[PATCH 2/2] score: Remove CPU port atomic operations API
Sebastian Huber
Fri May 26 05:19:07 UTC 2023
Use the C/C++ standard API directly.
cpukit/include/rtems/score/atomic.h | 962 ++++++++++++++++++++++--
cpukit/include/rtems/score/cpuatomic.h | 986 -------------------------
2 files changed, 888 insertions(+), 1060 deletions(-)
delete mode 100644 cpukit/include/rtems/score/cpuatomic.h
diff --git a/cpukit/include/rtems/score/atomic.h b/cpukit/include/rtems/score/atomic.h
index 161b0ec03e..9ef1779e60 100644
--- a/cpukit/include/rtems/score/atomic.h
+++ b/cpukit/include/rtems/score/atomic.h
@@ -10,6 +10,7 @@
+ * Copyright (C) 2015 embedded brains GmbH & Co. KG
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
@@ -37,7 +38,7 @@
#ifndef _RTEMS_SCORE_ATOMIC_H
#define _RTEMS_SCORE_ATOMIC_H
-#include <rtems/score/cpuatomic.h>
+#include <rtems/score/basedefs.h>
* @defgroup RTEMSScoreAtomic Atomic Operations
@@ -54,122 +55,935 @@
-typedef CPU_atomic_Uint Atomic_Uint;
+#ifdef RTEMS_SMP
+ #if defined(__cplusplus) \
+ && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9))
+ * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
+ * suggested solution was to include <atomic> in case C++ is used. This works
+ * at least with GCC 4.9. See also:
+ * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
+ * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
+ #include <atomic>
+ #define _RTEMS_SCORE_ATOMIC_USE_ATOMIC
+ #else
+ #include <stdatomic.h>
+ #define _RTEMS_SCORE_ATOMIC_USE_STDATOMIC
+ #endif
+#else
+ #include <rtems/score/isrlevel.h>
+#endif
-typedef CPU_atomic_Ulong Atomic_Ulong;
+#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
-typedef CPU_atomic_Uintptr Atomic_Uintptr;
+typedef std::atomic_uint Atomic_Uint;
-typedef CPU_atomic_Flag Atomic_Flag;
+typedef std::atomic_ulong Atomic_Ulong;
-typedef CPU_atomic_Order Atomic_Order;
+typedef std::atomic_uintptr_t Atomic_Uintptr;
-#define ATOMIC_ORDER_RELAXED CPU_ATOMIC_ORDER_RELAXED
+typedef std::atomic_flag Atomic_Flag;
-#define ATOMIC_ORDER_ACQUIRE CPU_ATOMIC_ORDER_ACQUIRE
+typedef std::memory_order Atomic_Order;
-#define ATOMIC_ORDER_RELEASE CPU_ATOMIC_ORDER_RELEASE
+#define ATOMIC_ORDER_RELAXED std::memory_order_relaxed
-#define ATOMIC_ORDER_ACQ_REL CPU_ATOMIC_ORDER_ACQ_REL
+#define ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
-#define ATOMIC_ORDER_SEQ_CST CPU_ATOMIC_ORDER_SEQ_CST
+#define ATOMIC_ORDER_RELEASE std::memory_order_release
-#define ATOMIC_INITIALIZER_UINT( value ) CPU_ATOMIC_INITIALIZER_UINT( value )
+#define ATOMIC_ORDER_ACQ_REL std::memory_order_acq_rel
-#define ATOMIC_INITIALIZER_ULONG( value ) CPU_ATOMIC_INITIALIZER_ULONG( value )
+#define ATOMIC_ORDER_SEQ_CST std::memory_order_seq_cst
-#define ATOMIC_INITIALIZER_UINTPTR( value ) CPU_ATOMIC_INITIALIZER_UINTPTR( value )
+#define ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
-#define ATOMIC_INITIALIZER_FLAG CPU_ATOMIC_INITIALIZER_FLAG
+#define ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
-#define _Atomic_Fence( order ) _CPU_atomic_Fence( order )
+#define ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
-#define _Atomic_Init_uint( obj, desired ) \
- _CPU_atomic_Init_uint( obj, desired )
+#define ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
-#define _Atomic_Init_ulong( obj, desired ) \
- _CPU_atomic_Init_ulong( obj, desired )
+#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
-#define _Atomic_Init_uintptr( obj, desired ) \
- _CPU_atomic_Init_uintptr( obj, desired )
+typedef atomic_uint Atomic_Uint;
-#define _Atomic_Load_uint( obj, order ) \
- _CPU_atomic_Load_uint( obj, order )
