[PATCH 11/34] bsps: Use new APBUART register block API
Sebastian Huber
Wed May 31 16:30:46 UTC 2023
bsps/include/grlib/apbuart_termios.h | 4 +-
bsps/shared/grlib/uart/apbuart_cons.c | 136 +++++++++++++---------
bsps/shared/grlib/uart/apbuart_polled.c | 52 +++++----
bsps/shared/grlib/uart/apbuart_termios.c | 49 +++++---
bsps/sparc/leon3/console/console.c | 2 +-
bsps/sparc/leon3/console/printk_support.c | 16 ++-
bsps/sparc/leon3/include/bsp/leon3.h | 6 +
7 files changed, 162 insertions(+), 103 deletions(-)
diff --git a/bsps/include/grlib/apbuart_termios.h b/bsps/include/grlib/apbuart_termios.h
index 82eb4b6de4..a19b99b609 100644
--- a/bsps/include/grlib/apbuart_termios.h
+++ b/bsps/include/grlib/apbuart_termios.h
@@ -34,7 +34,7 @@
#define APBUART_TERMIOS_H
#include <rtems/termiostypes.h>
-#include "grlib.h"
+#include "apbuart.h"
#ifdef __cplusplus
extern "C" {
@@ -42,7 +42,7 @@ extern "C" {
struct apbuart_context {
rtems_termios_device_context base;
- struct apbuart_regs *regs;
+ apbuart *regs;
unsigned int freq_hz;
rtems_vector_number irq;
volatile int sending;
diff --git a/bsps/shared/grlib/uart/apbuart_cons.c b/bsps/shared/grlib/uart/apbuart_cons.c
index 5d47b7f4a1..74f9bf3e0c 100644
--- a/bsps/shared/grlib/uart/apbuart_cons.c
+++ b/bsps/shared/grlib/uart/apbuart_cons.c
@@ -47,11 +47,15 @@
#include <grlib/ambapp_bus.h>
#include <grlib/apbuart.h>
#include <grlib/ambapp.h>
-#include <grlib/grlib.h>
+#include <grlib/io.h>
#include <grlib/cons.h>
#include <grlib/apbuart_cons.h>
+#ifdef LEON3
+#include <bsp/leon3.h>
+#endif
/*#define DEBUG 1 */
#ifdef DEBUG
@@ -60,12 +64,6 @@
#define DBG(x...)
#endif
-/* LEON3 Low level transmit/receive functions provided by debug-uart code */
-#ifdef LEON3
-#include <leon.h>
-extern struct apbuart_regs *leon3_debug_uart; /* The debug UART */
-#endif
/* Probed hardware capabilities */
enum {
CAP_FIFO = 0x01, /* FIFO available */
@@ -74,7 +72,7 @@ enum {
struct apbuart_priv {
struct console_dev condev;
struct drvmgr_dev *dev;
+ apbuart *regs;
struct rtems_termios_tty *tty;
char devName[52];
@@ -213,18 +211,23 @@ static const rtems_termios_device_handler handler_polled = {
* can select appropriate routines for the hardware. probecap() return value
* is a CAP_ bitmask.
