[PATCH] score: Unify <rtems/score/cpuatomic.h>
Sebastian Huber
Wed May 24 13:00:43 UTC 2023
All CPU ports use the same file.
.../aarch64/include/rtems/score/cpuatomic.h | 8 ++---
.../cpu/arm/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/bfin/include/rtems/score/cpuatomic.h | 36 ++++++++++++++++---
.../cpu/i386/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/lm32/include/rtems/score/cpuatomic.h | 36 ++++++++++++++++---
.../cpu/m68k/include/rtems/score/cpuatomic.h | 11 +++++-
.../include/rtems/score/cpuatomic.h | 7 ++--
.../cpu/mips/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/moxie/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/nios2/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/or1k/include/rtems/score/cpuatomic.h | 11 +++++-
.../powerpc/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/riscv/include/rtems/score/cpuatomic.h | 33 +++++++++++------
.../cpu/sh/include/rtems/score/cpuatomic.h | 36 ++++++++++++++++---
.../cpu/sparc/include/rtems/score/cpuatomic.h | 7 ++--
.../sparc64/include/rtems/score/cpuatomic.h | 11 +++++-
.../cpu/v850/include/rtems/score/cpuatomic.h | 11 +++++-
.../x86_64/include/rtems/score/cpuatomic.h | 36 ++++++++++++++++---
18 files changed, 261 insertions(+), 48 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
index ed8091d73c..772d496741 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
@@ -3,14 +3,14 @@
* @file
- * @ingroup RTEMSScoreCPU
+ * @ingroup RTEMSScoreAtomicCPU
- * @brief AArch64 Atomics support
+ * @brief This header file provides interfaces of the atomic operations
+ * implementation using functions provided by the C11/C++11.
- * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
- * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * Copyright (C) 2012, 2013 Deng Hengyi
* modification, are permitted provided that the following conditions
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
index 01bb99cda3..772d496741 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
/* SPDX-License-Identifier: BSD-2-Clause */
+ * @file
- * COPYRIGHT (c) 2012-2013 Deng Hengyi.
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
index 598ee76b20..772d496741 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
@@ -1,9 +1,37 @@
+ * @file
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
@@ -1,9 +1,37 @@
+ * @file
+ * are met:
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
index 6dc769b95a..772d496741 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
@@ -3,13 +3,14 @@
* @file
- * @brief MicroBlaze atomic support
- * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
index 8ee9606b44..772d496741 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
@@ -1,5 +1,16 @@
+ * @file
@@ -10,17 +21,17 @@
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
@@ -1,9 +1,37 @@
+ * @file
+ * are met:
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
index c8d4b4c4e7..772d496741 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
@@ -5,13 +5,12 @@
- * @brief This header file provides interfaces of the
- * atomic operations implementation using
- * functions provided by the C11/C++11.
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
@@ -1,7 +1,16 @@
+ * @file
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
@@ -1,9 +1,37 @@
+ * @file
+ * are met:
2.35.3