+typedef atomic_ulong Atomic_Ulong;
-#define _Atomic_Load_ulong( obj, order ) \
- _CPU_atomic_Load_ulong( obj, order )
+typedef atomic_uintptr_t Atomic_Uintptr;
-#define _Atomic_Load_uintptr( obj, order ) \
- _CPU_atomic_Load_uintptr( obj, order )
+typedef atomic_flag Atomic_Flag;
-#define _Atomic_Store_uint( obj, desr, order ) \
- _CPU_atomic_Store_uint( obj, desr, order )
+typedef memory_order Atomic_Order;
-#define _Atomic_Store_ulong( obj, desr, order ) \
- _CPU_atomic_Store_ulong( obj, desr, order )
+#define ATOMIC_ORDER_RELAXED memory_order_relaxed
-#define _Atomic_Store_uintptr( obj, desr, order ) \
- _CPU_atomic_Store_uintptr( obj, desr, order )
+#define ATOMIC_ORDER_ACQUIRE memory_order_acquire
-#define _Atomic_Fetch_add_uint( obj, arg, order ) \
- _CPU_atomic_Fetch_add_uint( obj, arg, order )
+#define ATOMIC_ORDER_RELEASE memory_order_release
-#define _Atomic_Fetch_add_ulong( obj, arg, order ) \
- _CPU_atomic_Fetch_add_ulong( obj, arg, order )
+#define ATOMIC_ORDER_ACQ_REL memory_order_acq_rel
-#define _Atomic_Fetch_add_uintptr( obj, arg, order ) \
- _CPU_atomic_Fetch_add_uintptr( obj, arg, order )
+#define ATOMIC_ORDER_SEQ_CST memory_order_seq_cst
-#define _Atomic_Fetch_sub_uint( obj, arg, order ) \
- _CPU_atomic_Fetch_sub_uint( obj, arg, order )
-#define _Atomic_Fetch_sub_ulong( obj, arg, order ) \
- _CPU_atomic_Fetch_sub_ulong( obj, arg, order )
-#define _Atomic_Fetch_sub_uintptr( obj, arg, order ) \
- _CPU_atomic_Fetch_sub_uintptr( obj, arg, order )
-#define _Atomic_Fetch_or_uint( obj, arg, order ) \
- _CPU_atomic_Fetch_or_uint( obj, arg, order )
-#define _Atomic_Fetch_or_ulong( obj, arg, order ) \
- _CPU_atomic_Fetch_or_ulong( obj, arg, order )
+#else
-#define _Atomic_Fetch_or_uintptr( obj, arg, order ) \
- _CPU_atomic_Fetch_or_uintptr( obj, arg, order )
+typedef unsigned int Atomic_Uint;
-#define _Atomic_Fetch_and_uint( obj, arg, order ) \
- _CPU_atomic_Fetch_and_uint( obj, arg, order )
+typedef unsigned long Atomic_Ulong;
-#define _Atomic_Fetch_and_ulong( obj, arg, order ) \
- _CPU_atomic_Fetch_and_ulong( obj, arg, order )
+typedef uintptr_t Atomic_Uintptr;
-#define _Atomic_Fetch_and_uintptr( obj, arg, order ) \
- _CPU_atomic_Fetch_and_uintptr( obj, arg, order )
+typedef bool Atomic_Flag;
-#define _Atomic_Exchange_uint( obj, desr, order ) \
- _CPU_atomic_Exchange_uint( obj, desr, order )
+typedef int Atomic_Order;
-#define _Atomic_Exchange_ulong( obj, desr, order ) \
- _CPU_atomic_Exchange_ulong( obj, desr, order )
+#define ATOMIC_ORDER_RELAXED 0
-#define _Atomic_Exchange_uintptr( obj, desr, order ) \
- _CPU_atomic_Exchange_uintptr( obj, desr, order )
+#define ATOMIC_ORDER_ACQUIRE 2
-#define _Atomic_Compare_exchange_uint( obj, expected, desired, succ, fail ) \
- _CPU_atomic_Compare_exchange_uint( obj, expected, desired, succ, fail )
+#define ATOMIC_ORDER_RELEASE 3
-#define _Atomic_Compare_exchange_ulong( obj, expected, desired, succ, fail ) \
- _CPU_atomic_Compare_exchange_ulong( obj, expected, desired, succ, fail )
+#define ATOMIC_ORDER_ACQ_REL 4
-#define _Atomic_Compare_exchange_uintptr( obj, expected, desired, succ, fail ) \
- _CPU_atomic_Compare_exchange_uintptr( obj, expected, desired, succ, fail )
+#define ATOMIC_ORDER_SEQ_CST 5
-#define _Atomic_Flag_clear( obj, order ) \
- _CPU_atomic_Flag_clear( obj, order )
+#define ATOMIC_INITIALIZER_UINT( value ) ( value )
-#define _Atomic_Flag_test_and_set( obj, order ) \
- _CPU_atomic_Flag_test_and_set( obj, order )
+#define ATOMIC_INITIALIZER_ULONG( value ) ( value )
+#define ATOMIC_INITIALIZER_UINTPTR( value ) ( value )
+#define ATOMIC_INITIALIZER_FLAG false
+#endif
+ * @brief Sets up a cpu fence.