-static int probecap(struct apbuart_regs *regs)
+static int probecap(apbuart *regs)
int cap = 0;
+ uint32_t ctrl;
/* Probe FIFO */
- if (regs->ctrl & APBUART_CTRL_FA) {
+ ctrl = grlib_load_32(®s->ctrl);
+ if (ctrl & APBUART_CTRL_FA) {
cap |= CAP_FIFO;
/* Probe RX delayed interrupt */
- regs->ctrl |= APBUART_CTRL_DI;
- if (regs->ctrl & APBUART_CTRL_DI) {
- regs->ctrl &= ~APBUART_CTRL_DI;
+ ctrl |= APBUART_CTRL_DI;
+ grlib_store_32(®s->ctrl, ctrl);
+ if (ctrl & APBUART_CTRL_DI) {
+ ctrl &= ~APBUART_CTRL_DI;
cap |= CAP_DI;
@@ -241,6 +244,7 @@ int apbuart_init1(struct drvmgr_dev *dev)
char prefix[32];
unsigned int db;
static int first_uart = 1;
+ uint32_t ctrl;
/* The default operation in AMP is to use APBUART[0] for CPU[0],
* APBUART[1] for CPU[1] and so on. The remaining UARTs is not used
@@ -269,10 +273,12 @@ int apbuart_init1(struct drvmgr_dev *dev)
if (ambadev == NULL)
return -1;
pnpinfo = &ambadev->info;
- priv->regs = (struct apbuart_regs *)pnpinfo->apb_slv->start;
+ priv->regs = (apbuart *)pnpinfo->apb_slv->start;
/* Clear HW regs, leave baudrate register as it is */
- priv->regs->status = 0;
+ grlib_store_32(&priv->regs->status, 0);
+ ctrl = grlib_load_32(&priv->regs->ctrl);
/* leave Transmitter/receiver if this is the RTEMS debug UART (assume
* it has been setup by boot loader).
@@ -280,10 +286,10 @@ int apbuart_init1(struct drvmgr_dev *dev)
db = 0;
#ifdef LEON3
if (priv->regs == leon3_debug_uart) {
- db = priv->regs->ctrl & (APBUART_CTRL_RE |
- APBUART_CTRL_TE |
- APBUART_CTRL_PE |
- APBUART_CTRL_PS);
+ db = ctrl & (APBUART_CTRL_RE |
+ APBUART_CTRL_TE |
+ APBUART_CTRL_PE |
+ APBUART_CTRL_PS);
#endif
/* Let UART debug tunnelling be untouched if Flow-control is set.
@@ -293,12 +299,12 @@ int apbuart_init1(struct drvmgr_dev *dev)
* guess that we are debugging if FL is already set, the debugger set
* either LB or DB depending on UART capabilities.
- if (priv->regs->ctrl & APBUART_CTRL_FL) {
- db |= priv->regs->ctrl & (APBUART_CTRL_DB |
+ if (ctrl & APBUART_CTRL_FL) {
+ db |= ctrl & (APBUART_CTRL_DB |
APBUART_CTRL_LB | APBUART_CTRL_FL);
- priv->regs->ctrl = db;
+ grlib_store_32(&priv->regs->ctrl, db);
priv->cap = probecap(priv->regs);
@@ -387,12 +393,13 @@ static int apbuart_info(
sprintf(buf, "FS Name: %s", priv->condev.fsname);
print_line(p, buf);
- sprintf(buf, "STATUS REG: 0x%x", priv->regs->status);
+ sprintf(buf, "STATUS REG: 0x%x", grlib_load_32(&priv->regs->status));
print_line(p, buf);
- sprintf(buf, "CTRL REG: 0x%x", priv->regs->ctrl);
+ sprintf(buf, "CTRL REG: 0x%x", grlib_load_32(&priv->regs->ctrl));
print_line(p, buf);
sprintf(buf, "SCALER REG: 0x%x baud rate %d",
- priv->regs->scaler, apbuart_get_baud(priv));
+ grlib_load_32(&priv->regs->scaler),
+ apbuart_get_baud(priv));
print_line(p, buf);
return DRVMGR_OK;
@@ -407,6 +414,8 @@ static bool first_open(
struct apbuart_priv *uart = base_get_priv(base);
+ apbuart *regs = uart->regs;
+ uint32_t ctrl;
uart->tty = tty;
@@ -418,7 +427,8 @@ static bool first_open(
/* Enable TX/RX */
- uart->regs->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
+ ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
if (uart->mode != TERMIOS_POLLED) {
int ret;
@@ -435,15 +445,15 @@ static bool first_open(
uart->sending = 0;
/* Turn on RX interrupts */
