[PATCH v4 2/3] libmisc/shell: Add flashdev command
Mon May 15 13:45:50 UTC 2023
On Sun, Apr 30, 2023 at 11:20 PM <aaron.nyholm at unfoldedeffective.com> wrote:
> From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
>  cpukit/include/rtems/shellconfig.h   |   7 +
>  cpukit/libmisc/shell/main_flashdev.c | 592 +++++++++++++++++++++++++++
>  spec/build/cpukit/objshell.yml       |   1 +
>  3 files changed, 600 insertions(+)
>  create mode 100644 cpukit/libmisc/shell/main_flashdev.c
> diff --git a/cpukit/include/rtems/shellconfig.h b/cpukit/include/rtems/shellconfig.h
> index a013840ee7..489f281400 100644
> --- a/cpukit/include/rtems/shellconfig.h
> +++ b/cpukit/include/rtems/shellconfig.h
> @@ -98,6 +98,7 @@ extern rtems_shell_cmd_t rtems_shell_MD5_Command;
>  extern rtems_shell_cmd_t rtems_shell_RTC_Command;
>  extern rtems_shell_cmd_t rtems_shell_SPI_Command;
> +extern rtems_shell_cmd_t rtems_shell_FLASHDEV_Command;
>  extern rtems_shell_cmd_t rtems_shell_I2CDETECT_Command;
>  extern rtems_shell_cmd_t rtems_shell_I2CGET_Command;
>  extern rtems_shell_cmd_t rtems_shell_I2CSET_Command;
> @@ -556,6 +557,12 @@ extern rtems_shell_alias_t * const rtems_shell_Initial_aliases[];
>        &rtems_shell_SPI_Command,
>      #endif
> +    #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
> +          && !defined(CONFIGURE_SHELL_NO_COMMAND_FLASHDEV)) \
> +        || defined(CONFIGURE_SHELL_COMMAND_FLASHDEV)
> +      &rtems_shell_FLASHDEV_Command,
> +    #endif
>            && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CDETECT)) \
>          || defined(CONFIGURE_SHELL_COMMAND_I2CDETECT)
> diff --git a/cpukit/libmisc/shell/main_flashdev.c b/cpukit/libmisc/shell/main_flashdev.c
> new file mode 100644
> index 0000000000..5484e7d7f9
> --- /dev/null
> +++ b/cpukit/libmisc/shell/main_flashdev.c
> @@ -0,0 +1,592 @@
> + * Copyright (C) 2023 Aaron Nyholm
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <fcntl.h>
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <errno.h>
> +#include <rtems/shell.h>
> +#include <dev/flash/flashdev.h>
> +static int flashdev_shell_read(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_write(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_erase(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_type(char *dev_path);
> +static int flashdev_shell_jedecid(char *dev_path);
> +static int flashdev_shell_page_off(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_page_idx(char *dev_path, int argc, char *argv[]);
> +static int flashdev_shell_pg_count(char *dev_path);
> +static int flashdev_shell_wb_size(char *dev_path);
> +static int flashdev_shell_ioctl_value(
> +  char *dev_path,
> +  int ioctl_call,
> +  void *ret
> +static int flashdev_shell_page(
> +  char *dev_path,
> +  int argc,
> +  char *argv[],
> +  int ioctl_call
> +static const char rtems_flashdev_shell_usage [] =
> +  "simple flash read / write / erase\n"
> +  "\n"
> +  "flashdev <FLASH_DEV_PATH> [OPTION]\n"
> +  "   -r <address> <bytes>  Read at address for bytes\n"
> +  "   -w <address> <file>   Write file to address\n"
> +  "   -e <address> <bytes>  Erase at address for bytes\n"
> +  "   -t                    Print the flash type\n"
> +  "   -d                    Print the JEDEC ID of flash device\n"