+ * @param[out] order The order for the fence.
+static inline void _Atomic_Fence( Atomic_Order order )
+ std::atomic_thread_fence( order );
+ atomic_thread_fence( order );
+#else
+ (void) order;
+ RTEMS_COMPILER_MEMORY_BARRIER();
+#endif
+ * @brief Initializes Uint.
+ * @param[out] obj The CPU atomic Uint to initialize.
+ * @param desired The desired value for @a obj.
+static inline void _Atomic_Init_uint( Atomic_Uint *obj, unsigned int desired )
+ obj->store( desired );
+ atomic_init( obj, desired );
+#else
+ *obj = desired;
+#endif
+ * @brief Initializes Ulong.
+ * @param[out] obj The CPU atomic Ulong to initialize.
+static inline void _Atomic_Init_ulong( Atomic_Ulong *obj, unsigned long desired )
+#else
+ *obj = desired;
+#endif
+ * @brief Initializes Uintptr.
+ * @param[out] obj The CPU atomic Uintptr to initialize.
+static inline void _Atomic_Init_uintptr( Atomic_Uintptr *obj, uintptr_t desired )
+#else
+ *obj = desired;
+#endif
+ * @brief Loads value of Uint considering the order.
+ * @param obj The CPU atomic Uint to get the value from.
+ * @param order The atomic order for getting the value.
+ * @return The value of @a obj considering the @a order.
+static inline unsigned int _Atomic_Load_uint( const Atomic_Uint *obj, Atomic_Order order )
+ return obj->load( order );
+ return atomic_load_explicit( obj, order );
+#else
+ unsigned int val;
+ (void) order;
+ val = *obj;
+ return val;
+#endif
+ * @brief Loads value of Ulong considering the order.
+ * @param obj The CPU atomic Ulong to get the value from.
+static inline unsigned long _Atomic_Load_ulong( const Atomic_Ulong *obj, Atomic_Order order )
+#else
+ unsigned long val;
+ (void) order;
+ val = *obj;
+ return val;
+#endif
+ * @brief Loads value of Uintptr considering the order.
+ * @param obj The CPU atomic Uintptr to get the value from.
+static inline uintptr_t _Atomic_Load_uintptr( const Atomic_Uintptr *obj, Atomic_Order order )
+#else
+ uintptr_t val;
+ (void) order;
+ val = *obj;
+ return val;
+#endif
+ * @brief Stores a value to Uint considering the order.
+ * @param[out] obj The CPU atomic Uint to store a value in.
+ * @param order The atomic order for storing the value.
+static inline void _Atomic_Store_uint( Atomic_Uint *obj, unsigned int desired, Atomic_Order order )
+ obj->store( desired, order );
+ atomic_store_explicit( obj, desired, order );
+#else
+ (void) order;
+ *obj = desired;
+#endif
+ * @brief Stores a value to Ulong considering the order.
+ * @param[out] obj The CPU atomic Ulong to store a value in.
+static inline void _Atomic_Store_ulong( Atomic_Ulong *obj, unsigned long desired, Atomic_Order order )
+#else
+ (void) order;
+ *obj = desired;
+#endif
+ * @brief Stores a value to Uintptr considering the order.
+ * @param[out] obj The CPU atomic Uintptr to store a value in.
+static inline void _Atomic_Store_uintptr( Atomic_Uintptr *obj, uintptr_t desired, Atomic_Order order )
+#else
+ (void) order;
+ *obj = desired;
+#endif
+ * @brief Fetches current value of Uint and adds a value to the stored value.
+ * @param[in, out] obj The CPU atomic Uint to get the value from and add @a arg to.
+ * @param arg The value to add to @a obj.
+ * @param order The atomic order for the operation.
+ * @return The value of @a obj prior to the addition of @a arg.
+static inline unsigned int _Atomic_Fetch_add_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
+ return obj->fetch_add( arg, order );
+ return atomic_fetch_add_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ _ISR_Local_disable( level );
+ val = *obj;
+ *obj = val + arg;
+ _ISR_Local_enable( level );
+ return val;
+#endif
+ * @brief Fetches current value of Ulong and adds a value to the stored value.
