[PATCH rtems-libbsd] ipsec-tools: Fix copying fd_set prior to select
    Chris Johns
    chrisj at rtems.org
    Tue May 23 01:36:47 UTC 2023
Hi,
I have been resolving this by adding:
#define preset_mask *preset_mask_prealloc
#define active_mask *active_mask_prealloc
as the assignment logic works as is. It does not catch FD_ZERO which is a shame
but is helps avoid us adding a special case.
On 22/5/2023 5:36 pm, Christian Mauderer wrote:
> The racoon session code copies an fd_set from one variable into another
> prior to calling select. That works well for simple structures.
> In libbsd we have to allocate fd_sets instead of using fixed structures
> to avoid a problem with file numbers bigger than FD_SETSIZE. The simple
> assignment didn't work in that case.
> This patch makes sure that a memcpy is used instead.
>  ipsec-tools/src/racoon/session.c | 7 +++++++
>  1 file changed, 7 insertions(+)
> diff --git a/ipsec-tools/src/racoon/session.c b/ipsec-tools/src/racoon/session.c
> index 7ea857ba..bd2bd316 100644
> --- a/ipsec-tools/src/racoon/session.c
> +++ b/ipsec-tools/src/racoon/session.c
> @@ -215,6 +215,8 @@ session(void)
>  #ifndef __rtems__
>  	FD_ZERO(&preset_mask);
>  #else /* __rtems__ */
> +	size_t allocated_mask_size = sizeof(fd_set) *
> +	    howmany(rtems_libio_number_iops, sizeof(fd_set) * 8);
>  	allocated_preset_mask = calloc(sizeof(fd_set),
>  	    howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
>  	if (allocated_preset_mask == NULL)
> @@ -352,7 +354,12 @@ session(void)
>  		/* schedular can change select() mask, so we reset
>  		 * the working copy here */
> +#ifndef __rtems__
>  		active_mask = preset_mask;
> +#else /* __rtems__ */
> +		memcpy(allocated_active_mask, allocated_preset_mask,
> +		    allocated_mask_size);
> +#endif /* __rtems__ */
>  		error = select(nfds + 1, &active_mask, NULL, NULL, timeout);
>  		if (error < 0) {
