[PATCH 1/2] bsps/microblaze: Remove GPIO build system options
Alex White alex.white at oarcorp.com
Fri May 19 03:46:28 UTC 2023
The number of GPIO devices along with each of their particular
configurations is application-specific. Encoding this information as
build options also introduced a lot of clutter.
 .../microblaze_fpga/gpio/microblaze-gpio.c    | 32 -------------------
 .../include/bsp/microblaze-gpio.h             | 10 ------
 .../bsps/microblaze/microblaze_fpga/grp.yml   | 18 -----------
 .../microblaze_fpga/optgpio1baseaddress.yml   | 19 -----------
 .../microblaze_fpga/optgpio1dualchannel.yml   | 16 ----------
 .../microblaze_fpga/optgpio1interrupt.yml     | 16 ----------
 .../microblaze_fpga/optgpio1irq.yml           | 18 -----------
 .../microblaze_fpga/optgpio2baseaddress.yml   | 19 -----------
 .../microblaze_fpga/optgpio2dualchannel.yml   | 16 ----------
 .../microblaze_fpga/optgpio2enable.yml        | 17 ----------
 .../microblaze_fpga/optgpio2interrupt.yml     | 16 ----------
 .../microblaze_fpga/optgpio2irq.yml           | 18 -----------
 12 files changed, 215 deletions(-)
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
 delete mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
diff --git a/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c b/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
index 9025840e32..a12158f1b7 100644
--- a/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
+++ b/bsps/microblaze/microblaze_fpga/gpio/microblaze-gpio.c
@@ -42,38 +42,6 @@
 extern "C" {
 #endif /* __cplusplus */
-Microblaze_GPIO_context gpio1_context = {
-  .regs = (Microblaze_GPIO_registers *) BSP_MICROBLAZE_FPGA_GPIO1_BASE,
-#ifdef BSP_MICROBLAZE_FPGA_GPIO1_DUAL_CHANNEL
-  .is_dual = true,
-#else
-  .is_dual = false,
-#endif
-  .irq = BSP_MICROBLAZE_FPGA_GPIO1_IRQ,
-#ifdef BSP_MICROBLAZE_FPGA_GPIO1_INTERRUPT
-  .has_interrupts = true
-#else
-  .has_interrupts = false
-#endif
-#if BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
-Microblaze_GPIO_context gpio2_context = {
-  .regs = (Microblaze_GPIO_registers *) BSP_MICROBLAZE_FPGA_GPIO2_BASE,
-#ifdef BSP_MICROBLAZE_FPGA_GPIO2_DUAL_CHANNEL
-  .is_dual = true,
-#else
-  .is_dual = false,
-#endif
-  .irq = BSP_MICROBLAZE_FPGA_GPIO2_IRQ,
-#ifdef BSP_MICROBLAZE_FPGA_GPIO2_INTERRUPT
-#else
-#endif
-#endif
 void microblaze_gpio_set_data_direction(
   Microblaze_GPIO_context *ctx,
   uint32_t                 channel,
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h b/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
index 5fe9c44cf8..a3d79ff70f 100644
--- a/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/microblaze-gpio.h
@@ -129,16 +129,6 @@ typedef struct {
   bool                       has_interrupts;
 } Microblaze_GPIO_context;
-extern Microblaze_GPIO_context gpio1_context;
-#ifdef BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
-extern Microblaze_GPIO_context gpio2_context;
-#endif
-#define gpio1 ((Microblaze_GPIO_context * const) &gpio1_context)
-#define gpio2 ((Microblaze_GPIO_context * const) &gpio2_context)
-#endif
  * @brief Set pin configuration for the specified GPIO channel.
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index 4f854de2cd..aeaa07dc03 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -28,24 +28,6 @@ links:
   uid: optdcachesize
 - role: build-dependency
   uid: optdtbheaderpath
-- role: build-dependency
-  uid: optgpio2enable
-  uid: optgpio1baseaddress
-  uid: optgpio2baseaddress
-  uid: optgpio1dualchannel
-  uid: optgpio2dualchannel
-  uid: optgpio1irq
-  uid: optgpio2irq
-  uid: optgpio1interrupt
-  uid: optgpio2interrupt
   uid: opticachebaseaddress
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
deleted file mode 100644
index 34a22d566b..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1baseaddress.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-actions:
-- get-integer: null
-- assert-uint32: null
-- env-assign: null
-- format-and-define: null
-build-type: option
-copyrights:
-- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
-default:
-- enabled-by: true
-  value: 0x40000000
-description: |
-  base address of GPIO 1
-enabled-by: true
-format: '{:#010x}'
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO1_BASE
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
index 43f6d5943c..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1dualchannel.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-- get-boolean: null
-- define-condition: null
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: true
-description: |
-  GPIO 1 is dual channel
-enabled-by: true
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO1_DUAL_CHANNEL
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
index 52597bddd0..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1interrupt.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: true
-description: |
-  GPIO 1 has interrupt
-enabled-by: true
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO1_INTERRUPT
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
index bd9d413af6..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio1irq.yml
+++ /dev/null
@@ -1,18 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: 8
-description: |
-  the IRQ number of GPIO 1
-enabled-by: true
-format: '{}'
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO1_IRQ
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
index 4e248830bf..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2baseaddress.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-actions:
-- env-assign: null
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: 0x40010000
-description: |
-  base address of GPIO 2
-enabled-by: BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
-format: '{:#010x}'
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO2_BASE
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
index b3053021d9..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2dualchannel.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: false
-description: |
-  GPIO 2 is dual channel
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO2_DUAL_CHANNEL
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
index 7fd402af43..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2enable.yml
+++ /dev/null
@@ -1,17 +0,0 @@
-actions:
-- env-enable: null
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: false
-description: |
-  GPIO 2 is enabled
-enabled-by: true
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO2_ENABLED
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
index b7ef76dc18..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2interrupt.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: true
-description: |
-  GPIO 2 has interrupt
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO2_INTERRUPT
-type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
index 4a5b63438e..0000000000
--- a/spec/build/bsps/microblaze/microblaze_fpga/optgpio2irq.yml
+++ /dev/null
@@ -1,18 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default:
-- enabled-by: true
-  value: 9
-description: |
-  the IRQ number of GPIO 2
-format: '{}'
-links: []
-name: BSP_MICROBLAZE_FPGA_GPIO2_IRQ
-type: build
2.34.1
