[PATCH] termios: Add <rtems/termiosdevice.h>
Sebastian Huber
Fri May 26 04:57:48 UTC 2023
Add <rtems/termiosdevice.h> which does not depend on <rtems/libio.h> to
provide rtems_termios_device_context and rtems_termios_device_handler.
For polled serial device drivers, this removes a header file dependency
to the full file system support.
bsps/arm/xilinx-zynq/console/console-init.c | 1 +
bsps/include/dev/serial/zynq-uart.h | 2 +-
bsps/shared/dev/serial/zynq-uart.c | 1 +
cpukit/include/rtems/libio.h | 2 +-
cpukit/include/rtems/termiosdevice.h | 300 ++++++++++++++++++++
cpukit/include/rtems/termiostypes.h | 244 +---------------
cpukit/libcsupport/src/termiosinitialize.c | 11 +-
7 files changed, 314 insertions(+), 247 deletions(-)
create mode 100644 cpukit/include/rtems/termiosdevice.h
diff --git a/bsps/arm/xilinx-zynq/console/console-init.c b/bsps/arm/xilinx-zynq/console/console-init.c
index 5eb69dc224..72fa27da11 100644
--- a/bsps/arm/xilinx-zynq/console/console-init.c
+++ b/bsps/arm/xilinx-zynq/console/console-init.c
@@ -26,6 +26,7 @@
#include <rtems/console.h>
+#include <rtems/termiostypes.h>
#include <bsp.h>
#include <dev/serial/zynq-uart.h>
diff --git a/bsps/include/dev/serial/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
index 245c6d2afc..e7854af5f1 100644
--- a/bsps/include/dev/serial/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -34,7 +34,7 @@
#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
#define LIBBSP_ARM_XILINX_ZYNQ_UART_H
-#include <rtems/termiostypes.h>
+#include <rtems/termiosdevice.h>
#ifdef __cplusplus
extern "C" {
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 10e5d2acff..390ee1f527 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -28,6 +28,7 @@
#include <dev/serial/zynq-uart-regs.h>
#include <bsp/irq.h>
#include <bspopts.h>
diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
index cb0e6879a9..6898168aa6 100644
--- a/cpukit/include/rtems/libio.h
+++ b/cpukit/include/rtems/libio.h
@@ -1360,7 +1360,7 @@ typedef struct {
* @brief Parameter block for open/close.
-typedef struct {
+typedef struct rtems_libio_open_close_args {
rtems_libio_t *iop;
uint32_t flags;
uint32_t mode;
diff --git a/cpukit/include/rtems/termiosdevice.h b/cpukit/include/rtems/termiosdevice.h
new file mode 100644
index 0000000000..146510c457
--- /dev/null
+++ b/cpukit/include/rtems/termiosdevice.h
@@ -0,0 +1,300 @@
+ * @file
+ * @ingroup TermiostypesSupport
+ * @brief This header file provides the interfaces of the
+ * @ref TermiostypesSupport.
+ * Copyright (C) 2014, 2017 embedded brains GmbH & Co. KG
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_TERMIOSDEVICE_H
+#define _RTEMS_TERMIOSDEVICE_H
+#include <rtems/thread.h>
+#include <rtems/rtems/intr.h>
+#include <sys/ioccom.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+struct rtems_libio_open_close_args;
+struct rtems_termios_tty;
+struct termios;
+ * @defgroup TermiostypesSupport RTEMS Termios Device Support
+ * @ingroup libcsupport
+ * @brief This group contains the Termios Device Support provided by RTEMS.
+ * @brief Termios device context.
+ * @see RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(),
+ * rtems_termios_device_context_initialize() and
+ * rtems_termios_device_install().
+typedef struct rtems_termios_device_context {
+ union {
+ /* Used for TERMIOS_POLLED and TERMIOS_IRQ_DRIVEN */
+ rtems_interrupt_lock interrupt;
+ /* Used for TERMIOS_IRQ_SERVER_DRIVEN or TERMIOS_TASK_DRIVEN */
+ rtems_mutex mutex;
+ } lock;
+ void ( *lock_acquire )(
+ struct rtems_termios_device_context *,
+ rtems_interrupt_lock_context *
+ void ( *lock_release )(
+} rtems_termios_device_context;
+typedef enum {
+ TERMIOS_POLLED,
+ TERMIOS_IRQ_DRIVEN,
+ TERMIOS_TASK_DRIVEN,
+ TERMIOS_IRQ_SERVER_DRIVEN
+} rtems_termios_device_mode;
+ * @brief Termios device handler.
+ * @see rtems_termios_device_install().
+typedef struct {
+ * @brief First open of this device.
+ * @param[in] tty The Termios control. This parameter may be passed to
+ * interrupt service routines since it must be provided for the
+ * rtems_termios_enqueue_raw_characters() and
+ * rtems_termios_dequeue_characters() functions.
+ * @param[in] context The Termios device context.
+ * @param[in] term The current Termios attributes.
+ * @param[in] args The open/close arguments. This is parameter provided to
+ * support legacy drivers. It must not be used by new drivers.
+ * @retval true Successful operation.