+ * @param[in, out] obj The CPU atomic Ulong to get the value from and add @a arg to.
+static inline unsigned long _Atomic_Fetch_add_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val + arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uintptr and adds a value to the stored value.
+ * @param[in, out] obj The CPU atomic Uintptr to get the value from and add @a arg to.
+static inline uintptr_t _Atomic_Fetch_add_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val + arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uint and subtracts a value from the stored value.
+ * @param[in, out] obj The CPU atomic Uint to get the value from and subtract @a arg from.
+ * @param arg The value to subtract from @a obj.
+ * @return The value of @a obj prior to the subtraction of @a arg.
+static inline unsigned int _Atomic_Fetch_sub_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
+ return obj->fetch_sub( arg, order );
+ return atomic_fetch_sub_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - arg;
+ return val;
+#endif
+ * @brief Fetches current value of Ulong and subtracts a value from the stored value.
+ * @param[in, out] obj The CPU atomic Ulong to get the value from and subtract @a arg from.
+static inline unsigned long _Atomic_Fetch_sub_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uintptr and subtracts a value from the stored value.
+ * @param[in, out] obj The CPU atomic Uintptr to get the value from and subtract @a arg from.
+static inline uintptr_t _Atomic_Fetch_sub_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uint and ORs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Uint to get the value from and OR @a arg to.
+ * @param arg The value to OR with @a obj.
+ * @return The value of @a obj prior to the OR operation with @a arg.
+static inline unsigned int _Atomic_Fetch_or_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
+ return obj->fetch_or( arg, order );
+ return atomic_fetch_or_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | arg;
+ return val;
+#endif
+ * @brief Fetches current value of Ulong and ORs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Ulong to get the value from and OR @a arg to.
+static inline unsigned long _Atomic_Fetch_or_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uintptr and ORs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Uintptr to get the value from and OR @a arg to.
+static inline uintptr_t _Atomic_Fetch_or_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uint and ANDs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Uint to get the value from and AND @a arg to.
+ * @param arg The value to AND with @a obj.
+ * @return The value of @a obj prior to the AND operation with @a arg.
+static inline unsigned int _Atomic_Fetch_and_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
+ return obj->fetch_and( arg, order );
+ return atomic_fetch_and_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & arg;
+ return val;
+#endif
+ * @brief Fetches current value of Ulong and ANDs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Ulong to get the value from and AND @a arg to.
+static inline unsigned long _Atomic_Fetch_and_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uintptr and ANDs a value with the stored value.
+ * @param[in, out] obj The CPU atomic Uintptr to get the value from and AND @a arg to.
+static inline uintptr_t _Atomic_Fetch_and_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & arg;
+ return val;
+#endif
+ * @brief Fetches current value of Uint and sets its value.
+ * @param[in, out] obj The CPU atomic Uint to get the value from and set the value to @a desired.
+ * @param arg The value to set for @a obj.
+ * @return The value of @a obj prior to the exchange with @a desired.
+static inline unsigned int _Atomic_Exchange_uint( Atomic_Uint *obj, unsigned int desired, Atomic_Order order )
+ return obj->exchange( desired, order );
+ return atomic_exchange_explicit( obj, desired, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = desired;
+ return val;
+#endif
+ * @brief Fetches current value of Ulong and sets its value.
+ * @param[in, out] obj The CPU atomic Ulong to get the value from and set the value to @a desired.
+static inline unsigned long _Atomic_Exchange_ulong( Atomic_Ulong *obj, unsigned long desired, Atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = desired;
+ return val;
+#endif
+ * @brief Fetches current value of Uintptr and sets its value.
+ * @param[in, out] obj The CPU atomic Uintptr to get the value from and set the value to @a desired.
+static inline uintptr_t _Atomic_Exchange_uintptr( Atomic_Uintptr *obj, uintptr_t desired, Atomic_Order order )
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = desired;
+ return val;
+#endif
+ * @brief Checks if value of Uint is as expected.
+ * This method checks if the value of @a obj is equal to the value of @a expected. If
+ * this is the case, the value of @a obj is changed to @a desired. Otherwise, the value
+ * of @a obj is changed to @a expected.
+ * @param[in, out] obj The CPU atomic Uint to operate upon.
+ * @param[in, out] expected The expected value of @a obj. If @a obj has a different
+ * value, @a expected is changed to the actual value of @a obj.
+ * @param desired The new value of @a obj if the old value of @a obj was as expected.
+ * @param succ The order if it is successful.
+ * @param fail The order if it fails.
+ * @retval true The old value of @a obj was as expected.
+ * @retval false The old value of @a obj was not as expected.