- ctrl = uart->regs->ctrl;
ctrl |= APBUART_CTRL_RI;
if (uart->cap & CAP_DI) {
/* Use RX FIFO interrupt only if delayed interrupt available. */
ctrl |= (APBUART_CTRL_DI | APBUART_CTRL_RF);
- uart->regs->ctrl = ctrl;
return true;
@@ -454,13 +464,16 @@ static void last_close(
rtems_interrupt_lock_context lock_context;
+ uint32_t ctrl;
/* Turn off RX interrupts */
rtems_termios_device_lock_acquire(base, &lock_context);
- uart->regs->ctrl &=
- ~(APBUART_CTRL_DI | APBUART_CTRL_RI | APBUART_CTRL_RF);
+ ctrl &= ~(APBUART_CTRL_DI | APBUART_CTRL_RI | APBUART_CTRL_RF);
rtems_termios_device_lock_release(base, &lock_context);
/**** Flush device ****/
@@ -468,8 +481,8 @@ static void last_close(
/* Wait until all data has been sent */
while (
- (uart->regs->ctrl & APBUART_CTRL_TE) &&
- !(uart->regs->status & APBUART_STATUS_TS)
+ (grlib_load_32(®s->ctrl) & APBUART_CTRL_TE) &&
+ !(grlib_load_32(®s->status) & APBUART_STATUS_TS)
/* Wait until all data has left shift register */
@@ -480,8 +493,11 @@ static void last_close(
#ifdef LEON3
/* Disable TX/RX if not used for DEBUG */
- if (uart->regs != leon3_debug_uart)
- uart->regs->ctrl &= ~(APBUART_CTRL_RE | APBUART_CTRL_TE);
+ if (regs != leon3_debug_uart) {
+ ctrl &= ~(APBUART_CTRL_RE | APBUART_CTRL_TE);
#endif
@@ -497,10 +513,11 @@ static int read_task(rtems_termios_device_context *base)
- struct apbuart_regs *regs = uart->regs;
int cnt;
char buf[33];
+ uint32_t ctrl;
uint32_t ctrl_add;
ctrl_add = APBUART_CTRL_RI;
@@ -511,10 +528,10 @@ static int read_task(rtems_termios_device_context *base)
do {
cnt = 0;
while (
- (regs->status & APBUART_STATUS_DR) &&
+ (grlib_load_32(®s->status) & APBUART_STATUS_DR) &&
(cnt < sizeof(buf))
- buf[cnt] = regs->data;
+ buf[cnt] = grlib_load_32(®s->data);
cnt++;
if (0 < cnt) {
@@ -528,9 +545,11 @@ static int read_task(rtems_termios_device_context *base)
* afterwards.
- regs->ctrl |= ctrl_add;
+ ctrl |= ctrl_add;
- } while (regs->status & APBUART_STATUS_DR);
+ } while (grlib_load_32(®s->status) & APBUART_STATUS_DR);
return EOF;
@@ -541,7 +560,7 @@ int apbuart_get_baud(struct apbuart_priv *uart)
unsigned int scaler;
/* Get current scaler setting */
- scaler = uart->regs->scaler;
+ scaler = grlib_load_32(&uart->regs->scaler);
/* Get APBUART core frequency */
drvmgr_freq_get(uart->dev, DEV_APB_SLV, &core_clk_hz);
@@ -576,7 +595,7 @@ static bool set_attributes(
/* Read out current value */
+ ctrl = grlib_load_32(&uart->regs->ctrl);
switch(t->c_cflag & (PARENB|PARODD)){
case (PARENB|PARODD):
@@ -603,7 +622,7 @@ static bool set_attributes(
ctrl &= ~APBUART_CTRL_FL;
/* Update new settings */
+ grlib_store_32(&uart->regs->ctrl, ctrl);
@@ -617,7 +636,7 @@ static bool set_attributes(
scaler = (((core_clk_hz*10)/(baud*8))-5)/10;
/* Set new baud rate by setting scaler */
- uart->regs->scaler = scaler;
+ grlib_store_32(&uart->regs->scaler, scaler);
return true;
@@ -637,7 +656,7 @@ static void get_attributes(
t->c_cflag |= CS8;
/* Read out current parity */
if (ctrl & APBUART_CTRL_PE) {
if (ctrl & APBUART_CTRL_PS)
t->c_cflag |= PARENB|PARODD; /* Odd parity */
@@ -673,11 +692,11 @@ static void write_interrupt(
int sending;
unsigned int ctrl;
- ctrl = regs->ctrl;
if (len > 0) {
@@ -685,28 +704,30 @@ static void write_interrupt(
* we can tell termios later.