+ * @retval false Cannot open device.
+ * @see rtems_termios_get_device_context() and rtems_termios_set_best_baud().
+ bool (*first_open)(
+ struct rtems_termios_tty *tty,
+ rtems_termios_device_context *context,
+ struct termios *term,
+ struct rtems_libio_open_close_args *args
+ * @brief Last close of this device.
+ void (*last_close)(
+ * @brief Polled read.
+ * In case mode is TERMIOS_IRQ_DRIVEN, TERMIOS_IRQ_SERVER_DRIVEN or
+ * TERMIOS_TASK_DRIVEN, then data is received via
+ * rtems_termios_enqueue_raw_characters().
+ * @retval char The received data encoded as unsigned char.
+ * @retval -1 No data currently available.
+ int (*poll_read)(rtems_termios_device_context *context);
+ * @brief Polled write in case mode is TERMIOS_POLLED or write support
+ * otherwise.
+ * @param[in] buf The output buffer.
+ * @param[in] len The output buffer length in characters.
+ void (*write)(
+ const char *buf,
+ size_t len
+ * @brief Set attributes after a Termios settings change.
+ * @param[in] term The new Termios attributes.
+ * @retval false Invalid attributes.
+ bool (*set_attributes)(
+ const struct termios *term
+ * @brief IO control handler.
+ * Invoked in case the Termios layer cannot deal with the IO request.
+ * @param[in] request The IO control request.
+ * @param[in] buffer The IO control buffer.
+ int (*ioctl)(
+ ioctl_command_t request,
+ void *buffer
+ * @brief Termios device mode.
+ rtems_termios_device_mode mode;
+} rtems_termios_device_handler;
+ * @brief Termios device flow control handler.
+typedef struct {
+ * @brief Indicate to stop remote transmitter.
+ void (*stop_remote_tx)(rtems_termios_device_context *context);
+ * @brief Indicate to start remote transmitter.
+ void (*start_remote_tx)(rtems_termios_device_context *context);
+} rtems_termios_device_flow;
+void rtems_termios_device_lock_acquire_default(
+ rtems_termios_device_context *ctx,
+ rtems_interrupt_lock_context *lock_context
+void rtems_termios_device_lock_release_default(
+ * @brief Initializes a device context.
+ * @param[in] name The name for the interrupt lock. This name must be a
+ * string persistent throughout the life time of this lock. The name is only
+ * used if profiling is enabled.
+static inline void rtems_termios_device_context_initialize(
+ const char *name
+ rtems_interrupt_lock_initialize( &context->lock.interrupt, name );
+ context->lock_acquire = rtems_termios_device_lock_acquire_default;
+ context->lock_release = rtems_termios_device_lock_release_default;
+ * @brief Initializer for static initialization of Termios device contexts.
+ * @param name The name for the interrupt lock. It must be a string. The name
+ * is only used if profiling is enabled.
+#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( name ) \
+ { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) }, \
+ rtems_termios_device_lock_acquire_default, \
+ rtems_termios_device_lock_release_default \
+ * @brief Acquires the device lock.
+ * @param[in] context The device context.
+ * @param[in] lock_context The local interrupt lock context for an acquire and
+ * release pair.
+static inline void rtems_termios_device_lock_acquire(
+ ( *context->lock_acquire )( context, lock_context );
+ * @brief Releases the device lock.
+ * release pair.
+static inline void rtems_termios_device_lock_release(
+ ( *context->lock_release )( context, lock_context );
+#ifdef __cplusplus
+#endif /* _RTEMS_TERMIOSDEVICE_H */
diff --git a/cpukit/include/rtems/termiostypes.h b/cpukit/include/rtems/termiostypes.h
index 67f3461b1f..5cf418a5eb 100644
--- a/cpukit/include/rtems/termiostypes.h
+++ b/cpukit/include/rtems/termiostypes.h
@@ -39,8 +39,7 @@
#include <rtems/libio.h>
#include <rtems/assoc.h>
#include <rtems/chain.h>
-#include <rtems/thread.h>
-#include <sys/ioccom.h>
#include <stdint.h>
#include <termios.h>
@@ -49,11 +48,9 @@ extern "C" {
#endif
- * @defgroup TermiostypesSupport RTEMS Termios Device Support
+ * @addtogroup TermiostypesSupport
- * @ingroup libcsupport
- * @brief RTEMS Termios Device Support Internal Data Structures
@@ -75,211 +72,6 @@ struct rtems_termios_rawbuf {
rtems_binary_semaphore Semaphore;
-typedef enum {
- TERMIOS_POLLED,
- TERMIOS_IRQ_DRIVEN,
- TERMIOS_TASK_DRIVEN,
- TERMIOS_IRQ_SERVER_DRIVEN
-} rtems_termios_device_mode;
-struct rtems_termios_tty;
- * @brief Termios device context.
- * @see RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(),
- * rtems_termios_device_context_initialize() and
- * rtems_termios_device_install().