+static inline bool _Atomic_Compare_exchange_uint( Atomic_Uint *obj, unsigned int *expected, unsigned int desired, Atomic_Order succ, Atomic_Order fail )
+ return obj->compare_exchange_strong( *expected, desired, succ, fail );
+ return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
+#else
+ bool success;
+ ISR_Level level;
+ unsigned int actual;
+ (void) succ;
+ (void) fail;
+ actual = *obj;
+ success = ( actual == *expected );
+ if ( success ) {
+ *obj = desired;
+ } else {
+ *expected = actual;
+ return success;
+#endif
+ * @brief Checks if value of Ulong is as expected.
+ * @param[in, out] obj The CPU atomic Ulong to operate upon.
+static inline bool _Atomic_Compare_exchange_ulong( Atomic_Ulong *obj, unsigned long *expected, unsigned long desired, Atomic_Order succ, Atomic_Order fail )
+#else
+ bool success;
+ ISR_Level level;
+ unsigned long actual;
+ (void) succ;
+ (void) fail;
+ actual = *obj;
+ if ( success ) {
+ *obj = desired;
+ } else {
+ return success;
+#endif
+ * @brief Checks if value of Uintptr is as expected.
+ * @param[in, out] obj The CPU atomic Uintptr to operate upon.
+static inline bool _Atomic_Compare_exchange_uintptr( Atomic_Uintptr *obj, uintptr_t *expected, uintptr_t desired, Atomic_Order succ, Atomic_Order fail )
+#else
+ bool success;
+ ISR_Level level;
+ uintptr_t actual;
+ (void) succ;
+ (void) fail;
+ actual = *obj;
+ if ( success ) {
+ *obj = desired;
+ } else {
+ return success;
+#endif
+ * @brief Clears the atomic flag.
+ * @param[out] obj The atomic flag to be cleared.
+static inline void _Atomic_Flag_clear( Atomic_Flag *obj, Atomic_Order order )
+ obj->clear( order );
+ atomic_flag_clear_explicit( obj, order );
+#else
+ (void) order;
+ *obj = false;
+#endif
+ * @brief Returns current flag state and sets it.
+ * @param[in, out] obj The atomic flag to be set.
+ * @retval true @a obj was set prior to this operation.
+ * @retval false @a obj was not set prior to this operation.
+static inline bool _Atomic_Flag_test_and_set( Atomic_Flag *obj, Atomic_Order order )
+ return obj->test_and_set( order );
+ return atomic_flag_test_and_set_explicit( obj, order );
+#else
+ bool flag;
+ ISR_Level level;
+ (void) order;
+ flag = *obj;
+ *obj = true;
+ return flag;
+#endif
diff --git a/cpukit/include/rtems/score/cpuatomic.h b/cpukit/include/rtems/score/cpuatomic.h
deleted file mode 100644
index f1afa6bec2..0000000000
--- a/cpukit/include/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,986 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSScoreAtomicCPU
- * @brief This header file provides the interfaces of the
- * @ref RTEMSScoreAtomicCPU.
- * COPYRIGHT (c) 2013 Deng Hengyi.
- * Copyright (c) 2015 embedded brains GmbH & Co. KG
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_CPUSTDATOMIC_H
-#define _RTEMS_SCORE_CPUSTDATOMIC_H
-#include <rtems/score/basedefs.h>
- * @defgroup RTEMSScoreAtomicCPU C11/C++11 Atomic Operations
- * @brief This group contains the atomic operations implementation using
- * functions provided by the C11/C++11.
