[PATCH 1/2] score: Remove CPU port specific cpuatomic.h
Fri May 26 05:19:06 UTC 2023
All CPU ports used the same <rtems/score/cpustdatomic.h> header file to
provide the atomic operations.  Remove the header file indirection.
 .../score/{cpustdatomic.h => cpuatomic.h}     |  0
 .../aarch64/include/rtems/score/cpuatomic.h   | 42 -------------------
 .../cpu/arm/include/rtems/score/cpuatomic.h   | 33 ---------------
 .../cpu/bfin/include/rtems/score/cpuatomic.h  | 14 -------
 .../cpu/i386/include/rtems/score/cpuatomic.h  | 33 ---------------
 .../cpu/lm32/include/rtems/score/cpuatomic.h  | 14 -------
 .../cpu/m68k/include/rtems/score/cpuatomic.h  | 33 ---------------
 .../include/rtems/score/cpuatomic.h           | 41 ------------------
 .../cpu/mips/include/rtems/score/cpuatomic.h  | 33 ---------------
 .../cpu/moxie/include/rtems/score/cpuatomic.h | 33 ---------------
 .../cpu/nios2/include/rtems/score/cpuatomic.h | 33 ---------------
 .../cpu/or1k/include/rtems/score/cpuatomic.h  | 33 ---------------
 .../powerpc/include/rtems/score/cpuatomic.h   | 33 ---------------
 .../cpu/riscv/include/rtems/score/cpuatomic.h | 31 --------------
 .../cpu/sh/include/rtems/score/cpuatomic.h    | 14 -------
 .../cpu/sparc/include/rtems/score/cpuatomic.h | 33 ---------------
 .../sparc64/include/rtems/score/cpuatomic.h   | 33 ---------------
 .../cpu/v850/include/rtems/score/cpuatomic.h  | 33 ---------------
 .../x86_64/include/rtems/score/cpuatomic.h    | 14 -------
 19 files changed, 533 deletions(-)
 rename cpukit/include/rtems/score/{cpustdatomic.h => cpuatomic.h} (100%)
 delete mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
 delete mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
diff --git a/cpukit/include/rtems/score/cpustdatomic.h b/cpukit/include/rtems/score/cpuatomic.h
similarity index 100%
rename from cpukit/include/rtems/score/cpustdatomic.h
rename to cpukit/include/rtems/score/cpuatomic.h
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
deleted file mode 100644
index ed8091d73c..0000000000
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,42 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSScoreCPU
- * @brief AArch64 Atomics support
- * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
- * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
-#define _RTEMS_SCORE_ATOMIC_CPU_H
-#include <rtems/score/cpustdatomic.h>
-#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
index 01bb99cda3..0000000000
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * COPYRIGHT (c) 2012-2013 Deng Hengyi.
- * are met:
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
index 598ee76b20..0000000000
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,14 +0,0 @@
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,14 +0,0 @@
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
index 6dc769b95a..0000000000
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,41 +0,0 @@
- * @file
- * @brief MicroBlaze atomic support
- * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
- * are met:
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
index 8ee9606b44..0000000000
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,31 +0,0 @@
- * are met:
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,14 +0,0 @@
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * are met:
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,14 +0,0 @@
2.35.3
