[PATCH 0/2] bsps/microblaze: GPIO improvements
Alex White
alex.white at oarcorp.com
Fri May 19 03:46:27 UTC 2023
Hi,
This patch set removes the build system options for the GPIO driver and adds
device tree support. The build system options were removed because they are now
supplied by the application or pulled from the device tree. This removes a lot
of clutter and makes the driver more flexible.
Alex
Alex White (2):
bsps/microblaze: Remove GPIO build system options
bsps/microblaze: Add device tree support to GPIO
.../microblaze_fpga/gpio/microblaze-gpio.c | 93 ++++++++++++-------
.../include/bsp/microblaze-gpio.h | 26 ++++--
.../bsps/microblaze/microblaze_fpga/grp.yml | 18 ----
.../microblaze_fpga/optgpio1baseaddress.yml | 19 ----
.../microblaze_fpga/optgpio1dualchannel.yml | 16 ----
.../microblaze_fpga/optgpio1interrupt.yml | 16 ----
.../microblaze_fpga/optgpio1irq.yml | 18 ----
.../microblaze_fpga/optgpio2baseaddress.yml | 19 ----
.../microblaze_fpga/optgpio2dualchannel.yml | 16 ----
.../microblaze_fpga/optgpio2enable.yml | 17 ----
.../microblaze_fpga/optgpio2interrupt.yml | 16 ----
.../microblaze_fpga/optgpio2irq.yml | 18 ----
12 files changed, 79 insertions(+), 213 deletions(-)
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
2.34.1