> +  "   -o <address>          Print the page information of page at address\n"
> +  "   -i <index>            Print the page information of page at index\n"
> +  "   -p                    Print the number of pages\n"
> +  "   -b                    Print the write block size\n"
> +  "   -h                    Print this help\n";
> +static int rtems_flashdev_shell_main( int argc, char *argv[] ) {
> +  char *dev_path = NULL;
> +  int i;
> +  for (i = 1; i < argc; ++i) {
> +    if (argv[i][0] == '-') {
> +      switch (argv[i][1]) {
> +      case ('r'):
> +        /* Read */
> +        return flashdev_shell_read(dev_path, argc, &argv[i]);
> +      case ('w'):
> +        /* Write */
> +        return flashdev_shell_write(dev_path, argc, &argv[i]);
> +      case ('e'):
> +        /* Erase */
> +        return flashdev_shell_erase(dev_path, argc, &argv[i]);
> +      case ('t'):
> +        /* Flash Type */
> +        return flashdev_shell_type(dev_path);
> +      case ('d'):
> +        /* JEDEC Id */
> +        return flashdev_shell_jedecid(dev_path);
> +      case ('o'):
> +        /* Page info by offset */
> +        return flashdev_shell_page_off(dev_path, argc, &argv[i]);
> +      case ('i'):
> +        /* Page info by index */
> +        return flashdev_shell_page_idx(dev_path, argc, &argv[i]);
> +      case ('p'):
> +        /* Page count */
> +        return flashdev_shell_pg_count(dev_path);
> +      case ('b'):
> +        /* Write block size */
> +        return flashdev_shell_wb_size(dev_path);
> +        //return flashdev_shell_pg_count(dev_path);
Don't comment out code, and avoid // comments
> +      case ('h'):
> +      default:
> +        /* Help */
> +        printf(rtems_flashdev_shell_usage);
> +        break;
> +    } else if (dev_path == NULL) {
> +      dev_path = argv[i];
> +    } else {
> +      printf("Invalid argument: %s\n", argv[i]);
> +      return 1;
> +  if (argc == 1) {
> +  return 0;
> +int flashdev_shell_read(
> +  char *dev_path,
> +  int argc,
> +  char *argv[]
> +  uint32_t address;
> +  uint32_t bytes;
> +  int fd;
> +  int status;
> +  void *buffer;
> +  /* Check arguments */
> +  if (argc < 5) {
> +    printf("Missing argument\n");
> +    return -1;
> +  if (dev_path == NULL) {
> +    printf("Please input FLASH_DEV_PATH before instruction\n");
> +    return 1;
> +  /* Get arguments */
> +  errno = 0;
> +  address = (uint32_t) strtoul(argv[1], NULL, 0);
> +  if (errno != 0) {
> +    printf("Could not read address\n");
> +  errno = 0;
> +  bytes = (uint32_t) strtoul(argv[2], NULL, 0);
> +  if (errno != 0) {
> +  /* Open flash device */
> +  fd = open(dev_path, O_RDONLY);
> +  if (fd == -1) {
> +    printf("Couldn't open %s\n", dev_path);
> +    return -1;
> +  /* Move to address */
> +  status = lseek(fd, address, SEEK_SET);
> +  if (status == -1) {
> +    printf("Reading failed\n");
> +    close(fd);
> +    return -1;
> +  /* Create a buffer to read into */
> +  buffer = calloc((bytes + bytes%4), 1);
> +  if (buffer == NULL) {
> +    printf("Failed to allocate read buffer\n");
> +    return -1;
> +  /* Read into buffer */
> +  status = read(fd, buffer, bytes);
> +    free(buffer);
> +    close(fd);
> +    return -1;
> +  /* Print buffer out in 32bit blocks */