-typedef struct rtems_termios_device_context {
- union {
- /* Used for TERMIOS_POLLED and TERMIOS_IRQ_DRIVEN */
- rtems_interrupt_lock interrupt;
- /* Used for TERMIOS_IRQ_SERVER_DRIVEN or TERMIOS_TASK_DRIVEN */
- rtems_mutex mutex;
- } lock;
- void ( *lock_acquire )(
- struct rtems_termios_device_context *,
- rtems_interrupt_lock_context *
- void ( *lock_release )(
-} rtems_termios_device_context;
-void rtems_termios_device_lock_acquire_default(
- rtems_termios_device_context *ctx,
- rtems_interrupt_lock_context *lock_context
-void rtems_termios_device_lock_release_default(
- * @brief Initializes a device context.
- * @param[in] context The Termios device context.
- * @param[in] name The name for the interrupt lock. This name must be a
- * string persistent throughout the life time of this lock. The name is only
- * used if profiling is enabled.
-static inline void rtems_termios_device_context_initialize(
- rtems_termios_device_context *context,
- const char *name
- rtems_interrupt_lock_initialize( &context->lock.interrupt, name );
- context->lock_acquire = rtems_termios_device_lock_acquire_default;
- context->lock_release = rtems_termios_device_lock_release_default;
- * @brief Initializer for static initialization of Termios device contexts.
- * @param name The name for the interrupt lock. It must be a string. The name
- * is only used if profiling is enabled.
-#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( name ) \
- { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) }, \
- rtems_termios_device_lock_acquire_default, \
- rtems_termios_device_lock_release_default \
- * @brief Termios device handler.
- * @see rtems_termios_device_install().
-typedef struct {
- * @brief First open of this device.
- * @param[in] tty The Termios control. This parameter may be passed to
- * interrupt service routines since it must be provided for the
- * rtems_termios_enqueue_raw_characters() and
- * rtems_termios_dequeue_characters() functions.
- * @param[in] term The current Termios attributes.
- * @param[in] args The open/close arguments. This is parameter provided to
- * support legacy drivers. It must not be used by new drivers.
- * @retval true Successful operation.
- * @retval false Cannot open device.
- * @see rtems_termios_get_device_context() and rtems_termios_set_best_baud().
- bool (*first_open)(
- struct rtems_termios_tty *tty,
- struct termios *term,
- rtems_libio_open_close_args_t *args
- * @brief Last close of this device.
- void (*last_close)(
- * @brief Polled read.
- * In case mode is TERMIOS_IRQ_DRIVEN, TERMIOS_IRQ_SERVER_DRIVEN or
- * TERMIOS_TASK_DRIVEN, then data is received via
- * rtems_termios_enqueue_raw_characters().
- * @retval char The received data encoded as unsigned char.
- * @retval -1 No data currently available.
- int (*poll_read)(rtems_termios_device_context *context);
- * @brief Polled write in case mode is TERMIOS_POLLED or write support
- * otherwise.
- * @param[in] buf The output buffer.
- * @param[in] len The output buffer length in characters.
- void (*write)(
- const char *buf,
- size_t len
- * @brief Set attributes after a Termios settings change.
- * @param[in] term The new Termios attributes.
- * @retval false Invalid attributes.
- bool (*set_attributes)(
- const struct termios *term
- * @brief IO control handler.
- * Invoked in case the Termios layer cannot deal with the IO request.
- * @param[in] request The IO control request.
- * @param[in] buffer The IO control buffer.
- int (*ioctl)(
- ioctl_command_t request,
- void *buffer
- * @brief Termios device mode.
- rtems_termios_device_mode mode;
-} rtems_termios_device_handler;
- * @brief Termios device flow control handler.
-typedef struct {
- * @brief Indicate to stop remote transmitter.
- void (*stop_remote_tx)(rtems_termios_device_context *context);
- * @brief Indicate to start remote transmitter.
- void (*start_remote_tx)(rtems_termios_device_context *context);
-} rtems_termios_device_flow;
* @brief Termios device node for installed devices.
@@ -455,36 +247,6 @@ static inline void *rtems_termios_get_device_context(
return tty->device_context;
- * @brief Acquires the device lock.
- * @param[in] context The device context.
- * @param[in] lock_context The local interrupt lock context for an acquire and
- * release pair.
-static inline void rtems_termios_device_lock_acquire(
- ( *context->lock_acquire )( context, lock_context );
- * @brief Releases the device lock.
- * release pair.
-static inline void rtems_termios_device_lock_release(
- ( *context->lock_release )( context, lock_context );
* @brief Sets the best baud value in the Termios control.
diff --git a/cpukit/libcsupport/src/termiosinitialize.c b/cpukit/libcsupport/src/termiosinitialize.c
index 35aa1eb955..ae80243b2a 100644
--- a/cpukit/libcsupport/src/termiosinitialize.c
+++ b/cpukit/libcsupport/src/termiosinitialize.c
@@ -1,8 +1,11 @@
- * @file
+ * @file
- * @brief Termios Initialization
- * @ingroup Termios
+ * @brief This source file contains the implementation of
+ * rtems_termios_device_lock_acquire_default() and
+ * rtems_termios_device_lock_release_default().
@@ -17,7 +20,7 @@
#include "config.h"
#endif
void
2.35.3