-#ifdef RTEMS_SMP
- #if defined(__cplusplus) \
- && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9))
- * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
- * suggested solution was to include <atomic> in case C++ is used. This works
- * at least with GCC 4.9. See also:
- * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
- * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
- #include <atomic>
- #define _RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC
- #else
- #include <stdatomic.h>
- #define _RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC
- #endif
-#else
- #include <rtems/score/isrlevel.h>
-#endif
-#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
-typedef std::atomic_uint CPU_atomic_Uint;
-typedef std::atomic_ulong CPU_atomic_Ulong;
-typedef std::atomic_uintptr_t CPU_atomic_Uintptr;
-typedef std::atomic_flag CPU_atomic_Flag;
-typedef std::memory_order CPU_atomic_Order;
-#define CPU_ATOMIC_ORDER_RELAXED std::memory_order_relaxed
-#define CPU_ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
-#define CPU_ATOMIC_ORDER_RELEASE std::memory_order_release
-#define CPU_ATOMIC_ORDER_ACQ_REL std::memory_order_acq_rel
-#define CPU_ATOMIC_ORDER_SEQ_CST std::memory_order_seq_cst
-#define CPU_ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
-#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
-#define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
-#define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
-#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
-typedef atomic_uint CPU_atomic_Uint;
-typedef atomic_ulong CPU_atomic_Ulong;
-typedef atomic_uintptr_t CPU_atomic_Uintptr;
-typedef atomic_flag CPU_atomic_Flag;
-typedef memory_order CPU_atomic_Order;
-#define CPU_ATOMIC_ORDER_RELAXED memory_order_relaxed
-#define CPU_ATOMIC_ORDER_ACQUIRE memory_order_acquire
-#define CPU_ATOMIC_ORDER_RELEASE memory_order_release
-#define CPU_ATOMIC_ORDER_ACQ_REL memory_order_acq_rel
-#define CPU_ATOMIC_ORDER_SEQ_CST memory_order_seq_cst
-#else
-typedef unsigned int CPU_atomic_Uint;
-typedef unsigned long CPU_atomic_Ulong;
-typedef uintptr_t CPU_atomic_Uintptr;
-typedef bool CPU_atomic_Flag;
-typedef int CPU_atomic_Order;
-#define CPU_ATOMIC_ORDER_RELAXED 0
-#define CPU_ATOMIC_ORDER_ACQUIRE 2
-#define CPU_ATOMIC_ORDER_RELEASE 3
-#define CPU_ATOMIC_ORDER_ACQ_REL 4
-#define CPU_ATOMIC_ORDER_SEQ_CST 5
-#define CPU_ATOMIC_INITIALIZER_UINT( value ) ( value )
-#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ( value )
-#define CPU_ATOMIC_INITIALIZER_UINTPTR( value ) ( value )
-#define CPU_ATOMIC_INITIALIZER_FLAG false
-#endif
- * @brief Sets up a cpu fence.
- * @param[out] order The order for the fence.
-static inline void _CPU_atomic_Fence( CPU_atomic_Order order )
- std::atomic_thread_fence( order );
- atomic_thread_fence( order );
-#else
- (void) order;
- RTEMS_COMPILER_MEMORY_BARRIER();
-#endif
- * @brief Initializes Uint.
- * @param[out] obj The CPU atomic Uint to initialize.
- * @param desired The desired value for @a obj.
-static inline void _CPU_atomic_Init_uint( CPU_atomic_Uint *obj, unsigned int desired )
- obj->store( desired );
- atomic_init( obj, desired );
-#else
- *obj = desired;
-#endif
- * @brief Initializes Ulong.
- * @param[out] obj The CPU atomic Ulong to initialize.
-static inline void _CPU_atomic_Init_ulong( CPU_atomic_Ulong *obj, unsigned long desired )
-#else
- *obj = desired;
-#endif
- * @brief Initializes Uintptr.
- * @param[out] obj The CPU atomic Uintptr to initialize.
-static inline void _CPU_atomic_Init_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired )
-#else
- *obj = desired;
-#endif
- * @brief Loads value of Uint considering the order.
- * @param obj The CPU atomic Uint to get the value from.
- * @param order The atomic order for getting the value.
- * @return The value of @a obj considering the @a order.
-static inline unsigned int _CPU_atomic_Load_uint( const CPU_atomic_Uint *obj, CPU_atomic_Order order )
- return obj->load( order );
- return atomic_load_explicit( obj, order );
-#else
- unsigned int val;
- (void) order;
- val = *obj;
- return val;
-#endif
- * @brief Loads value of Ulong considering the order.
- * @param obj The CPU atomic Ulong to get the value from.
-static inline unsigned long _CPU_atomic_Load_ulong( const CPU_atomic_Ulong *obj, CPU_atomic_Order order )
-#else
- unsigned long val;
- (void) order;
- val = *obj;
- return val;
-#endif
- * @brief Loads value of Uintptr considering the order.
- * @param obj The CPU atomic Uintptr to get the value from.
-static inline uintptr_t _CPU_atomic_Load_uintptr( const CPU_atomic_Uintptr *obj, CPU_atomic_Order order )
-#else
- uintptr_t val;
- (void) order;
- val = *obj;
- return val;
-#endif
- * @brief Stores a value to Uint considering the order.
- * @param[out] obj The CPU atomic Uint to store a value in.
- * @param order The atomic order for storing the value.
-static inline void _CPU_atomic_Store_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
- obj->store( desired, order );
- atomic_store_explicit( obj, desired, order );
-#else
- (void) order;
- *obj = desired;
-#endif
- * @brief Stores a value to Ulong considering the order.
- * @param[out] obj The CPU atomic Ulong to store a value in.
-static inline void _CPU_atomic_Store_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
-#else
- (void) order;
- *obj = desired;
-#endif
- * @brief Stores a value to Uintptr considering the order.