/* Enable TX interrupt (interrupt is edge-triggered) */
- regs->ctrl = ctrl | APBUART_CTRL_TI;
+ ctrl |= APBUART_CTRL_TI;
/* APBUART with FIFO.. Fill as many as FIFO allows */
sending = 0;
while (
- ((regs->status & APBUART_STATUS_TF) == 0) &&
+ ((grlib_load_32(®s->status) & APBUART_STATUS_TF) == 0) &&
(sending < len)
- regs->data = *buf;
+ grlib_store_32(®s->data, *buf);
buf++;
sending++;
} else {
/* start UART TX, this will result in an interrupt when done */
sending = 1;
} else {
/* No more to send, disable TX interrupts */
- regs->ctrl = ctrl & ~APBUART_CTRL_TI;
+ ctrl &= ~APBUART_CTRL_TI;
/* Tell close that we sent everything */
sending = 0;
@@ -722,21 +743,24 @@ static void apbuart_cons_isr(void *arg)
rtems_termios_device_context *base;
struct console_dev *condev = rtems_termios_get_device_context(tty);
struct apbuart_priv *uart = condev_get_priv(condev);
unsigned int status;
char buf[33];
int cnt;
if (uart->mode == TERMIOS_TASK_DRIVEN) {
- if ((status = regs->status) & APBUART_STATUS_DR) {
+ if ((status = grlib_load_32(®s->status)) & APBUART_STATUS_DR) {
+ uint32_t ctrl;
base = rtems_termios_get_device_context(tty);
- regs->ctrl &=
+ ctrl &=
APBUART_CTRL_RF);
/* Activate termios RX daemon task */
rtems_termios_rxirq_occured(tty);
@@ -749,10 +773,10 @@ static void apbuart_cons_isr(void *arg)
cnt = 0;
while (
- ((status=regs->status) & APBUART_STATUS_DR) &&
+ ((status=grlib_load_32(®s->status)) & APBUART_STATUS_DR) &&
(cnt < sizeof(buf))
cnt++;
if (0 < cnt) {
diff --git a/bsps/shared/grlib/uart/apbuart_polled.c b/bsps/shared/grlib/uart/apbuart_polled.c
index b83af56b09..f3e4997a12 100644
--- a/bsps/shared/grlib/uart/apbuart_polled.c
+++ b/bsps/shared/grlib/uart/apbuart_polled.c
@@ -1,8 +1,17 @@
/* SPDX-License-Identifier: BSD-2-Clause */
+ * @file
+ * @ingroup RTEMSDeviceGRLIBAPBUART
+ * @brief This source file contains the implementation of
+ * apbuart_outbyte_wait(), apbuart_outbyte_polled(), and
+ * apbuart_inbyte_nonblocking().
- * COPYRIGHT (c) 2010.
- * Cobham Gaisler AB.
