[PATCH] smptests: Print proper end of test message
Sebastian Huber
Tue May 23 12:20:29 UTC 2023
Make sure that the end of test message is not mixed up with other test
output.
testsuites/smptests/smp05/init.c | 8 ++++++++
testsuites/smptests/smp07/init.c | 4 ++--
testsuites/smptests/smp08/tasks.c | 8 ++++++--
3 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index c8a9da2131..eb6461f3bc 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -35,6 +35,8 @@
const char rtems_test_name[] = "SMP 5";
+static volatile bool init_task_done;
rtems_task Init(
rtems_task_argument argument
@@ -54,6 +56,10 @@ rtems_task Test_task(
+ while (!init_task_done) {
+ /* Wait */
locked_printf( "Shut down from CPU %" PRIu32 "\n", rtems_scheduler_get_processor() );
success();
@@ -95,6 +101,8 @@ rtems_task Init(
directive_failed( status, "task start" );
+ init_task_done = true;
while (1)
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 3e1a852bd4..7066720a47 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -78,8 +78,6 @@ rtems_task Test_task(
if ( !TSRFired )
locked_printf( "*** ERROR TSR DID NOT FIRE BUT TEST TASK AWAKE***" );
- TaskRan = true;
/* Print that the task is up and running. */
locked_printf(
" CPU %" PRIu32 " running Task %s after semaphore release\n",
@@ -87,6 +85,8 @@ rtems_task Test_task(
name
+ TaskRan = true;
rtems_task_exit();
diff --git a/testsuites/smptests/smp08/tasks.c b/testsuites/smptests/smp08/tasks.c
index b71f437027..446c0d11da 100644
--- a/testsuites/smptests/smp08/tasks.c
+++ b/testsuites/smptests/smp08/tasks.c
@@ -54,8 +54,12 @@ rtems_task Test_task(
status = rtems_clock_get_tod( &time );
rtems_test_assert( status == RTEMS_SUCCESSFUL );
if ( time.second >= 35 ) {
- TEST_END();
- rtems_test_exit( 0 );
+ if ( task_index == 1 ) {
+ TEST_END();
+ rtems_test_exit( 0 );
+ } else {
+ rtems_task_exit();
PrintTaskInfo( p, &time );
2.35.3
