[PATCH 2/5] build: Use CSafeLoader if available
Tue May 23 06:03:29 UTC 2023
On 23.05.23 02:42, Chris Johns wrote:
> On 22/5/2023 6:29 pm, Sebastian Huber wrote:
>> On 22.05.23 01:48, Chris Johns wrote:
>>>> The support for the CSafeLoader is just about 60 lines of additional code.
>>>> It would be a nice improvement for systems supporting this feature. I don't have
>>>> time to work on adding PyYAML with libyaml to the RTEMS Tools right now and I
>>>> think this would open another maintenance issues. If someone would be unable to
>>>> get a yaml module with a CSafeLoader, then he would be no longer able to build
>>>> RTEMS.
>>> It is not about the size of the implementation, it is about making 2 classes of
>>> performance, those with and those without csafe. I am a firm believer all
>>> developers and especially core developers need to be using the exact same tools
>>> and code our community users are using. We did not always do this and it
>>> resulted in the developers being disconnected from the user experience and I
>>> decided I would do what I could to avoid this happening again.
>> I really don't see the issue here. It is just the way to load the items from the
>> file system. This is a very isolated task in the build and having two ways to do
>> this is not a big deal from my point of view.
> Great, lets not go down this path and we all use the same process.
The CSafeLoader approach makes my work more efficient, so I will
definitely use it.
>>> In regards to PyYAML there are a few basic issues with it that I am not sure
>>> about. The package can be built without support for the C library even if it is
>>> installed. I cannot tell if a pip installed version is using the C YAML package
>>> or not. I would like more certainty across our supported hosts before agreeing
>>> to us using it.
>> I think it is just too complicated to make sure that the user has a PyYAML with
>> the CSafeLoader available when RTEMS is built. A more robust approach is a fall
>> back to the current implementation if needed.
> Maybe we move away from YAML for the build system data? Amar and I originally
> had python and INI files.
This discussion started with a proposal to switch to JSON:
https://lists.rtems.org/pipermail/devel/2023-April/075082.html
The INI format is a simple key-value format with no support for
hierarchical data, so not suitable from my point of view.
Using Python code could be an option, however, this gives the writer of
the files more freedom and room for creativity. On lesson learnt from
converting the autoconf/automake build to the new build system is, that
this may cause some issues.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