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
* modification, are permitted provided that the following conditions
@@ -27,38 +36,37 @@
-#include <rtems/score/cpuimpl.h>
+#include <rtems/score/io.h>
-void apbuart_outbyte_wait(const struct apbuart_regs *regs)
+void apbuart_outbyte_wait( const apbuart *regs )
- while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
- /* Lower bus utilization while waiting for UART */
- _CPU_Instruction_no_operation();
+ while ( ( grlib_load_32( ®s->status ) & APBUART_STATUS_TE ) == 0 ) {
+ _IO_Relax();
-void apbuart_outbyte_polled(struct apbuart_regs *regs, char ch)
+void apbuart_outbyte_polled( apbuart *regs, char ch)
- apbuart_outbyte_wait(regs);
- regs->data = (uint8_t) ch;
+ apbuart_outbyte_wait( regs );
+ grlib_store_32( ®s->data, (uint8_t) ch );
-int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
+int apbuart_inbyte_nonblocking( apbuart *regs )
- /* Clear errors */
- regs->status = ~APBUART_STATUS_ERR;
+ uint32_t status;
+ status = grlib_load_32( ®s->status );
+ /* Clear errors, writes to non-error flags are ignored */
+ status &= ~( APBUART_STATUS_FE | APBUART_STATUS_PE | APBUART_STATUS_OV |
+ APBUART_STATUS_BR );
+ grlib_store_32( ®s->status, status );
- if ((regs->status & APBUART_STATUS_DR) == 0) {
+ if ( ( status & APBUART_STATUS_DR ) == 0 ) {
return -1;
- return (uint8_t) regs->data;
+ return (int) APBUART_DATA_DATA_GET( grlib_load_32( ®s->data ) );
diff --git a/bsps/shared/grlib/uart/apbuart_termios.c b/bsps/shared/grlib/uart/apbuart_termios.c
index 6506b70e3d..8b5ccd67f6 100644
--- a/bsps/shared/grlib/uart/apbuart_termios.c
+++ b/bsps/shared/grlib/uart/apbuart_termios.c
@@ -32,6 +32,7 @@
#include <grlib/apbuart_termios.h>
#include <bsp.h>
static void apbuart_isr(void *arg)
@@ -42,9 +43,9 @@ static void apbuart_isr(void *arg)
char data;
/* Get all received characters */
- while ((status=uart->regs->status) & APBUART_STATUS_DR) {
+ while ((status=grlib_load_32(&uart->regs->status)) & APBUART_STATUS_DR) {
/* Data has arrived, get new data */
- data = uart->regs->data;
+ data = (char)grlib_load_32(&uart->regs->data);
/* Tell termios layer about new character */
rtems_termios_enqueue_raw_characters(tty, &data, 1);
@@ -52,7 +53,7 @@ static void apbuart_isr(void *arg)
if (
(status & APBUART_STATUS_TE)
- && (uart->regs->ctrl & APBUART_CTRL_TI) != 0
+ && (grlib_load_32(&uart->regs->ctrl) & APBUART_CTRL_TI) != 0
/* write_interrupt will get called from this function */
rtems_termios_dequeue_characters(tty, 1);
@@ -67,23 +68,27 @@ static void apbuart_write_support(
struct apbuart_context *uart = (struct apbuart_context *) base;
int sending;
+ uint32_t ctrl;
if (len > 0) {
- uart->regs->ctrl |= APBUART_CTRL_TI;
- uart->regs->data = *buf;
+ grlib_store_32(&uart->regs->data, (uint8_t)*buf);
sending = 1;
} else {
- uart->regs->ctrl &= ~APBUART_CTRL_TI;
sending = 0;
uart->sending = sending;
@@ -134,7 +139,7 @@ static bool apbuart_set_attributes(
switch (t->c_cflag & (PARENB|PARODD)) {
@@ -162,7 +167,7 @@ static bool apbuart_set_attributes(
@@ -173,7 +178,7 @@ static bool apbuart_set_attributes(
scaler = (((uart->freq_hz * 10) / (baud * 8)) - 5) / 10;
return true;
@@ -184,7 +189,8 @@ static void apbuart_set_best_baud(
struct termios *term