- * @param[out] obj The CPU atomic Uintptr to store a value in.
-static inline void _CPU_atomic_Store_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
-#else
- (void) order;
- *obj = desired;
-#endif
- * @brief Fetches current value of Uint and adds a value to the stored value.
- * @param[in, out] obj The CPU atomic Uint to get the value from and add @a arg to.
- * @param arg The value to add to @a obj.
- * @param order The atomic order for the operation.
- * @return The value of @a obj prior to the addition of @a arg.
-static inline unsigned int _CPU_atomic_Fetch_add_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
- return obj->fetch_add( arg, order );
- return atomic_fetch_add_explicit( obj, arg, order );
-#else
- unsigned int val;
- ISR_Level level;
- (void) order;
- _ISR_Local_disable( level );
- val = *obj;
- *obj = val + arg;
- _ISR_Local_enable( level );
- return val;
-#endif
- * @brief Fetches current value of Ulong and adds a value to the stored value.
- * @param[in, out] obj The CPU atomic Ulong to get the value from and add @a arg to.
-static inline unsigned long _CPU_atomic_Fetch_add_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
-#else
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val + arg;
- return val;
-#endif
- * @brief Fetches current value of Uintptr and adds a value to the stored value.
- * @param[in, out] obj The CPU atomic Uintptr to get the value from and add @a arg to.
-static inline uintptr_t _CPU_atomic_Fetch_add_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
-#else
- uintptr_t val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val + arg;
- return val;
-#endif
- * @brief Fetches current value of Uint and subtracts a value from the stored value.
- * @param[in, out] obj The CPU atomic Uint to get the value from and subtract @a arg from.
- * @param arg The value to subtract from @a obj.
- * @return The value of @a obj prior to the subtraction of @a arg.
-static inline unsigned int _CPU_atomic_Fetch_sub_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
- return obj->fetch_sub( arg, order );
- return atomic_fetch_sub_explicit( obj, arg, order );
-#else
- unsigned int val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val - arg;
- return val;
-#endif
- * @brief Fetches current value of Ulong and subtracts a value from the stored value.
- * @param[in, out] obj The CPU atomic Ulong to get the value from and subtract @a arg from.
-static inline unsigned long _CPU_atomic_Fetch_sub_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
-#else
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val - arg;
- return val;
-#endif
- * @brief Fetches current value of Uintptr and subtracts a value from the stored value.
- * @param[in, out] obj The CPU atomic Uintptr to get the value from and subtract @a arg from.
-static inline uintptr_t _CPU_atomic_Fetch_sub_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
-#else
- uintptr_t val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val - arg;
- return val;
-#endif
- * @brief Fetches current value of Uint and ORs a value with the stored value.
- * @param[in, out] obj The CPU atomic Uint to get the value from and OR @a arg to.
- * @param arg The value to OR with @a obj.
- * @return The value of @a obj prior to the OR operation with @a arg.
-static inline unsigned int _CPU_atomic_Fetch_or_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
- return obj->fetch_or( arg, order );
- return atomic_fetch_or_explicit( obj, arg, order );
-#else
- unsigned int val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val | arg;
- return val;
-#endif
- * @brief Fetches current value of Ulong and ORs a value with the stored value.
- * @param[in, out] obj The CPU atomic Ulong to get the value from and OR @a arg to.
-static inline unsigned long _CPU_atomic_Fetch_or_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
-#else
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val | arg;
- return val;
-#endif
- * @brief Fetches current value of Uintptr and ORs a value with the stored value.
- * @param[in, out] obj The CPU atomic Uintptr to get the value from and OR @a arg to.
-static inline uintptr_t _CPU_atomic_Fetch_or_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
-#else
- uintptr_t val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val | arg;
- return val;
-#endif
- * @brief Fetches current value of Uint and ANDs a value with the stored value.
- * @param[in, out] obj The CPU atomic Uint to get the value from and AND @a arg to.
- * @param arg The value to AND with @a obj.
- * @return The value of @a obj prior to the AND operation with @a arg.
-static inline unsigned int _CPU_atomic_Fetch_and_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
- return obj->fetch_and( arg, order );
- return atomic_fetch_and_explicit( obj, arg, order );
-#else
- unsigned int val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val & arg;
- return val;
-#endif
- * @brief Fetches current value of Ulong and ANDs a value with the stored value.
- * @param[in, out] obj The CPU atomic Ulong to get the value from and AND @a arg to.
-static inline unsigned long _CPU_atomic_Fetch_and_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
-#else
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val & arg;
- return val;
-#endif
- * @brief Fetches current value of Uintptr and ANDs a value with the stored value.
- * @param[in, out] obj The CPU atomic Uintptr to get the value from and AND @a arg to.
