[PATCH rtems-libbsd] ipsec-tools: Fix copying fd_set prior to select
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon May 22 07:38:24 UTC 2023
Hello,
I would like to apply this patch on 5 and 6 branches. I'll create
tickets before applying it.
Best regards
Christian
On 2023-05-22 09:36, Christian Mauderer wrote:
> The racoon session code copies an fd_set from one variable into another
> prior to calling select. That works well for simple structures.
> In libbsd we have to allocate fd_sets instead of using fixed structures
> to avoid a problem with file numbers bigger than FD_SETSIZE. The simple
> assignment didn't work in that case.
> This patch makes sure that a memcpy is used instead.
> ipsec-tools/src/racoon/session.c | 7 +++++++
> 1 file changed, 7 insertions(+)
> diff --git a/ipsec-tools/src/racoon/session.c b/ipsec-tools/src/racoon/session.c
> index 7ea857ba..bd2bd316 100644
> --- a/ipsec-tools/src/racoon/session.c
> +++ b/ipsec-tools/src/racoon/session.c
> @@ -215,6 +215,8 @@ session(void)
> #ifndef __rtems__
> FD_ZERO(&preset_mask);
> #else /* __rtems__ */
> + size_t allocated_mask_size = sizeof(fd_set) *
> + howmany(rtems_libio_number_iops, sizeof(fd_set) * 8);
> allocated_preset_mask = calloc(sizeof(fd_set),
> howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
> if (allocated_preset_mask == NULL)
> @@ -352,7 +354,12 @@ session(void)
> /* schedular can change select() mask, so we reset
> * the working copy here */
> +#ifndef __rtems__
> active_mask = preset_mask;
> +#else /* __rtems__ */
> + memcpy(allocated_active_mask, allocated_preset_mask,
> + allocated_mask_size);
> +#endif /* __rtems__ */
> error = select(nfds + 1, &active_mask, NULL, NULL, timeout);
> if (error < 0) {
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