- uint32_t baud = (uart->freq_hz * 10) / ((uart->regs->scaler * 10 + 5) * 8);
+ uint32_t baud = (uart->freq_hz * 10) /
+ ((grlib_load_32(&uart->regs->scaler) * 10 + 5) * 8);
rtems_termios_set_best_baud(term, baud);
@@ -197,12 +203,15 @@ static bool apbuart_first_open_polled(
+ uint32_t ctrl;
apbuart_set_best_baud(uart, term);
/* Initialize UART on opening */
- uart->regs->status = 0;
+ grlib_store_32(&uart->regs->status, 0);
return true;
@@ -216,6 +225,7 @@ static bool apbuart_first_open_interrupt(
rtems_status_code sc;
+ uint32_t ctrl;
@@ -229,11 +239,13 @@ static bool apbuart_first_open_interrupt(
uart->sending = 0;
/* Enable Receiver and transmitter and Turn on RX interrupts */
- uart->regs->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE |
- APBUART_CTRL_RI;
+ ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE | APBUART_CTRL_RI;
return true;
@@ -246,10 +258,13 @@ static void apbuart_last_close_interrupt(
+ uint32_t ctrl;
- uart->regs->ctrl &= ~(APBUART_CTRL_RI);
+ ctrl &= ~APBUART_CTRL_RI;
diff --git a/bsps/sparc/leon3/console/console.c b/bsps/sparc/leon3/console/console.c
index 24484eb96f..891116b2c4 100644
--- a/bsps/sparc/leon3/console/console.c
+++ b/bsps/sparc/leon3/console/console.c
@@ -81,7 +81,7 @@ static int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
/* Extract needed information of one APBUART */
- apbuarts[uarts].regs = (struct apbuart_regs *)apb->start;
+ apbuarts[uarts].regs = (apbuart *)apb->start;
apbuarts[uarts].irq = apb->common.irq;
/* Get APBUART core frequency, it is assumed that it is the same
* as Bus frequency where the UART is situated
diff --git a/bsps/sparc/leon3/console/printk_support.c b/bsps/sparc/leon3/console/printk_support.c
index 9fd1b1a089..cb77c66a96 100644
--- a/bsps/sparc/leon3/console/printk_support.c
+++ b/bsps/sparc/leon3/console/printk_support.c
@@ -35,14 +35,17 @@
#include <bsp.h>
-#include <leon.h>
#include <rtems/bspIo.h>
#include <rtems/sysinit.h>
+#include <grlib/ambapp.h>
int leon3_debug_uart_index __attribute__((weak)) = 0;
-struct apbuart_regs *leon3_debug_uart = NULL;
+apbuart *leon3_debug_uart = NULL;
static void bsp_debug_uart_init(void);
@@ -105,15 +108,18 @@ static void bsp_debug_uart_init(void)
ambapp_find_by_idx, (void *)&i);
if (adev != NULL) {
struct ambapp_apb_info *apb;
+ uint32_t ctrl;
* Found a matching debug console, initialize debug UART if present for
* printk().
apb = (struct ambapp_apb_info *)adev->devinfo;
- leon3_debug_uart = (struct apbuart_regs *)apb->start;
- leon3_debug_uart->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
- leon3_debug_uart->status = 0;
+ leon3_debug_uart = (apbuart *)apb->start;
+ ctrl = grlib_load_32(&leon3_debug_uart->ctrl);
+ grlib_store_32(&leon3_debug_uart->ctrl, ctrl);
+ grlib_store_32(&leon3_debug_uart->status, 0);
BSP_poll_char = bsp_debug_uart_poll_char;
BSP_output_char = bsp_debug_uart_output_char;
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 05915a7dea..7c723de129 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -38,6 +38,7 @@
+#include <grlib/apbuart-regs.h>
struct ambapp_dev;
@@ -104,6 +105,11 @@ static inline uint32_t bsp_irq_fixup( uint32_t irq )
return eirq;
+ * @brief This pointer provides the debug APBUART register block address.
+extern apbuart *leon3_debug_uart;
#ifdef __cplusplus
2.35.3