-static inline uintptr_t _CPU_atomic_Fetch_and_uintptr( CPU_atomic_Uintptr *obj, uintptr_t arg, CPU_atomic_Order order )
-#else
- uintptr_t val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = val & arg;
- return val;
-#endif
- * @brief Fetches current value of Uint and sets its value.
- * @param[in, out] obj The CPU atomic Uint to get the value from and set the value to @a desired.
- * @param arg The value to set for @a obj.
- * @return The value of @a obj prior to the exchange with @a desired.
-static inline unsigned int _CPU_atomic_Exchange_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
- return obj->exchange( desired, order );
- return atomic_exchange_explicit( obj, desired, order );
-#else
- unsigned int val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = desired;
- return val;
-#endif
- * @brief Fetches current value of Ulong and sets its value.
- * @param[in, out] obj The CPU atomic Ulong to get the value from and set the value to @a desired.
-static inline unsigned long _CPU_atomic_Exchange_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
-#else
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = desired;
- return val;
-#endif
- * @brief Fetches current value of Uintptr and sets its value.
- * @param[in, out] obj The CPU atomic Uintptr to get the value from and set the value to @a desired.
-static inline uintptr_t _CPU_atomic_Exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t desired, CPU_atomic_Order order )
-#else
- uintptr_t val;
- ISR_Level level;
- (void) order;
- val = *obj;
- *obj = desired;
- return val;
-#endif
- * @brief Checks if value of Uint is as expected.
- * This method checks if the value of @a obj is equal to the value of @a expected. If
- * this is the case, the value of @a obj is changed to @a desired. Otherwise, the value
- * of @a obj is changed to @a expected.
- * @param[in, out] obj The CPU atomic Uint to operate upon.
- * @param[in, out] expected The expected value of @a obj. If @a obj has a different
- * value, @a expected is changed to the actual value of @a obj.
- * @param desired The new value of @a obj if the old value of @a obj was as expected.
- * @param succ The order if it is successful.
- * @param fail The order if it fails.
- * @retval true The old value of @a obj was as expected.
- * @retval false The old value of @a obj was not as expected.
-static inline bool _CPU_atomic_Compare_exchange_uint( CPU_atomic_Uint *obj, unsigned int *expected, unsigned int desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
- return obj->compare_exchange_strong( *expected, desired, succ, fail );
- return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
-#else
- bool success;
- ISR_Level level;
- unsigned int actual;
- (void) succ;
- (void) fail;
- actual = *obj;
- success = ( actual == *expected );
- if ( success ) {
- *obj = desired;
- } else {
- *expected = actual;
- return success;
-#endif
- * @brief Checks if value of Ulong is as expected.
- * @param[in, out] obj The CPU atomic Ulong to operate upon.
-static inline bool _CPU_atomic_Compare_exchange_ulong( CPU_atomic_Ulong *obj, unsigned long *expected, unsigned long desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
-#else
- bool success;
- ISR_Level level;
- unsigned long actual;
- (void) succ;
- (void) fail;
- actual = *obj;
- if ( success ) {
- *obj = desired;
- } else {
- return success;
-#endif
- * @brief Checks if value of Uintptr is as expected.
- * @param[in, out] obj The CPU atomic Uintptr to operate upon.
-static inline bool _CPU_atomic_Compare_exchange_uintptr( CPU_atomic_Uintptr *obj, uintptr_t *expected, uintptr_t desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
-#else
- bool success;
- ISR_Level level;
- uintptr_t actual;
- (void) succ;
- (void) fail;
- actual = *obj;
- if ( success ) {
- *obj = desired;
- } else {
- return success;
-#endif
- * @brief Clears the atomic flag.
- * @param[out] obj The atomic flag to be cleared.
-static inline void _CPU_atomic_Flag_clear( CPU_atomic_Flag *obj, CPU_atomic_Order order )
- obj->clear( order );
- atomic_flag_clear_explicit( obj, order );
-#else
- (void) order;
- *obj = false;
-#endif
- * @brief Returns current flag state and sets it.
- * @param[in, out] obj The atomic flag to be set.
- * @retval true @a obj was set prior to this operation.
- * @retval false @a obj was not set prior to this operation.
-static inline bool _CPU_atomic_Flag_test_and_set( CPU_atomic_Flag *obj, CPU_atomic_Order order )
- return obj->test_and_set( order );
- return atomic_flag_test_and_set_explicit( obj, order );
-#else
- bool flag;
- ISR_Level level;
- (void) order;
- flag = *obj;
- *obj = true;
- return flag;
-#endif
-#endif /* _RTEMS_SCORE_CPUSTDATOMIC_H */
2.35.3