> +  printf("Reading %s at 0x%08x for %d bytes\n", dev_path, address, bytes);
> +  for (int i = 0; i < (bytes/4); i++) {
> +    printf("%08x ", ((uint32_t*)buffer)[i]);
> +    if ((i+1)%4 == 0) {
> +      printf("\n");
> +  printf("\n");
> +  /* Clean up */
> +  free(buffer);
> +  close(fd);
> +  return 0;
> +int flashdev_shell_write(
> +  char *dev_path,
> +  int argc,
> +  char *argv[]
> +  uint32_t address;
> +  int flash;
> +  int file;
> +  int status;
> +  int read_len;
> +  off_t length;
> +  void *buffer;
> +  uint32_t offset;
> +  char *file_path;
> +  if (argc < 5) {
> +    return -1;
> +    return 1;
> +  errno = 0;
> +  if (errno != 0) {
> +  errno = 0;
> +  file_path = argv[2];
> +  /* Open flash device and move to write offset */
> +  flash = open(dev_path, O_WRONLY);
> +  if (flash == -1) {
> +    return -1;
> +  status = lseek(flash, address, SEEK_SET);
> +    close(flash);
> +    return -1;
> +  /* Open file and get file length */
> +  file = open(file_path, O_RDONLY);
> +  if (file == -1) {
> +    printf("Couldn't open %s\n", file_path);
> +    close(flash);
> +    return -1;
> +  length = lseek(file, 0, SEEK_END);
> +  if (length == -1) {
> +    close(flash);
> +    close(file);
> +    printf("Couldn't find length of file\n");
> +    return -1;
> +  if (lseek(file, 0, SEEK_SET) == -1) {
> +    close(flash);
> +    close(file);
> +    return -1;
> +  /* Create buffer */
> +  buffer = calloc(1, 0x1000);
> +  /* Write file to flash device in 0x1000 byte chunks */
> +  offset = 0;
> +  while (offset != length) {
> +    read_len = length - offset;
> +    if (read_len > 0x1000) {
> +      read_len = 0x1000;
> +    status = read(file, buffer, read_len);
> +      free(buffer);
> +      close(flash);
> +      close(file);
> +      printf("Can't read %s\n", file_path);
> +      return -1;
> +    status = write(flash, buffer, read_len);
> +      free(buffer);
> +      close(flash);
> +      close(file);
> +      printf("Can't write %s\n", dev_path);
> +      return -1;
> +    offset = offset + read_len;
> +  /* Clean up */
> +  close(flash);
> +  close(file);
> +  free(buffer);
> +  return 0;
> +int flashdev_shell_erase(
> +  char *dev_path,
> +  int argc,
> +  char *argv[]
> +  uint32_t address;
> +  uint32_t bytes;
> +  int fd;
> +  int status;
> +  rtems_flashdev_region args;
> +  if (argc < 5) {
> +    return -1;
> +    return 1;
> +  errno = 0;
> +  if (errno != 0) {
> +  errno = 0;
> +  if (errno != 0) {
> +  fd = open(dev_path, O_RDWR);
> +  if (fd == -1) {
> +    return -1;
> +  printf("Erasing at %08x for %x bytes\n", address, bytes);
> +  /* Erase flash */
> +  args.offset = address;
> +  args.size = bytes;
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &args);
> +    printf("Erase failed\n");
> +    close(fd);
> +    return -1;
> +  /* Clean up */
> +  close(fd);
> +  return 0;
> +int flashdev_shell_type( char *dev_path )
> +  int type;
> +  int status;
> +  /* Get type */
> +  status = flashdev_shell_ioctl_value(
> +    dev_path,
> +    RTEMS_FLASHDEV_IOCTL_TYPE,
> +    &type
> +  if (status) {
> +    printf("Failed to get flash type\n");
> +    return status;
> +  /* Print type */
> +  switch(type) {
> +    case RTEMS_FLASHDEV_NOR:
> +      printf("NOR flash\n");
> +      break;
