -1;
> + /* Clean up */
> + close(fd);
> + return 0;
> +int flashdev_shell_type( char *dev_path )
> + int type;
> + int status;
> + /* Get type */
> + status = flashdev_shell_ioctl_value(
> + dev_path,
> + RTEMS_FLASHDEV_IOCTL_TYPE,
> + &type
> + if (status) {
> + printf("Failed to get flash type\n");
> + return status;
> + /* Print type */
> + switch(type) {
> + case RTEMS_FLASHDEV_NOR:
> + printf("NOR flash\n");
> + break;
> + case RTEMS_FLASHDEV_NAND:
> + printf("NAND flash\n");
> + break;
> + default:
> + printf("Unknown type\n");
> + return 0;
> +int flashdev_shell_jedecid( char *dev_path ) {
> + uint32_t ret;
> + int status;
> + /* Get JEDEC Id */
> + dev_path,
> + RTEMS_FLASHDEV_IOCTL_JEDEC_ID,
> + &ret
> + /* Print JEDEC Id */
> + if (status) {
> + printf("Failed to get JEDEC Id\n");
> + return status;
> + } else {
> + printf("JEDEC Id: 0x%x\n", ret);
> + return 0;
> + char *dev_path,
> + int argc,
> + char *argv[]
> + return flashdev_shell_page(
> + dev_path,
> + argc,
> + argv,
> + RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET
> + char *dev_path,
> + int argc,
> + char *argv[]
> + dev_path,
> + argc,
> + argv,
> + RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX
> +static int flashdev_shell_pg_count( char *dev_path )
> + uint32_t ret;
> + int status;
> + /* Get Page Count */
> + dev_path,
> + RTEMS_FLASHDEV_IOCTL_PAGE_COUNT,
> + &ret
> + /* Print Page Count */
> + if (status) {
> + printf("Failed to get page count\n");
> + return status;
> + } else {
> + printf("Page count: 0x%x\n", ret);
> + return 0;
> +static int flashdev_shell_wb_size( char *dev_path )
> + size_t ret;
> + int status;
> + /* Get Write Block Size */
> + dev_path,
> + RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE,
> + &ret
> + /* Print Write Block Size */
> + if (status) {
> + printf("Failed to get write block size\n");
> + return status;
> + } else {
> + printf("Write block size: 0x%zx\n", ret);
> + return 0;
> + char *dev_path,
> + int ioctl_call,
> + void *ret
> + int fd;
> + int status;
> + if (fd == -1) {
> + return -1;
> + status = ioctl(fd, ioctl_call, ret);
> + close(fd);
> + return -1;
> + close(fd);
> + return 0;
> + char *dev_path,
> + int argc,
> + char *argv[],
> + int ioctl_call
> + rtems_flashdev_ioctl_page_info pg_info;
> + int fd;
> + int status;
> + if (argc < 4) {
> + return -1;
> + return 1;
> + errno = 0;
> + pg_info.location = (off_t) strtoul(argv[1], NULL, 0);
> + if (errno != 0) {
> + if (fd == -1) {
> + return -1;
> + status = ioctl(fd, ioctl_call, &pg_info);
> + printf("Failed to get page info\n");
> + close(fd);
> + return -1;
> + printf(
> + "Page offset: 0x%jx\nPage length: 0x%zx\n",
> + pg_info.page_info.offset,
> + pg_info.page_info.size
> + /* Clean up */
> + close(fd);
> + return 0;
> +rtems_shell_cmd_t rtems_shell_FLASHDEV_Command = {
> + .name = "flashdev",
> + .usage = rtems_flashdev_shell_usage,
> + .topic = "misc",
> + .command = rtems_flashdev_shell_main,
> diff --git a/spec/build/cpukit/objshell.yml
> b/spec/build/cpukit/objshell.yml
> index 5fd259bee3..b71abb18f9 100644
> --- a/spec/build/cpukit/objshell.yml
> +++ b/spec/build/cpukit/objshell.yml
> @@ -52,6 +52,7 @@ source:
> - cpukit/libmisc/shell/main_echo.c
> - cpukit/libmisc/shell/main_edit.c
> - cpukit/libmisc/shell/main_exit.c
> +- cpukit/libmisc/shell/main_flashdev.c
> - cpukit/libmisc/shell/main_getenv.c
> - cpukit/libmisc/shell/main_halt.c
> - cpukit/libmisc/shell/main_help.c
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230516/2dc364a5/attachment-0001.htm>