> +    case RTEMS_FLASHDEV_NAND:
> +      printf("NAND flash\n");
> +      break;
> +    default:
> +      printf("Unknown type\n");
> +  return 0;
> +int flashdev_shell_jedecid( char *dev_path ) {
> +  uint32_t ret;
> +  int status;
> +  /* Get JEDEC Id */
> +    dev_path,
> +    RTEMS_FLASHDEV_IOCTL_JEDEC_ID,
> +    &ret
> +  /* Print JEDEC Id */
> +  if (status) {
> +    printf("Failed to get JEDEC Id\n");
> +    return status;
> +  } else {
> +    printf("JEDEC Id: 0x%x\n", ret);
> +  return 0;
> +  char *dev_path,
> +  int argc,
> +  char *argv[]
> +  return flashdev_shell_page(
> +    dev_path,
> +    argc,
> +    argv,
> +    RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET
> +  char *dev_path,
> +  int argc,
> +  char *argv[]
> +    dev_path,
> +    argc,
> +    argv,
> +    RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX
> +static int flashdev_shell_pg_count( char *dev_path )
> +  uint32_t ret;
> +  int status;
> +  /* Get Page Count */
> +    dev_path,
> +    RTEMS_FLASHDEV_IOCTL_PAGE_COUNT,
> +    &ret
> +  /* Print Page Count */
> +  if (status) {
> +    printf("Failed to get page count\n");
> +    return status;
> +  } else {
> +    printf("Page count: 0x%x\n", ret);
> +  return 0;
> +static int flashdev_shell_wb_size( char *dev_path )
> +  size_t ret;
> +  int status;
> +  /* Get Write Block Size */
> +    dev_path,
> +    RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE,
> +    &ret
> +  /* Print Write Block Size */
> +  if (status) {
> +    printf("Failed to get write block size\n");
> +    return status;
> +  } else {
> +    printf("Write block size: 0x%zx\n", ret);
> +  return 0;
> +  char *dev_path,
> +  int ioctl_call,
> +  void *ret
> +  int fd;
> +  int status;
> +  if (fd == -1) {
> +    return -1;
> +  status = ioctl(fd, ioctl_call, ret);
> +    close(fd);
> +    return -1;
> +  close(fd);
> +  return 0;
> +  char *dev_path,
> +  int argc,
> +  char *argv[],
> +  int ioctl_call
> +  rtems_flashdev_ioctl_page_info pg_info;
> +  int fd;
> +  int status;
> +  if (argc < 4) {
> +    return -1;
> +    return 1;
> +  errno = 0;
> +  pg_info.location = (off_t) strtoul(argv[1], NULL, 0);
> +  if (errno != 0) {
> +  if (fd == -1) {
> +    return -1;
> +  status = ioctl(fd, ioctl_call, &pg_info);
> +    printf("Failed to get page info\n");
> +    close(fd);
> +    return -1;
> +  printf(
> +    "Page offset: 0x%jx\nPage length: 0x%zx\n",
> +    pg_info.page_info.offset,
> +    pg_info.page_info.size
> +  /* Clean up */
> +  close(fd);
> +  return 0;
> +rtems_shell_cmd_t rtems_shell_FLASHDEV_Command = {
> +  .name = "flashdev",
> +  .usage = rtems_flashdev_shell_usage,
> +  .topic = "misc",
> +  .command = rtems_flashdev_shell_main,
> diff --git a/spec/build/cpukit/objshell.yml b/spec/build/cpukit/objshell.yml
> index 5fd259bee3..b71abb18f9 100644
> --- a/spec/build/cpukit/objshell.yml
> +++ b/spec/build/cpukit/objshell.yml
> @@ -52,6 +52,7 @@ source:
>  - cpukit/libmisc/shell/main_echo.c
>  - cpukit/libmisc/shell/main_edit.c
>  - cpukit/libmisc/shell/main_exit.c
> +- cpukit/libmisc/shell/main_flashdev.c
>  - cpukit/libmisc/shell/main_getenv.c
>  - cpukit/libmisc/shell/main_halt.c
>  - cpukit/libmisc/shell/main_help.c
> 2.25.1
> devel mailing list
> devel at rtems.org
